Old 01-19-2010, 10:26am   #1
FRC Joe
Points: 4,203, Level: 43
FRC Joe's Avatar
Gameroom Barn Bucks: $882
Default FRC Joe's underhood thread
In Nov of 08 I had my tranny lock itself into 4th gear at a track rental. I suppose pushing twice the stock power through it had something to do with it. While the driveline was out for that repair I thought I'd take the opportunity to clean up a few items under the hood and fix some things that I wasnt 100% happy with from my blower install. A combination of scope creep, fluctuating interest and poverty has stretched the project out to 14 mos. and counting, but I can see the light at the end of the tunnel! Here's a few pics of the progress.
Relocated
Coils into fenderwells w/ custom brackets and wire looms
Evap Solenoid to firewall
Catch Can to front of radiator
Replaced
Rear Main Seal
PS Pulley with LS2 steel
Valve covers
Coolant Hoses (w/Black Silicone)
Exhaust bolts with ARP studs
Ignition Wires with Accell Extreme 9000 Ceramics
Revised
Air Inlet Tube from IC to TB
PCV system
EVAP system
Top of A&A radiator to allow bolting on of top cover
Re-Routed or Hidden
Headlight wiring
top AC line
Alky Line
EVAP wiring
Coil Harnesses
TB, MAF and TPS wiring
IAT wiring
99 FRC - A&A T-Trim @ 10PSI
Old 01-19-2010, 11:19am   #2
That is some nice looking work, very professional. Looks like you're quite adept at polishing as well.
Old 01-19-2010, 11:26am   #3
FRC Joe
FRC Joe's Avatar
Thanks! Yeah I spent many hours this summer with the 2000 and some soapy water.
Also of note, The inky black intake manifold and blower inlet piece were painted by the man himself, GBVette. Laying down flawless black paint is practically a reflexive reaction for him now!
Old 01-19-2010, 12:05pm   #4
edcmat-l1
Charter Member - Vendor
Points: 3,014, Level: 35
edcmat-l1's Avatar
Gameroom Barn Bucks: $1080
Looks real nice.
The Following User Says Thank You to edcmat-l1 For This Useful Post:
Old 01-19-2010, 4:21pm   #5
Attention to detail is astounding. You could make these into a few various kits and sell them for sure.
Old 01-19-2010, 6:02pm   #6
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
The Following User Says Thank You to Garb55 For This Useful Post:
Old 01-19-2010, 10:17pm   #7
FRC Joe
FRC Joe's Avatar
Here's the evap solenoid mounted on the firewall. This was difficult to photograph. The solenoid is mounted vertically and the curvy plastic hose comes out of the bottom and back up to the re-positioned hard line. The test port is accessible, and it shouldnt pick up any header heat. Hopefully I wont get any crap about moving it at inspection time.
Old 01-19-2010, 10:30pm   #8
Inspector won't have any clue.
Old 01-20-2010, 8:33am   #9
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Looks incredible!
BTW, what's scope creep? A peeping tom with minty fresh breath?!?
j/k! Sounds like you deal with Lean manufacturing / Six Sigma?
The Following User Says Thank You to DropTheTop For This Useful Post:
Old 01-20-2010, 10:13am   #10
Scope creep = "well if I'm going to have to do x, then I might as well do y. Oh... well if I have to do x and y, then I should go ahead and do z." And so on and so forth It's what alwasy happens to me on my projects.
Old 01-20-2010, 10:14am   #11
I misplaced all of that stuff a while ago. The only thing they looked for at inspection time was the air pump. I have that (non-functional)
Old 01-20-2010, 10:16am   #12
Odd... I've had my car inspected 3x w/o an air pump.
Old 01-20-2010, 11:31am   #13
Do you even have emissions testing in VA Beach?
Old 01-20-2010, 12:34pm   #14
Not a sniffer test... they plug in the OBDII port though and most shops will look for things like headers w/o cats.
Old 01-21-2010, 8:40am   #15
FRC Joe
FRC Joe's Avatar
Originally Posted by DropTheTop View Post
Looks incredible!
Oh yeah! I did contracting stints at GE Appliance and GE Industrial Drive Systems in the mid and late 90s when that was coming into vogue.
Old 02-14-2010, 2:46pm   #16
FRC Joe
FRC Joe's Avatar
Default Getting close to done
Old 02-14-2010, 3:18pm   #17
Vet4jdc
Barn Stall Owner #78
Points: 19,383, Level: 96
Vet4jdc's Avatar
Gameroom Barn Bucks: $1004569
Awesome....can't wait to see it in person at Waterside!
The Following User Says Thank You to Vet4jdc For This Useful Post:
Old 02-14-2010, 5:17pm   #18
I really like what you did with your alternator bracket!
Old 02-14-2010, 8:15pm   #19
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
What fuel system did you install? Do you like it?
Old 02-14-2010, 8:16pm   #20
thegreenman
Looking really nice, great job.
