09-12-2021, 2:24pm | #1 | ||||||
Barn Stall Owner #1991
Besides those that call Audi junk, who can help?
2013 Audi A4 Quattro 2.0T. Having issues with it not starting. Carista OBD2 says U0100 code, which always comes back when reset. The rest of the codes are
CAN Network gateway 01314 Ignition Authorization 00956, 01330 Instrument cluster 01314 Parking brake 334080, 331264, 331520, 460800 Engine 04533, 10577 Transmission 12551, 12554, 12562 Power steering 3158274 New Alternator, new battery. ~51,200 miles. Battery is in the trunk, under the spare tire and tool kit. Hook up jumper cables under the hood and the car fires right up. When started, car runs normal. I do not have tools to test everything, such as a multimeter. Wouldn't know where to test if I had one. By the time I am don't with this car, I will probably know how to build one. |
09-12-2021, 2:26pm | #2 |
09-12-2021, 2:27pm | #3 | ||||||
Required photo.
The Following User Says Thank You to carlton_fritz For This Useful Post: |
09-12-2021, 2:35pm | #4 | ||||||
Codes are meaningless without definitions.
Current or history also is needed. Easiest thing to do would be test the battery, testing wise. A load test is in order especially if any of those codes are low voltage or comms errors. A voltage test on a battery pretty much useless unless it's completely shot. |
09-12-2021, 2:38pm | #5 | ||||||
Barn Stall Owner #93
Yes, the first thing is to look up every code. I’m not doing it. Too lazy.
09-12-2021, 3:15pm | #6 | |||||||
Can you clear codes on that car? If so, I would clear codes, start with jumpers and then check codes again. If the car doesn't start at all, I wouldn't trust the codes as low voltage can cause havoc in electronics. An auto store should have a multimeter to borrow. I'd look at battery voltages as you try and start the engine to see how far they sag. Any reasonable "box store" repair shop should have a load tester for your battery as well. If battery checks out well, and you can start it via jumper, the only easy thing to check is the connections at the battery, and the voltage at the starter. Everything else is probably managed by the electronics. |
09-12-2021, 3:22pm | #7 | ||||||
Gameroom Barn Bucks: $2106426
Lost Communication Faults
The digital data bus is damaged. The main causes common to all the malfunctions described in this section are: - disconnection of contacts due to vibration; - corrosion or clogging, moisture entering the connector; - melting of contact elements on the block as a result of voltage drops; - damage to the cable, an open circuit connected to the device; - wear of the insulating layer on the line, which led to a short circuit in the wiring; - equipment failure. |
The Following User Says Thank You to 09CTSV For This Useful Post: |
09-12-2021, 5:01pm | #8 | |||||||
That’s going to hurt |
09-12-2021, 5:43pm | #9 | |||||||
09-12-2021, 6:20pm | #10 | ||||||
Step one keep it simple... Check connections at battery and check battery, if you dont do that first wasting your time as any corrosion or non tight connection reaks havoc with never vehicles. We're talking if you turn the connections 1/8 to 1/4 they were loose or frankly any turning at all.
Next up i always check the grounds, visual check usually good enough. If you just start randomly checking and replacing stuff you'll end up insane like the rest of us. If voltage in battery is weak /bad connection or ground and you jump start them you can easily damage computers especially if using high amp starter. I've known several people who's battery went completely dead and someone jumped them and ruined computers, they can't handle voltage spikes and swings. Good luck. |
09-12-2021, 6:32pm | #11 | |||||||
Barn Stall Owner #747-400
09-12-2021, 6:52pm | #12 | ||||||
09-12-2021, 7:03pm | #13 | ||||||
Gameroom Barn Bucks: $152956
If your going to do much work on that car, I highly recommend the VCDS cable. We've had up to 4 audi's here, they've been great cars - but you really need a diagnostic cable.
You said it was a new battery, was it an Audi battery? It seems the VW/Audi products are extremely sensitive to voltage and will not do anything if it is under voltage. Also, in looking at the VCDS page, it could be that or a relay issue. https://www.google.com/url?client=in...dQgfPDPpNa79oj Not sure where you are located, but I'd offer you my cable if you were nearby... |
The Following 2 Users Say Thank You to John Wiz For This Useful Post: |
09-12-2021, 8:35pm | #14 | |||||||
09-12-2021, 10:24pm | #15 | |||||||
09-12-2021, 10:28pm | #16 | ||||||
Due to inflation they are no longer free
Gameroom Barn Bucks: $324490
Never own a German car after the warranty is up.
YW |
The Following 4 Users Say Thank You to Anjdog2003 For This Useful Post: |
09-13-2021, 9:21am | #17 | ||||||
09-13-2021, 10:44am | #18 | ||||||
As an automotive professional for over 40 years, this is 100% correct. Audi is the least reliable of all the German cars, and have been known for electrical gremlins for decades. Only British cars have more electrical issues.
