Old 08-06-2010, 6:37pm   #1
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Default Cleaned Up, Added some LED's..
Still needs to be lowered. Looking for Some Coil Overs next....
Old 08-06-2010, 6:39pm   #2
1TZSLO
Points: 5,654, Level: 51
1TZSLO's Avatar
Gameroom Barn Bucks: $377
So true slam that girl to the ground, or kinda close lol. Very sexy but gaps in the teeth are yuck hahah.
Arctic White 97 C5 Coupe
NOT STOCK
The Following User Says Thank You to 1TZSLO For This Useful Post:
Old 08-06-2010, 6:43pm   #3
Garb55
Garb55's Avatar
Yea, I hate the "GAPS" I go "LOW"!
Old 08-06-2010, 6:52pm   #4
Lightfoot
Points: 2,293, Level: 30
Lightfoot's Avatar
Gameroom Barn Bucks: $3880614
Beautiful ride. I'm sorta fond of blue myself!
Man, you got that thing clean!!!! Mine gets dirtier than that just sittin in the garage.
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
Old 08-06-2010, 7:24pm   #5
Garb55
Garb55's Avatar
Same Here, I have a cover and she still gets Dirty......
Old 08-06-2010, 8:10pm   #6
Looks great! Diggin the LED's.
Old 08-06-2010, 8:52pm   #7
Garb55
Garb55's Avatar
Yours Look Killer as well!
Old 08-06-2010, 8:56pm   #8
Those LED's really light things up! the blue is very cool.
I thought about doing something similar but I rarely have the Vette out after dark so it didn't make much sense.
Old 08-06-2010, 9:00pm   #9
Garb55
Garb55's Avatar
They look brighter in the photo then in person, however are still pretty bright.
Old 08-12-2010, 7:37pm   #10
Garb55
Garb55's Avatar
Just Installed Some LED Halo Tail Lights!
Before with Stock!
LED Halo
Old 08-12-2010, 10:07pm   #11
lutzdog
Points: 11,003, Level: 72
lutzdog's Avatar
Gameroom Barn Bucks: $595211
when you added your led's did you add a led flasher to cure the hyper flash? or what special things did you do?
Old 08-13-2010, 6:55am   #12
FSTFRC
Points: 1,516, Level: 23
FSTFRC's Avatar
Gameroom Barn Bucks: $1046
Looks good! The lights go well with your color.
FSTFRC is offline   Reply With Quote
The Following User Says Thank You to FSTFRC For This Useful Post:
Old 08-13-2010, 7:38am   #13
The halo's are a great mod, I have the black cherry ones.
Old 08-13-2010, 9:09am   #14
Peter Pan
Barn Stall Owner #58
Points: 9,221, Level: 66
Peter Pan's Avatar
Gameroom Barn Bucks: $13154
Halos and LEDs go together and your Z is a beauty
The Following User Says Thank You to Peter Pan For This Useful Post:
Old 08-13-2010, 4:04pm   #15
Garb55
Garb55's Avatar
Debating on Darkening them, will see how I like the red 1st.
Old 08-13-2010, 4:25pm   #16
Garb55
Garb55's Avatar
I have one on the list of things I still need to pick up.
Old 08-13-2010, 9:38pm   #17
Garb55
Garb55's Avatar
I might try this?
https://www.thevettebarn.com/forums/g....html#post5593
Old 08-14-2010, 9:52pm   #18
Garb55
Garb55's Avatar
Going to try the LED Tail Lights Halo Mod.
I had some 470k-Ohm 1/2 watt 5% Torrence Resistors from another project but I could not get them to work. The Directions on you tube show 470k-Ohm 1/2 watt 5% Carbon Film Resistor. Not sure if the Carbon Film Resistor makes a difference or not so I'm going to pick some up and retry..
These directions just state (4) 5-packs of 470 ohm .5 watt resistors.
Old 08-14-2010, 10:17pm   #19
What flashes when you use the blinker, the halo, the center or everything? What about when the brakes are being applied as well.
Old 08-14-2010, 10:44pm   #20
Garb55
Garb55's Avatar
http://www.youtube.com/user/BrianICS#p/a/u/2/IIgyofoP3D8
There are other options as well. Not sure what I'm going to do I just need to get the basic to work 1st.
The Following User Says Thank You to Garb55 For This Useful Post:
