03-02-2024, 7:48am | #1 |
garage lighting question
i have two fluorescent light fixtures on my garage ceiling with 2x tubes in each.
Sometimes when i flip the switch, all four tubes light up. Other times on set will light up and the other follows a minute or so later. Sometimes, the farthest one from the panel doesnt light up, but the ends of the tubes glow dim. I can occasionally flip the switch off/on real fast and the lights come on. Is this simply a need to change the bulbs, are rectifiers going bad, or should I call Father Guido Sarducci to do an excorcism? |
03-02-2024, 7:53am | #2 | ||||||
Use these...I have one in my attic (Shea Stadium) lol
https://www.amazon.com/Deformable-Ce...IlX_D_BwE&th=1 |
03-02-2024, 8:01am | #3 | ||||||
Gameroom Barn Bucks: $2001216
Possibly ballast are going bad.
03-02-2024, 8:07am | #4 | |
Is there any way to check without consulting Aero? |
03-02-2024, 8:13am | #5 | ||||||
03-02-2024, 8:15am | #6 | ||||||
I don't know of a good test for the ballast; but I would swap to LEDs anyway; ones without a ballast. It takes a bit of rewiring the fixtures but not all that hard.
03-02-2024, 8:19am | #7 | ||||||
Barn Stall Owner #105
Remove ballast and install LED or install new LED fixtures; whatever is easiest. I did a friend’s kitchen lighting and it was a great improvement over the old lights.
The dimmer switch had to be replaced by the proper type, but that won’t apply to your application. |
The Following User Says Thank You to BayouCountry For This Useful Post: |
03-02-2024, 8:33am | #8 | ||||||
To change over to LED bulbs, you simply bypass (remove) the ballast, reconnecting black and white wires.
03-02-2024, 8:38am | #9 | ||||||
Barn Stall Owner #747-400
The Following 6 Users Say Thank You to Rikki Z-06 For This Useful Post: |
03-02-2024, 8:39am | #10 | ||||||
03-02-2024, 8:43am | #11 | ||||||
Barn Stall Owner #14/32
Gameroom Barn Bucks: $4810
I can't believe nobody suggested switching to LEDs yet.
03-02-2024, 8:48am | #12 | ||||||
The Following User Says Thank You to Rikki Z-06 For This Useful Post: |
03-02-2024, 8:48am | #13 | ||||||
For the costs of new bulbs and or ballasts it's cheaper to replace with led shop lights.
Bulbs are most likely going bad is all. |
The Following 3 Users Say Thank You to Rodnok1 For This Useful Post: |
03-02-2024, 8:48am | #14 | ||||||
The Following 3 Users Say Thank You to zsr22 For This Useful Post: |
03-02-2024, 8:50am | #15 | ||||||
The Following User Says Thank You to Vandelay Industries For This Useful Post: |
03-02-2024, 8:56am | #16 | ||||||
Gameroom Barn Bucks: $1014987
Is the garage heated? They will do what you indicate when cold.
The Following User Says Thank You to Old Ben For This Useful Post: |
03-02-2024, 10:43am | #17 | ||||||
03-02-2024, 10:47am | #18 | ||||||
How long before some ass wipe pulls that down?
03-02-2024, 10:53am | #19 | ||||||
The Following User Says Thank You to zsr22 For This Useful Post: |
03-02-2024, 10:56am | #20 | ||||||
