Old 01-20-2012, 11:37pm   #1
oahuyahoo
Barn Stall Owner #67
Points: 12,190, Level: 76
oahuyahoo's Avatar
Default Now it's the AC
Used to come on all the time then slowly started to not work. Finally died the other day so I put in a new climate control unit. No go. Screwed somewhere else. Started with the fuses, I don't know why this has been a slow death not an instant one such as what a fuse would cause. Fuses are all good, now what?
oahuyahoo is offline   Reply With Quote
Old 01-20-2012, 11:46pm   #2
Vette40th
Points: 19,203, Level: 95
Activity: 16.9%
Vette40th's Avatar
Gameroom Barn Bucks: $3694
Disregard all and follow post after mine. You probably have bad seals within the lines. Common
Vette40th is offline   Reply With Quote
Old 01-22-2012, 8:19pm   #3
A slow death usually means a leak in the system somewhere. Get a can of R134 with the re-usable hose and gauge at Autozone. Start the car, turn the HVAC system down to 60 with the fan on high. Attach the can to the low side port.(don't worry it will only fit the low side port) As the charge gets into the system, you should hear the compressor kick on. Charge it up to the recommended level.
Old 07-07-2013, 11:01am   #4
Chuck A
Points: 40,099, Level: 100
Activity: 2.2%
Chuck A's Avatar
Gameroom Barn Bucks: $2601174
will the AC light not come on if the its low on charge, i tried turning my AC on the light stays on for 3-5 seconds then shuts off, any ideas?
Old 09-14-2013, 7:16pm   #5
Marmaduke
Barn Raising III
Points: 1,047, Level: 18
Marmaduke's Avatar
Gameroom Barn Bucks: $637
Check your AC Compressor ! Also, have the coolant/refrigerant checked as well. You could have a leak and/or the compress is bad.
Marmaduke is offline   Reply With Quote
