Old 05-21-2010, 9:00am   #1
Lowcash
Points: 4,921, Level: 47
Lowcash's Avatar
Gameroom Barn Bucks: $2827
Default Recharging an A/C
When I turned the AC on yesterday driving home it blew hot air for about 35 minutes; then it cooled down enough to stop me from sweating but it wasn't 'cold' air. I checked the codes and I don't have any, although I did have the right actuator code a while ago; but not yesterday or this morning.
I had a similar issue in my Explorer and I ended up adding a bottle of freon and all is 'cool'.
Is there anything special I need to do prior? (ie. drain the whole system)
Where is the low pressure connection connection on the C5?
Is there anything special I need to look out for?
2008 C6 Z06
Old 05-21-2010, 11:08am   #2
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
First thing I would do is to check the lines for oil to see if it is leaking. I don't know about the C5 locations but it might be the same as my C6, if memory serves me right one fitting was near the firewall and the other was near the fender. You should be able to follow the lines to find the fittings. I recharged mine when I upgraded the radiator, really easy.
Old 05-21-2010, 4:33pm   #3
The low pressure tap is beside the battery den.
Old 05-22-2010, 6:47am   #4
Hey Sean. For just a low charge, grab a can of 134a at autozone with the built in gauge and re-usable tap and hose. They are pretty accurate, and will let you know when you're in the proper poundage range.
The Following 2 Users Say Thank You to Sneaks For This Useful Post:
Old 05-22-2010, 7:21am   #5
Lowcash
Lowcash's Avatar
I checked this morning for any leaking and there was none.
Got it.
I have still have the tap and gauge from when I recharged the Exploder with 134. Will try to get out to Autozone today to pick up another bottle of 134a.
2008 C6 Z06
Old 05-22-2010, 6:53pm   #6
Lowcash
Lowcash's Avatar
After discovering my last tap and gauge was leaking, I picked up another bottle/gauage and all is well. It blows colder than polar bear farts.
It was on just between the fill and add level. So I filled it up just short of the 'danger zone'.
2008 C6 Z06
Old 05-22-2010, 9:17pm   #7
I would ask how you know how cold a polar bear fart is, but hell you travel all over the world, so why bother.
