Old 04-06-2011, 8:37pm   #1
skips2002
Points: 1,177, Level: 19
skips2002's Avatar
Gameroom Barn Bucks: $520
Default Traction Control problems
I am getting service messages on the computer display for the Traction Control System. It affects the Antilock Brake System and the Cruise Control System. I am looking for possible causes and solutions to the problem.
skips2002 is offline   Reply With Quote
Old 04-07-2011, 8:49am   #2
03SlowZ06
Points: 3,068, Level: 36
03SlowZ06's Avatar
Gameroom Barn Bucks: $100431
Check the DIC and post up the codes you are getting.
Old 04-07-2011, 8:01pm   #3
skips2002
skips2002's Avatar
Default Traction Control Problems
The DIC code is C1287!
Old 04-07-2011, 8:48pm   #4
That would be the steering sensor. Possibly you need an alignment or else your sensor is going bad.
Is the steering wheel straight while driving straight down the road? If it is then the sensor may be to blame.
Here is how to check the sensor courtesy of Bill Curlee:
The sensor inside the drivers foot well at the base of the steering column and has FOUR wires:
There connected to pins 1, 2, 5 & 6 on the sensor.
Pin 1 is GRY and it will have a 5 VDC (4.9) reference sig from the EBCM. It also feeds the YAW rate sensor and the lateral rate sensor. i would also check for the voltage there. It is also a GRY wire.
Pin 2 is ORN/BLK and it will have a LOW REFF (sensor ground) Sig. It also goes to the YAW and lateral sensors as the same color wires.
Pin 5 is the Steering wheel position sensor signal phase A. It goes directly to the EBCM Lite green wire
Pin 6 is the Steering wheel position sensor signal phase B. It goes directly to the EBCM Lite Blue wire
If you disconnect the sensor plug, you should read (if i read the procedure correctly) .2 VDC on pin 5 & 6
Read the 5 VDC ref voltage to the Low reff pin 2, orange/blk wire should see 5 VDC. if you measure the low reff pin to ground it should not read any higher than 5 ohms.
If it were me,, I would hook up a jumper wire to pin #1 0n the sensor and when the steering wheel is straight, you should see The same output on pins 5 & 6. As you turn the wheel all the way right and left, you should see one pins voltage smoothly increase while the other one smoothly decreases.
Hope this helps.
BC
Old 04-08-2011, 1:58pm   #5
skips2002
skips2002's Avatar
Hey thanks for the info, I will check this out.
Old 04-09-2011, 4:05pm   #6
Tulsa Vette Guy
Points: 4,253, Level: 44
Tulsa Vette Guy's Avatar
Gameroom Barn Bucks: $13
I had the same problem, after resetting the DIC, no more problems.
Old 05-27-2013, 1:26pm   #7
Marmaduke
Barn Raising III
Points: 1,047, Level: 18
Marmaduke's Avatar
Gameroom Barn Bucks: $637
Not to rain on your quest to solve you code problem, but if it's the Steering Position Sensor you may have problems finding one. I have a 99 C5 with the same problem and GM has discontinued (doesn't make em anymore) the 99-00 "Steering Position/Control Sensor". So far there just aren't any available. . . . . .
Marmaduke is offline   Reply With Quote
Old 07-18-2013, 11:07am   #8
Marmaduke
Barn Raising III
Marmaduke's Avatar
I'm having the same problem with my 1999 C5 . . . . it's the "Steering Wheel Position Sensor" located on the bottom end of the steering column under the dash.
GM no longer manufactures the sensor (well, actually Bosh manufactures them. GM and Bosh have had a falling out, so Bosh stopped manufacturing them). So, Chevy (GM) dealers can’t order the sensors from GM anymore.
NOTE: The 1998/1999 C5 Sensor are different from later model Vettes, e.g., 2000 and later, so the newer sensors are not interchangeable. . . .
OPTIONS: Locate and order a used Sensor (not easy to find and if you do the salvage folks are charging as much for the used part as you would pay for a new one). That's what I've done. . . . .
I’m having my 1999 C5 worked on now (as we speak). I had to buy a “USED” Sensor ($350.00 ~ Used).
What's Involved: To replace the sensor the steering wheel and steering column have to be removed ($$$$ ~ Labor). For me, this is the second “used” sensor I have order and having installed. I was lucky; the shop that’s working on my Vette (and ordered the first sensor) didn’t charge me for the part or the labor on the first attempt at replacing the sensor.
(I’m hoping this 2nd sensor will take care of the problem).
FYI ~ Cost for part and labor can run upwards to $600.-$800. (it ain’t cheap) !
FYI ~ This is a known problem by GM, but no resolution seems to be in the making.
Old 08-12-2013, 8:21am   #9
tbrent
Points: 7,109, Level: 58
tbrent's Avatar
Gameroom Barn Bucks: $135
I have an '01 and have to address this problem soon as well... But the reason I am posting is your engine bay is GORGEOUS!
Sorry to get off topic OP... Would love details about this engine bay full of candy though... Phew
tbrent is offline   Reply With Quote
Old 09-15-2013, 7:20pm   #10
Marmaduke
Barn Raising III
Marmaduke's Avatar
Default Engine Bay ~ 1999 C5 Coupe
tbrent,
Engine is a 2010 LS3, 6.2 Liter, Stroked to 427ci. Dyno'ed at 562 RWHP
with 551 Ft lbs Torque @ 3000 RPM. Thanks for the comments.
Old 11-11-2013, 8:56pm   #11
tbrent
tbrent's Avatar
tbrent,
No problem! Like a piece of candy... Would love an LS3 but I just spent pretty penny's on LG 1 7/8 headers on my LS6 and don't think the wifey would appreciate having to sell take a loss and buy new again
Speaking of this steering wheel position sensor problem,,, has anyone gone about somehow deleting their active handling? Is this possible?
Maybe I should start another thread...
