01-22-2024, 4:19pm | #1 | ||||||
Barn Stall Owner #14/32
Gameroom Barn Bucks: $4810
Water heater anode rods. Anybody ever bother changing them?
I had a problem with an electric water heater in one of my rental properties last week. One of the heating elements shit the bed, but I could also see quite a bit of exterior corrosion on the tank along with water seepage, so it made sense to replace the 16 year old unit.
For the hell of it, I had a look at the anode rod...or what was left of it: absolutely nothing. One of the other heaters was installed at the same time so I pulled the rod on that one...slightly better. At least the wire was still attached. Since there is no visible corrosion and no sign of leakage, I put a new anode in that one. Maybe it'll buy a few more years, maybe not. |
01-22-2024, 4:24pm | #2 | ||||||
Gameroom Barn Bucks: $2001216
01-22-2024, 4:24pm | #3 | ||||||
Yep in everyone depending on the water 3 to 5 years and two of my water heaters are over 20 years old. Also first thing is to change the factory drain with a full bore one.
The Following 2 Users Say Thank You to Big bob For This Useful Post: |
01-22-2024, 4:26pm | #4 | |||||||
It looks like an annual topic, right to the day. |
01-22-2024, 4:26pm | #5 | |||||||
Should be my last one ever. |
01-22-2024, 4:28pm | #6 | ||||||
The Following 2 Users Say Thank You to Don Rickles For This Useful Post: |
01-22-2024, 4:50pm | #7 | ||||||
Gameroom Barn Bucks: $2173478
Replacing mine tomorrow.
I bought a new washer and drier, which seems to have broken the dip tube in my water heater so replacing that and figured i might as well do the anode while im in there |
01-22-2024, 4:56pm | #8 | ||||||
I prefer powered anodes because they don't typically need replacement. But one way or the other, you must deal with the sacrifical anodes in your water heaters or you'll get the results you got.
Go here for some education: https://waterheaterrescue.com/ |
The Following User Says Thank You to the new me For This Useful Post: |
01-22-2024, 5:02pm | #9 | ||||||
01-22-2024, 5:07pm | #10 | ||||||
01-22-2024, 5:08pm | #11 | ||||||
Barn Stall Owner #123
Gameroom Barn Bucks: $525
We're on a well that taps an underground spring (only 40' down!) so the water is really hard. So (of course), we have a water softener and we've found if the anode is in place in the water heater, the water really reeks of hydrogen sulfide.
So we don't run an anode at all. Gotta replace the water heater every 10 years or so however... |
The Following User Says Thank You to KenHorse For This Useful Post: |
01-22-2024, 5:10pm | #12 | |||||||
Its a 10 minute job unless the anode's threads are seized, then is a PITA.. |
01-22-2024, 5:15pm | #13 | ||||||
01-22-2024, 5:23pm | #14 | ||||||
I'd always heard that a powered anode is called a "dildo"
01-22-2024, 5:34pm | #15 | |||||||
There are different types of rods do some homework. |
01-22-2024, 5:35pm | #16 | ||||||
The Following 2 Users Say Thank You to KenHorse For This Useful Post: |
01-22-2024, 5:37pm | #17 | ||||||
01-22-2024, 6:58pm | #18 | ||||||
just replaced the heating rods and thermostats on an electric water heater at one of my rentals. The kit is $34 at home depot and has heating rods and thermostats.
As long as the tank is not leaking, I won't replace the water heater. I'll fix it. Spending $35 beats spending $500 on a new water heater. |
The Following User Says Thank You to GrandSportC3 For This Useful Post: |
