Old 02-21-2021, 5:33pm   #201
Aerovette
Barn Stall Owner #7734
Points: 106,278, Level: 100
Aerovette's Avatar
Originally Posted by LisaJohn View Post
Kinda like the runs on toilet paper. We’ve been without power several times for a week and managed. I didn’t like it but I had food, lp gas for the grill, portable generator. My only gripe is that we have an electric water heater.
I have a gas water heater....which makes zero difference when there's no water to heat.
The Following User Says Thank You to Aerovette For This Useful Post:
Old 02-21-2021, 5:35pm   #202
Aerovette
Aerovette's Avatar
Originally Posted by Raazor View Post
let the pipes thaw and the breaks reveal themselves!
Gonna be a busy next few weeks for those in the water biz
My break made its presence known before the thaw. Two neighbors had their water start flowing and mine didn't so I went to investigate.
A shattered elbow and Ice Ice Baby playing in my head.
The Following 2 Users Say Thank You to Aerovette For This Useful Post:
Old 02-21-2021, 5:41pm   #203
Points: 223,746, Level: 100
You could have hooked up a garden hose to the drain tap at the bottom of your water heater, opened it, then gravity fed the hot water in the tank to your shower.
Old 02-21-2021, 5:51pm   #204
Rodnok1
Points: 42,618, Level: 100
Activity: 52.2%
Rodnok1's Avatar
Waaaaay back when we had a 30 below cold snap. Laying in bed with 6 blankets and a dog and heard the pipes breaking one night. Always fun. There was an access panel in bedroom closet and that's where they were blowing out. Water froze almost immediately so wasn't bad to clean up. Luckily I had replaced almost all the piping couple years before or it would have been a nightmare to fix. They had been on outside walls, i moved everything out of outside walls, these were in an interior wall just an unheated closet unfortunately.
I moved the pipes into the closet and ran heat tape the next couple of days. Then I ****ing moved South.
Rodnok1 is offline   Reply With Quote
The Following 4 Users Say Thank You to Rodnok1 For This Useful Post:
Old 02-22-2021, 7:24am   #205
Mick
Points: 17,932, Level: 92
Activity: 42.4%
Mick's Avatar
Gameroom Barn Bucks: $12721
Originally Posted by TripleBlack View Post
You know, that's what I thought - and still do, but my son has friends in a neighborhood a few minutes north of me and some of their neighbors had cracked pools. I couldn't confirm but decided to go around the pool and break up the ice after I lost the pump. The ice was over 3 inches thick in places. It doesn't seem reasonable that the pool could crack, but homeowners policies here don't usually cover pool damage. Did this three consecutive days.
Our power was never off long enough for the equipment to freeze except I forgot that my pool sweep runs off a separate pump and is set to only run for a couple hours a day. When I set the pool to run continuously I didn't think about the sweep. I think I would have been fine had I thought to take 10 seconds to set that pump on continuous. When I discovered the burst PVC, I shut the pool down and drained the filter and pumps. The pool froze quickly after that. If the pump isn't busted, it should be an easy fix.
Attachment 53325
If your pool is shaped correctly, it should be very difficult for the ice to crack the pool. That said, what you did was a good idea.
Mick is offline   Reply With Quote
Old 02-22-2021, 10:48am   #206
TripleBlack
Barn Raising I
Points: 17,178, Level: 90
Activity: 3.2%
TripleBlack's Avatar
Gameroom Barn Bucks: $308343
Near 70 degrees yesterday and most of the ice is now gone. I can't see any visible cracks and the water level hasn't dropped so I don't think there was any major damage. It does look like some of the grout between the plaster and the tile has flaked off. I can probably repair that myself if required. Keeping fingers crossed hoping no pumps are destroyed.
TripleBlack is offline   Reply With Quote
The Following User Says Thank You to TripleBlack For This Useful Post:
Old 02-22-2021, 12:22pm   #207
Mick
Activity: 42.4%
Mick's Avatar
I envy your 70 degrees, it is snowing here again.
The Following 2 Users Say Thank You to Mick For This Useful Post:
Old 02-22-2021, 5:56pm   #208
MadInNc
Points: 195,184, Level: 100
Activity: 25.2%
MadInNc's Avatar
ICNLT
MadInNc is offline   Reply With Quote
The Following User Says Thank You to MadInNc For This Useful Post:
Old 02-22-2021, 6:53pm   #209
77 and sunny today. Had the air conditioning on when I drove. Also, I stopped at an Aldi's grocery along the way. They were almost fully stocked, however, they didn't have white mushrooms, only the 'baby Bella' kind.
The horror. The horror.
The Following 4 Users Say Thank You to Bill For This Useful Post:
Old 02-22-2021, 7:19pm   #210
ZipZap
Points: 64,157, Level: 100
Activity: 7.6%
ZipZap's Avatar
Originally Posted by snide View Post
I've got a 30k generator for sale.
Can you rate that in ice cream trucks?
ZipZap is offline   Reply With Quote
The Following User Says Thank You to ZipZap For This Useful Post:
Old 02-22-2021, 7:46pm   #211
ZipZap
Activity: 7.6%
ZipZap's Avatar
Originally Posted by VatorMan View Post
You couldn’t help it could you ? She’s helping for another photo op like her fake cages photo.
You will never change. BTW- your boy Joe, says blacks and Hispanics can’t use the internet. That’s not racist because it wasn’t Trump right ?
https://notthebee.com/article/this-2...zsSnN55Zv5pOqA
Just can't make this stuff up...
Old 02-22-2021, 7:57pm   #212
Giraffe (He/Him)
Goldilocks
Barn Stall Owner #905
Bantayan Kids '13,'15
Points: 110,810, Level: 100
Giraffe (He/Him)'s Avatar
Gameroom Barn Bucks: $1009320
Originally Posted by ZipZap View Post
Old 02-22-2021, 9:34pm   #213
snide
NCM Supporter '13
Points: 216,817, Level: 100
Activity: 53.6%
It will power 3 ice cream trucks.
Old 02-22-2021, 9:49pm   #214
LisaJohn
Barn Stall Owner #1000
1000th member
NCM Supporter '13
Points: 32,505, Level: 100
Activity: 11.5%
LisaJohn's Avatar
Gameroom Barn Bucks: $2425793
I have only been without water one time for a couple of days during an ice storm. The pipes froze. We just went next door to grandmothers and spent the night. I hope things get back to normal for y’all real soon!
LisaJohn is offline   Reply With Quote
Old 02-24-2021, 1:35am   #215
TripleBlack
Barn Raising I
Activity: 3.2%
Thing are looking up in North Texas. A week ago the high temp was 18. Today it was 81.
Old 02-24-2021, 8:59am   #216
Dan47
Barn Stall Owner #106
Points: 24,238, Level: 100
Activity: 10.4%
Dan47's Avatar
Dan47 is offline   Reply With Quote
The Following 2 Users Say Thank You to Dan47 For This Useful Post:
Old 02-24-2021, 1:44pm   #217
Mick
Activity: 42.4%
Mick's Avatar
Finally getting a break in NJ, 50 degrees outside right now. I opened the windows in my house to let some of the fart smell out, it was getting pretty thick in here.
Old 02-24-2021, 3:28pm   #218
JetMechZ16
Points: 46,956, Level: 100
Activity: 5.4%
JetMechZ16's Avatar
Gameroom Barn Bucks: $856744
Invest
Name:  fart filter.jpg
The Following User Says Thank You to JetMechZ16 For This Useful Post:
Old 02-27-2021, 7:45pm   #219
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,158, Level: 100
Activity: 9.4%
JRD77VET's Avatar
Just heard the EPA REJECTED Texas' request to exceed current pollution standards ONLY during the winter emergency and ****tard biden's pick denied it
Plus, if that ****tard obama wouldn't had gotten the coal fired electrical plants shut down, there wouldn't have been any lack of electricity
The Following 2 Users Say Thank You to JRD77VET For This Useful Post:
Old 02-27-2021, 8:57pm   #220
Points: 57,157, Level: 100
Activity: 61.5%
Texas is all about freeing themselves from Federal regulation, and you think you can blame a former president?
Texans have nobody to blame but themselves for this fiasco.
