06-07-2013, 4:08pm | #1 | ||||||
Barn Stall Owner #67
Tire pressure sensors......
Do they all have to be the same manufacturer, make and model etc.?
06-07-2013, 9:06pm | #2 | ||||||
Barn Stall Owner #1000
Gameroom Barn Bucks: $2425793
One of mine isn't working.
06-07-2013, 11:31pm | #3 | ||||||
06-08-2013, 10:41am | #4 | ||||||
Please let me know if it works. John and I were discussing if we needed to replace all 4 or only the one that isn't working.
06-10-2013, 12:50pm | #5 | ||||||
Each sensor is individually programmed to the car, not as a whole 4 piece unit. So long as it is compatible with the C5, you should be fine. Regardless of the manufacturer.
06-10-2013, 12:51pm | #6 | ||||||
06-10-2013, 3:32pm | #7 | ||||||
The sensor I bought did not fit, we discovered this when we cracked the rim. I found an exact match and have that on order now. Take the tire off your car and have your shop open it up that way you can order what's there.
06-10-2013, 3:47pm | #8 | ||||||
There are only 2 style sensors used on a C5, categorized by the year of car...
1997-2000 and 2001-2004 The early style sensors are larger and more expensive. This pic shows both styles...Early style on the left, late style on the right. Note it is possible to convert an early car to use the late model sensors by changing the RF receiver, which will also require using late model (01-04) keyfob remotes. |
06-10-2013, 8:16pm | #9 | ||||||
My 2004 is using the larger of the two sensors.
06-10-2013, 8:33pm | #10 | ||||||
06-10-2013, 11:04pm | #11 | ||||||
06-11-2013, 7:30am | #12 | ||||||
I bought mine for my C-5 through an on line tire co. save a good bit that way.
The Following User Says Thank You to Bucwheat For This Useful Post: |
06-14-2013, 11:01am | #13 | ||||||
God is it a pain in the ass to program a new sensor. All I can say is keep walking around your car and hope folks in white uniforms don't see you.
Edit. Make sure you have a very strong magnet. |
