Old 10-30-2009, 9:10pm   #1
zz4vetteguy
Points: 19,739, Level: 97
zz4vetteguy's Avatar
Gameroom Barn Bucks: $9916
Default Do kids not appreciate anything anymore?
I dropped one of our work trucks off at our mechanic yesterday and he had a brand new still had 30 day tags Honda Civic up on the lift with the tranny torn out. As I walked up I saw the works turbo in chrome on the side and just knew this story was going to be good....so I asked.
He told me it was a young kid, 20 at most he thinks, he was racing, was running the car at 158 mph, & tore the hell out of the tranny and the clutch...well, the clutch was just no more. He said he was going back and forth with the Honda dealer trying to get info on what the car had because he is not that up on all the different "trim levels" that the foreign cars have for all the models, and the first thing he did was call the dealer. Honda told him there was no turbo Civic, so he said he would call them back and check it out. Popped the hood and it was a little 4 banger, and a turbo was of course no where to be found. He had someone from Honda come over and hook it up the the big brother reader and found out that the car had been run at 10K RPMs for 6.3 second...yes the little 4 cylinder had been run at 10 THOUSAND rpms for over 6 seconds.
Our mechanic know a little about speed, since he built and races his own top fuel dragster, so he and I had a good laugh about the story and I am still wondering how he did not blow his engine.
But I mean do kids today just really not appreciate things. I loved my Z28, and my C4, and love my C5, and I did/do drive them pretty hard, but that was just plain abuse...10K for over 6 seconds? On a brand new car to boot.
Street Dreams Corvette Club
Old 10-30-2009, 9:17pm   #2
Neutron
Moderator
Points: 5,764, Level: 52
Neutron's Avatar
Gameroom Barn Bucks: $1297
No rev limiter?
Edit: Must've been an ill-advised downshift..
Neutron is offline   Reply With Quote
Old 10-30-2009, 9:49pm   #3
Points: 35,076, Level: 100
10k might sound outrageous...but a 2010 Civic SI makes peak power at 7800, and redlines at 8000.
So he downshifted wrong and popped the clutch...FWD car, yeah that has the power to wreck some stuff (front wheels won't lock up quite as easily pulling that maneuver).
Old 10-30-2009, 9:52pm   #4
jeff w
Barn Stall Owner #40
Points: 7,555, Level: 61
jeff w's Avatar
Gameroom Barn Bucks: $32212
I call BS on that civic doing 158 mph
jeff w is offline   Reply With Quote
Old 10-30-2009, 10:12pm   #5
We have some really big hills around here.
Old 10-30-2009, 10:20pm   #6
Neutron
Moderator
Neutron's Avatar
You'd need some really big cliffs.
Old 10-30-2009, 10:24pm   #7
jeff w
jeff w's Avatar
IDK if a civic can break 150mph at terminal velocity
Old 10-30-2009, 10:26pm   #8
Neutron
Moderator
Neutron's Avatar
Hmmm.. What's the terminal velocity of a falling car? I thought it was like 180mph...
Old 10-30-2009, 10:28pm   #9
jeff w
jeff w's Avatar
stop trying to ruin my jokes
Old 10-30-2009, 10:29pm   #10
Neutron
Moderator
Neutron's Avatar
I was serious.
Old 10-30-2009, 10:47pm   #11
jeff w
jeff w's Avatar
I was serious.
If this makes any sense
Actually, since the car gets a head start we can infer that the car at most is traveling its maximum speed(2006 Lexus IS350 is 142mph). Therefore the car is at most traveling 208 ft/sec. It would take the car on the ground 19.231 seconds to travel the 4000 feet(1219.2 meters).
When we look at the fallign car, we can disregard air friction and say that the falling car accelerates at 9.81 m/s^2 or 32.19 ft/s^2. From the equation: x=1/2at^2 we can conclude that the car will take 15.765 seconds to travel the 1219.2 meters(4000 feet). However, air friction will give the car a terminal velocity. Without the terminal velocity, we can figure that the car was traveling 507.475 ft/sec or 346.006 mph. It is obvious that the falling car will be fatser. But lets not overlook terminal velocity.
Terminal velocity can be calculated using the equation:
V = sqrt ( (2 * W) / (Cd * r * A)
v=terminal velocity
W=weight in Newtons
Cd=Drag Coefficeint
r=atmospheric density
a=area exposed to air(area facing down)
Furthermore, we find terminal velocity by detwermining our variables. The weight of the 2006 Lexus IS350 is 3,435 lbs. The atmospheric density is a main determining factor, and since the density is decreased by higher temperatures, for the fact of covering margins, lets say the experiment was done at 80 degrees F. This would make the atmospheric density 1.184. Again, for the sake of covering margins, lets say the car fell with its botom facing downward, its surface area of exposure would be equal to the factory dimensions of 180 inches by 70.9 inches, or 88.625 square feet. Lastly, the drag coefficient must be calculated. First, take into account that the drag coefficient of a falling cube is 0.8. this is roughly the shape of the falling car. Also, consider the drag resistence of the front of a lexus IS350(the drag coefficient if the car was falling head first) is very close to 0.3. Once again, for the sake of covering margins, lets use a coefficient of 0.6. After calculating, you will come up with a table looking like this:
altitude terminal velocity
3000 ft 243.795 ft/s
2000 ft 240.198 ft/s
1000 ft 236.679 ft/s
0 ft 233.235 ft/s
Since we will not reach terminal velocity until an altitude of 3000 feet(fallign for 1000 feet), we can disregard the 4000 ft mark. We can then take the average terminal velocity from 3000 ft to 0 ft, about 238.515 ft/s. To cover margins, lets use 240 ft/s.
Therefore, we can use the equation velocity=acceleration*time. We find that we reach terminal velocity(240 ft/s) using the acceleration of gravity of 32.19 ft/s^2 after 7.456 seconds. We then use the equation distance=1/2*acceleration*time^2 and find that the car had traveled 894.688 feet when it reached terminal velocity.
Using this information, since the car had traveled 894.688 feet in 7.456 seconds, and since the car is now traveling 240 ft/sec for the remainder of its trip, we conclude that the car will take an additional 12.939 seconds to travel the remaining 3105.312 feet.(dist/veloc=time, (4000-894.688)/240=12.939)
Through addition we find that the car will take about 20.395 seconds to hit the ground.
Therefore, we see that(with our margins covered for variations) when we take air resistence into account and factor in a terminal velocity, a Lexus IS350 on the ground takes 19.231 seconds to travel 4000 feet. And as the commercial demonstrates, a Lexus IS350 takes about 20.395 seconds to reach the ground and travel its distance. Illustrating how the Lexus on the ground can, in fact, travel 4000 feet quicker than gravity can accelerate the same car 4000 feet to the ground.
These statistics(weight, surface area, Cd) are based on the 2006 Lexus IS350 manual transmission. Also, I over estimated many of my values, such as the temperature and the Cd of the Lexus. If they were to conduct the experiment at lets say 30 degrees F, the time the car would take to reach the ground would increase by about 1 second. Also, lets say the Cd of the car was infact close to one of a cube, the terminal velocity of the car would be an average of about 205 ft/sec. This would actually increase the time of the falling car by about 2.301 seconds from 20.395 seconds to 22.696 seconds.
As you can see, the demonstration done in the commercial is completely plausible as long as the Lexus on the ground starts from near its maximum speed.
However, if the Lexus did not start from near 140 mph, it would never be able to compete with gravity. Just to compare this car with the Ferrari 333 Sp. This car can accelerate from 0-60 in 3.8 seconds. The Lexus IS350, 5.6 seconds. Just for a fact, the Ferrari 333 SP is a modified race car, not stock. Based on this, and the fact that the Faerrari 333 SP can accelerate at an average of about 20 ft/sec over a quarter mile and gravity, 32.19 ft/sec demonstrates that the Ferrari 333 cannot conquer the feat of starting from a stop, let alone the Lexus IS350.
The Lexus IS Started near its maximum speed, and was therefore able to beat gravity, as the commercial demonstrated.
Old 10-31-2009, 6:21am   #12
How are we supposed to believe someone who says "fallign" and "Furthermore, we find terminal velocity by detwermining our variables"?
Old 10-31-2009, 9:38am   #13
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
