01-19-2024, 11:04am | #1 | ||||||
Gameroom Barn Bucks: $2173478
Heated Spigot Covers
Having survived the last hard freeze and another coming tonight. My two outdoor spigots that I cannot shut off froze during the last freeze, I was able to thaw them several times before any damage was done.
I've searched and searched but I don't see any pre-made plug in style heated Faucet covers. Does anybody make one? I'm sure I can make my own, but most of the heat tapes require direct contact with the plumbing, which means installing and uninstalling will be a pain in the ass. Before I go build a big ass box that has 10 feet of heat tape zig zagging inside of it, I wanted to see if y'all have any recommendations/ experience? These two faucets will require cutting drywall inside my house if I wanted to add a cut off and drain, so I'd like to avoid that if I can. |
01-19-2024, 11:06am | #2 | ||||||
Go buy cheap heating pads. make sure it does not have auto shut off.
https://www.dollargeneral.com/p/cona...E&gclsrc=aw.ds |
01-19-2024, 11:17am | #3 | ||||||
Barn Stall Owner #116
Doesn't have a big thing
Yet another reason FLORIDA is the best!!
01-19-2024, 11:24am | #4 | ||||||
Buy hand warmers (the little disposable ones) for a couple of bucks and put one inside of faucet covers.
01-19-2024, 11:26am | #5 | ||||||
I used the black pipe insulation, and then used a larger diameter of pipe insulation wrap over that, then wrapped old rags around the spigot and horizontal line going into the house
I wrapped all that in an old comforter, then covered the whole thing with a thick contractor garbage bag to keep it dry and out of the wind. Aero used the heat tape, under the pipe wrap, which also seems like a good idea. And now that you know where your weak points are, run those adjacent inside taps periodically through the night. I suspect that's a lot easier than going outside with a hair dryer or heat gun to thaw the exterior piping. |
01-19-2024, 11:26am | #6 | ||||||
Surely there's exposed pipe somewhere far enough upstream to stick in a valve
01-19-2024, 11:28am | #7 | ||||||
Barn Stall Owner #105
I leave my outside faucets running during the arctic blast. Otherwise, the cover is on. I would think you could use heat cable inside the cover if running the water is not an option.
The only other thing I can think of would be to install an antifreeze spigot, but that also takes getting inside the wall. |
01-19-2024, 11:30am | #8 | ||||||
Never leave your hose hooked up it can back freeze.
01-19-2024, 11:33am | #9 | |||||||
Thus our solutions of heavily insulating it, and heating it. I wouldn't want to cut open sheetrock to install cut off valves, either. It would be easier to simply turn off the water and drain the pipes, but that's not really an option for a family with young kids to be without water. |
01-19-2024, 11:34am | #10 | ||||||
How about combining this...
https://www.amazon.com/lollyes-Outdo...4465e04e148fe6 With this... https://www.amazon.com/marinexplore-...96&sr=1-8&th=1 |
01-19-2024, 11:35am | #11 | ||||||
But it's not a tough job of cutting and patching drywall, you would just cut out the drywall but then slap on an access panel, no patching involved. Stupid simple unless you're simple and stupid.
01-19-2024, 11:36am | #12 | |||||||
Gameroom Barn Bucks: $2115673
When working I have installed a few dozen of those outside rated spigots! |
01-19-2024, 11:45am | #13 | ||||||
ICNLT
01-19-2024, 11:59am | #14 | ||||||
Gameroom Barn Bucks: $530
I have a similar situation. I been thinking of this.
https://www.amazon.com/9FT-Protectio...7&sr=8-13&th=1 |
The Following User Says Thank You to Jughead For This Useful Post: |
01-19-2024, 12:04pm | #15 | ||||||
01-19-2024, 1:37pm | #16 | |||||||
01-19-2024, 1:40pm | #17 | ||||||
Yes stupid and simple if you don't care about how it looks. One of these is in the laundry room the other my office. Both places we're likely installing built in's. I will make an access panel work if it's my last resort. But we get 1 or 2 hard freezes a year, I think there's likely a simpler solution here. I'm just surprised there isn't one sold.
01-19-2024, 1:48pm | #18 | |||||||
I used to have a covered well pit that held the pump and pressure tank. During the coldest months I left a light bulb on next to the pump, never had a freezing problem. |
01-19-2024, 1:51pm | #19 | ||||||
I wrap 1/2 string of incandescent mini Christmas lights around the spigot and exposed pipe, then put the cover over it or wrap it in a towel. Bonus is it is easy to see if it is working. I always wonder if the wire heaters are working.
During the 2021 snowstorm, we were below freezing for 100 hours or more going as low as 6*. I pushed a kitchen thermometer between the stone and cover's foam and consistently got 65-70*. |
01-19-2024, 1:51pm | #20 | ||||||
For ten bucks, I'd buy one and plug it in on the garage floor and see if it warms or burns up. It does not give a range, but says it is thermostat controlled. I image that without water, it would just cycle more often because it reaches temp sooner.
