01-25-2023, 3:29pm | #41 | |||||||
Sling offers FNC with their 'Blue' package and the News Extra option for some of the business channels. I think that brings the total to about $46 monthly. |
01-25-2023, 3:43pm | #42 | ||||||
Barn Stall Owner #0331
I've had a 2 element bowtie type coaxial antenna for about 15 years now. When I first used it I received about a dozen channels. I rescanned available channels yesterday and have about 49, many which appear to be OK programming.
01-25-2023, 8:33pm | #43 |
Gameroom Barn Bucks: $555
So you hooked up an outdoor antenna to the existing Dish coax? How did it work? That's a perfect solution. I was only going for an indoor antenna so I wouldnt have to run coax/cable thru a wall... Using the existing cable from the dish is a no brainer if it in fact works...
01-25-2023, 8:46pm | #44 | ||||||
Works perfectly it is what you run now. And if you get the tablo you can go wireless from there. Mine supports 4 TV's wireless with guide and dvr.
01-25-2023, 9:35pm | #45 | ||||||
Barn Stall Owner #111
Gameroom Barn Bucks: $5547
Yes you can. I installed an antenna and ran a cable from the antenna to my previous cable input. Depending on how many splits you have, you may need to add a power booster to get all the channels at some of the TV's. I am feeding 7 TV's off mine with about 50 channels on each. A lot are junk, but we get all the networks, and streaming services cover the gap.
01-25-2023, 9:52pm | #46 | |||||||
If your home has Coax ran through it, use it. Need to inject signal at source and if need be, place Amp in cable run. A smart TV will tell ya the signal power (in home wiring with or without Amp) and “quality” or received signal strength |
01-25-2023, 10:11pm | #47 | ||||||
01-26-2023, 8:15am | #48 | |||||||
That really is a must, especially if you have a long coax cable run. I have an antenna in the attic and and the pre-amp sends the signal to a splitter in the basement, which distributes it to the first floor, basement and outside. Good overall signal strength for half a dozen TV's. |
01-26-2023, 10:08am | #49 | |||||||
It doesn't matter what's being carried on this signal be it analog (old days) or digital (today) if the antenna is capable of receiving these frequencies they will. Of course you do need a tuner in the TV or a set-top tuner box. |
01-26-2023, 10:34am | #50 | |||||||
01-27-2023, 8:05am | #51 | ||||||
Actually the carrier wave frequencies didn't change just the data carried changed from analog to digital data. That is why you needed a set top box when the data went digital because an analog tuner won't know what to do with a digital signal.
01-27-2023, 8:02pm | #52 | ||||||
UPDATE?????????
Did OP ever get any OTA channels? Don't leave us hanging!!!!!!! |
01-27-2023, 8:12pm | #53 | ||||||
Better send help he got on the roof and knocked the ladder over.
01-28-2023, 9:55am | #54 | |
01-28-2023, 10:07am | #55 | |
This website works well for finding which direction is best to point your antenna https://www.antennasdirect.com/transmitter-locator.html At best the farthest signal you should get is about 40Km (30 miles or so). |
01-28-2023, 10:22am | #56 | ||||||
You don't need any paid subscription there are too many free ones out there. Explore those first you can always add later if you still want to throw your money away.
