Old 10-30-2009, 10:51am   #1
nedih rotaredom
Sophisticated PITA CM
Points: 2,433, Level: 31
nedih rotaredom's Avatar
Gameroom Barn Bucks: $837
Default FS: 1968 plain jane Camaro coupe parted out
Here is a copy of the 1968 Camaro Parts I have for sale.
The price to the right is my selling price + actual shipping cost.
The (*) means that the part has been sandblasted and primed.
The ( ) means that the part is Gold colored.
If you have any questions, post here or PM me.
I have a simple policy, If you do not like what you buy, once I receive it back in the same condition I sent it, you get your money back. Life member of the NCM #1409
You can check out my Website as well....I have been around a while
My Website with some pictures of the parts;
My Corvette Web Site
Corvette photos | Corvette pics - Misc 68/71 parts - Powered by PhotoPost
Brackets & Sheet Metal
*Hood Hinge Driver Side $50.00
*Hood Hinge Springs (2) L & (2) R $5.00 ea.
Headlight Retainer (Stainless) $5.00
*Upper Hoodlock hood saftey latch assembly $15.00
*Standard Hood $90.00
Standard Hood Blue w/minor dent $80.00
Standard Hood British Green $100.00
*Hoodlock Catch Latch Support Bracket $20.00
*Lower Hood lock latch assy. $50.00
*Front Bumper Outer Bracket Driver Side $15.00
Roof Drip Pillar Post Molding L&R $15.00 pr
*Shock/Rear Spring Mount Brackets L&R $50.00 ea.
"AR" stamped on DS Cable Holders, "MC" stamped on PS
Cable Holders "E"
*Shock/Rear Spring Mount Brackets LH&RH “1” stamped on top.
-----------------------With some small cracks, need weld $35.00 ea.
*Brake Hose Brackets (2) $2.00 ea.
*Fender to Skirt Bracket (passenger side) $10.00
*Hood Lock Catch Support $25.00
327 cid Swaybar Assembly 11/16" $50.00
Outside Door Handle to Door Skin Gaskets (1) 1.00 ea.
Hood to Fender Rubber Block Stoppers 2.00 ea.
*Front Inner Fenderwell to Fender Washers (4) 2.00 ea.
*Fuel Pump Mounting Plate $2.00
*Front Bumper Mounting Steel Base Plate (1) $2.00
*Frame to Body Bushing Bolts & Washers (4) $2.00 ea.
Carb Manual Choke Rod Bracket $1.00
Emblems
Used GM OEM 1967 Std Camaro Grill Emblem, 3893819 $15.00
Used GM OEM "Camaro" Fender Emblems (2), 3916660 $15.00 ea.
Used GM OEM GM "302" Front Fender Emblem, 3927481 $15.00
Glass Parts
*Windshield Washer Nozzles $10.00 pr
Pass. Mirror (Broken at pivot ball only) $10.00
Rear Side Panel Steel, Upper Reinforcing Molding/
Window Felt Area L&R $50.00
Door Molding/Window Felt Steel Panels L&R $40.00
*Std. Mirror to Door Bracket $2.00
*Windshield Washer Jar Bracket $5.00
Windshield Washer Pump & Motor $60.00
Driver & Passenger Side Door Window Regulator $ 60.00 ea.
Driver & Passenger Side Door Glass( WITH 2 BOLTS & NUT MOUNTS) $60.00 ea. Wording on glass is: SAFETY, LOF, FLO-LITE, AS-2, XX, solid tempered, M71.
DS & PS Side 1/4 Window Regulator $45.00
DS & PS 1/4 Window Vertical Guide Brackets $25.00
Driver & Passenger Side Door Window Glass Brackets $50.00 ea.
Rear Glass $75.00
DS & PS Side 1/4 Window Glass Sash Assy. ( all that bolts to glass) $20.00 ea.
Front Windshield Lower Molding to Body Clips (5) $1.00 ea.
Window Centering Brackets for Doors (4 side) (2 top) $3.00 ea.
Inside Chrome/Aluminum/Stainless
Std. Inside Door Handles L&R $10.00 ea.
Door Sill Plates L&R $10.00 pr
Std. Front Door Panel Molding L&R $20.00 ea.
Std. Front Door Panel "Camaro" Emblems $7.00 ea.
Dash Vent Chrome Bezels (L&R) $15.00 ea.
Round Vent Chrome Balls (L&R) $15.00 ea.
Interior Door Lock Chrome Knob $3.00
Front Seat Track Chrome Adjustment Knob $3.00
Chrome Flasher Actuating Button $5.00
Console Rear Light Aluminum Reflector Bracket $3.00
Interior Parts
Headliner Reinforcement Bars $25.00
Std. Door Panel Cardboard Backing $20.00
Sun Visor w/Supports L&R $40.00 ea.( Excellent Shape)
Outside Air to Vent Intakes L&R $20.00 ea.
Black Console Compartment Lid w/o Hinge $7.00
*Inside to Outside Park Brake Cable 25.00
Window Handle Plastic Washer Springs (1 short) $1.00
Door Lock Cylinder Retaining Clips (2) $1.00 ea.
Interior Window Handle Plastic Backing Washers (2) $1.00 ea.
Driver Side Inner Door Latch Assembly $40.00
Door Lock Striker Plate w/Bracket $10.00
Exterior Chrome/Aluminum/Stainless
Door Edge Guards L&R $5.00 pr
Front Bumper (dings/bent) shiny $35.00
Outside Door Handles Assembly (1DS & 2PS) $10.00 ea.
Std. Grille Parking Light (Lens, Bezel, Gasket) $10.00
Oil Level Tube & Stick $5.00
Stainless Drip Pillar to Top Stainless Filler L&R $3.00 ea.
Mechanical Parts
Std. Sidemarker Lenses (2) $2.00 ea.
Std. Sidemarker Lenses Housings (2) $5.00 ea.
Gas Tank Rubber Filler Neck $10.00
*Blower Motor w/Housing w/o air $70.00
Q-Jet 4 BBL (needs rebuild) #70282249CC $80.00
*327 cid w/ Powerglide Driveshaft Yoke for Trans $45.00
327-275 HP w/ Powerglide Dist. #1111297 8F11 $25.00
Gas Tank to Front Fuel Line 3/8", $35.00
12 bolt/10 bolt rear end brake line assy, DS/PS for each, $5.00 ea.
327-275 HP w/Powerglide Dist. #1111297 8C20 $25.00
327-275 HP Choke Kit Assemblies for Q-Jet (2) $10.00 ea.
10 Bolt 3:08 Ring & Pinion Gear $75.00
10 Bolt Axle Assembly 2:73 Ratios BPO 711 G2 &
BPO 325 G2 Non-Posi 200.00 ea.
Multi leaf spring mounting pad set, 4 new polyurethane $12.00
Front Leaf spring press in rubber bushings, 2 new $18
8pcs poly rear leaf mounting bushing set w/ collars. New $35.00
Original front leaf spring mounting fastener assys. $5.00 ea.(2 pcs.)
Multi leaf u-bolts $5.00 ea.
Front Brake Line for Drum Brakes $25.00
*327 cid Stock Steel Fans (2) $10.00 ea.
*327 cid Stock Steel Timing Chain Cover (Chevy Orange Paint) $7.00
*327 cid Water Pump Pulley #3905995CF (Black Paint) $40.00
*Rear Park Brake Cable Assembly $10.00
*Park Brake Guide Bar $15.00
Multi-leaf Spring Perch Rubber Pads (4) $2.00 ea.
*Carb Return Spring (2) $4.00 ea.
Trunk Lock Assembly w/o Lock $15.00
Dual Exhaust (2" dia. over rear axle and exits in stock location $30.00 ea. from back of muffler on back to exit. Pipe only.)
LH/RH Front Brake Assy. w/ Spindles (drum) $50.00 ea.
Front Coil Springs LH/RH $40.00 ea.
Front Upper A-arms LH/RH $40.00 ea.
Front Lower A-arms LH/RH $40.00 ea.
Tie Rods LH/RH $10.00 ea.
Center Linkage $30.00
Idler Arm $10.00
Wiring Harnesses
Dash Wiring Harness $200.00 (white tag "5062" AL)
Fuel Tank Wiring Harness $10.00 (between light & main wire)
Trunk Light Wiring Harness $10.00
