Old 01-05-2021, 7:21pm   #1
DAB
Barn Stall Owner #4
Points: 172,146, Level: 100
Activity: 9.4%
DAB's Avatar
Default [Woodworking] Reloading Bench
just made this today for a shooting buddy of mine.
36" tall, 30" wide, 25" deep.
top is 3/4 plywood with laminate (fancy!), supported by a 4x4 in front, 2x4s on the sides and back. legs are 4x4, half lapped into the top supports. lower shelf is 12" above ground, simple piece of 3/4 plywood supported by 2x4s on edge.
he intends to either stand or sit on a stool when using it, so the height is set for that.
second pic is my reloading bench that is designed for sitting at.
(well, no luck loading pics, try again in a bit.)
DAB is offline   Reply With Quote
The Following 4 Users Say Thank You to DAB For This Useful Post:
Old 01-05-2021, 8:09pm   #2
markids77
Points: 22,591, Level: 100
Activity: 10.8%
markids77's Avatar
Dillon press... your bud intends to crank out some serious round counts!
And both benches are quite nice.
Old 01-05-2021, 8:18pm   #3
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,158, Level: 100
Activity: 9.4%
JRD77VET's Avatar
Both are nice benches. The smaller one may need some "ballast" on the bottom shelf or bolted to a wall depending on how much leverage is needed.
Old 01-06-2021, 8:56am   #4
LisaJohn
Barn Stall Owner #1000
1000th member
NCM Supporter '13
Points: 32,494, Level: 100
Activity: 11.5%
LisaJohn's Avatar
Gameroom Barn Bucks: $2425793
Well I’m out of the loop. My guys have already started building. I’ll try to get a pic later.
LisaJohn is offline   Reply With Quote
The Following User Says Thank You to LisaJohn For This Useful Post:
Old 01-06-2021, 10:46am   #5
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
couldn't wait?
this took about 3 hours to build. wasn't rushing, just a nice steady pace, with time for me and my shooting buddy to talk, both about what i was doing and other matters.
well, there's the design. easy to adjust the overall dimensions to suit.
Old 01-06-2021, 11:37am   #6
LisaJohn
1000th member
NCM Supporter '13
Activity: 11.5%
LisaJohn's Avatar
36 tall, 28x72 and it’s in J’s shop because neither son has a shop.
The Following 2 Users Say Thank You to LisaJohn For This Useful Post:
Old 01-06-2021, 11:40am   #7
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
looks like a hollow core door for the top? they might need to add a 4x4 on the front edge to support the torque of the press later. can be quite significant, and it's really annoying when your press is wiggly. failing that, double stacked 2x4s would also work.
The Following 2 Users Say Thank You to DAB For This Useful Post:
Old 01-06-2021, 11:44am   #8
LisaJohn
1000th member
NCM Supporter '13
Activity: 11.5%
LisaJohn's Avatar
I know it’s not a door. I’ll pass along your suggestions. I know they will appreciate the input. A wiggly press does sound annoying.
Thank you!
Old 01-06-2021, 8:48pm   #9
markids77
Activity: 10.8%
markids77's Avatar
Ask them to screw it to whatever wall they put it up against. It lacks a bit in the "robustness" category.
The Following User Says Thank You to markids77 For This Useful Post:
Old 01-06-2021, 9:18pm   #10
LisaJohn
1000th member
NCM Supporter '13
Activity: 11.5%
LisaJohn's Avatar
I think that’s their plan when it’s moved out of J’s shop. It’s not finished.
Old 01-07-2021, 4:29am   #11
itsaz
Barn Raising I
Points: 12,028, Level: 75
itsaz's Avatar
Gameroom Barn Bucks: $1729
Where would one find small pistol primers these days?
itsaz is offline   Reply With Quote
Old 01-07-2021, 7:11am   #12
86RAG
Points: 23,062, Level: 100
86RAG's Avatar
Nowhere I can find! I still have plenty for now, but wouldn't mind beefing up the inventory
86RAG is online now   Reply With Quote
Old 01-07-2021, 8:43am   #13
Mr Hole
That's MR Hole To You
Points: 11,906, Level: 75
Mr Hole's Avatar
Gameroom Barn Bucks: $3067
Here's mine.
Mr Hole is offline   Reply With Quote
The Following 4 Users Say Thank You to Mr Hole For This Useful Post:
