Old 04-20-2011, 8:55pm   #1
Default Fluid capacities
Anyone have the fluid capacities for the A4 tranny, and the rear differential? Thanks!
Old 04-21-2011, 9:25am   #2
allthrottleandsomebottle
Points: 23,599, Level: 100
Gameroom Barn Bucks: $1005893
Owner's Manual for a C5...........close enough
Capacities and Specifications
The following approximate capacities are given in
English and metric conversions.
Please refer to “Recommended Fluids and Lubricants”
in the Index for more information.
Air Conditioning . . . See the refrigerant information
label under the hood.
Automatic Transmission
Drain and Refill . . . . . . . . . . . . . . 5.0 quarts (4.7 L)
Overhaul . . . . . . . . . . . . . . . . . 10.8 quarts (10.2 L)
Cooling System . . . . . . . . . . . . . . 12.6 quarts (11.9 L)
Crankcase
With Filter Change . . . . . . . . . . . 6.5 quarts (6.1 L)
Fuel Tank . . . . . . . . . . . . . . . . . 18.5 gallons (70.0 L)
Manual Transmission
(Overhaul) . . . . . . . . . . . . . . . . . 4.1 quarts (3.8 L)
Rear Axle
Lubricant . . . . . . . . . . . . . . . . . . 1.69 quarts (1.6 L)
Limited Slip Additive . . . . . . . . . 4 ounces (118 ml)
Tire Pressures . . . . . . See Tire-Loading Information
label on rear edge of driver’s door.
Wheel Nut Torque . . . . . . . . . . 100 lb-ft (140 N·m)
All capacities are approximate. When adding, be sure to
fill to the appropriate level, as recommended in this
manual. Recheck fluid level after filling.
Engine Specifications
Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.7L V8
VIN Engine Code . . . . . . . . . . . . . . . . . . . . . . . . . . G
Displacement . . . . . . . . . 346 cubic inches (5665 cc)
Fuel Delivery . . . . . . . . . . . . . Sequential Multi-Port
Fuel Injection (SFI)
Valve Arrangement . . . . . . . . . . . . . Overhead Valve
Piston Displacement . . . . . . . . . . . . . . . . . . . . . . 5.7L
Bore . . . . . . . . . . . . . . . . . . . . . . 3.90 inches (9.9 cm)
Stroke . . . . . . . . . . . . . . . . . . . . 3.62 inches (9.2 cm)
Compression Ratio . . . . . . . . . . . . . . . . . . . . 10.1:1
Horsepower . . . . . . . . . . . . . . . . . . . . . . . 345 @ 5600
Torque . . . . . . . . . . . . . . . . . . . . . . . . . . . 350 @ 4400
Firing Order . . . . . . . . . . . . . . . . . . 1-8-7-2-6-5-4-3
Thermostat Starts to Open 187F (86. . . . . . . . C)
Old 04-21-2011, 10:15am   #3
I just did my a4 filter and used 5 quarts like Steve posted above. If that's what you are doing get your filter and gasket from Napa, they have the nice neoprene gasket. I also got a cheap fluid pump off Amazon to put the fluid back in that worked great. I also reccomend having a few new pan bolts on hand in case any of the old ones had been over torqued and flipped the washer.
Old 04-22-2011, 10:15am   #4
Thanks boys!
