Share Thread Tools
Old 03-06-2020, 11:10am   #1
Stevedore
Points: 9,457, Level: 67
Activity: 2.3%
Stevedore's Avatar
Gameroom Barn Bucks: $405993
Default Septic Tank Cleaning Cost?
We've been in our current house for 3 years. It has a septic system; I never owned one before.
When we bought the house, the previous owner had it pumped out a few days prior; our inspector said it all looked OK, & recommended having it pumped out again in 3 years.
It's a 1250 gallon solids tank, followed by a 1000 gallon liquid tank with a pump to the field.
I'm assuming that they only pump out the solids tank. (Amiright?) Question for anyone with a septic system is what do you typically pay to have it pumped out?
Stevedore is offline   Reply With Quote
Old 03-06-2020, 11:12am   #2
DAB
Barn Stall Owner #4
NCM Supporter '13,'14,'15,'16,'17
Points: 136,409, Level: 100
Activity: 32.9%
DAB's Avatar
Gameroom Barn Bucks: $18001872
we do ours every 2 years. about $300 each time.
DAB is offline   Reply With Quote
The Following User Says Thank You to DAB For This Useful Post:
Old 03-06-2020, 11:17am   #3
z06psi
Barn Stall Owner #∞
Points: 14,621, Level: 83
z06psi's Avatar
Gameroom Barn Bucks: $30146
I would suggest it to be pumped every month if Felx is cooking for you.
z06psi is offline   Reply With Quote
Old 03-06-2020, 11:18am   #4
Mr.Bigg
Banned
Points: 970, Level: 17
Activity: 46.7%
Mr.Bigg's Avatar
Gameroom Barn Bucks: $1440
Pump it all and make sure they rinse it clean. Mine is a bit bigger and cost $300 last time. If you put a aerator in your solid tank and use minimal good tp you may never have to pump it. Never use rid x.
Mr.Bigg is offline   Reply With Quote
Old 03-06-2020, 11:27am   #5
JetMechZ16
Points: 29,364, Level: 100
Activity: 60.0%
JetMechZ16's Avatar
Gameroom Barn Bucks: $855686
Had my house built in 2003 4 bedroom 4 bath 3500 sq ft. We have not had the septic system pumped yet. After reading up on it I think I better get on that.
The national average cost to clean and pump a septic tank is between $295 and $610 with most people spending around $375. Depending on the size of your septic tank, pumping could cost as low as $250 for a 750-gallon tank, or as high as $895 for a 1,250-gallon tank. Get free estimates from septic professionals near you.
Old 03-06-2020, 11:29am   #6
BOTY
Points: 24,222, Level: 100
Activity: 41.4%
BOTY's Avatar
Gameroom Barn Bucks: $15017818
You definitely want to call the guy for this one.
BOTY is offline   Reply With Quote
The Following User Says Thank You to BOTY For This Useful Post:
Old 03-06-2020, 11:34am   #7
6spdC6
Points: 14,027, Level: 81
Activity: 7.0%
6spdC6's Avatar
Gameroom Barn Bucks: $2115402
Get ours done every 3 years at a cost of $250. I have to do the digging to expose the cover. Takes about 20 minutes as top of tank is only 9'' deep.
6spdC6 is offline   Reply With Quote
Old 03-06-2020, 11:47am   #8
Rodnok1
Points: 7,275, Level: 59
Activity: 88.7%
Rodnok1's Avatar
Gameroom Barn Bucks: $312807
If they have to dig to get to it thy charge more. I dug the hole and knocked a clean out hole in the corner. Put a PVC riser in at ground level. Cost was 250 few years back, guy said it wasn't due and it had probably been 10 years easy since cleaned out.
Rodnok1 is offline   Reply With Quote
Old 03-06-2020, 12:04pm   #9
Egnalf
Points: 6,223, Level: 54
Activity: 11.7%
Egnalf's Avatar
Gameroom Barn Bucks: $17892
Average human ( not flex) produces about 325 pounds of pooh per year. One gallon of pooh is roughly 8 pounds depending upon moisture content. Some of that goes away as moisture. So, assume 275 pounds per human per year if your stool is really, really dense. Fill it halfway, or 625 gallons, that is 5000 pounds. How many humans in that house to fill it that much in three years?
3years x 275=825. Even if you have six, hard pooping mofos, that tank isn't full.
Egnalf is offline   Reply With Quote
Old 03-06-2020, 12:13pm   #10
Jeff '79
Barn Stall Owner #2112
Fantasy Football Champ '14,'16
Points: 132,598, Level: 100
Activity: 99.5%
Jeff '79's Avatar
Gameroom Barn Bucks: $3042752
I did mine every 6 years.
I dug the covers up myself and was charged $425.00.
That is WNY prices, (Buffalo Suburb).
Jeff '79 is offline   Reply With Quote
The Following User Says Thank You to Jeff '79 For This Useful Post:
Old 03-06-2020, 12:25pm   #11
MadInNc
Points: 57,059, Level: 100
MadInNc's Avatar
Gameroom Barn Bucks: $107346
Have a three tank system. All tanks pumped and rinsed for ~$300 last year
MadInNc is offline   Reply With Quote
Old 03-06-2020, 12:59pm   #12
snide
Potnonomicaphobe
NCM Supporter '13
Points: 99,598, Level: 100
Activity: 99.4%
Gameroom Barn Bucks: $109031731
I bought my house in NH in 2007. New construction. When I sold the house two years ago, I had to have it pumped. Was $350 or so. First time pumped, so it needed it.
Old 03-06-2020, 1:58pm   #13
Black94lt1
Barn Stall Owner #13
NCM Supporter '13,'14,'16,'17,'19,'20
GTMS 18
Points: 19,164, Level: 95
Activity: 5.0%
Black94lt1's Avatar
Gameroom Barn Bucks: $425082
About the same price here and we do every 6 years
Black94lt1 is offline   Reply With Quote
Old 03-06-2020, 2:19pm   #14
Stevedore
Activity: 2.3%
Stevedore's Avatar
Tanks for the replies. ~$300 would be OK with me. No digging required, the tanks have iron "manhole" covers that are exposed & easily lift out. I guess I'll ask the guy who does it if it was premature, & if I could have waited longer.
Old 03-06-2020, 2:27pm   #15
Mr.Bigg
Banned
Activity: 46.7%
Mr.Bigg's Avatar
Just take a stick and poke around and see how thick and deep the solids are.
The shit suckers are known to lie. Your shit is their bread and butter.
Old 03-06-2020, 3:15pm   #16
Egnalf
Activity: 11.7%
Egnalf's Avatar
I owned a place I bought in 2007 and sold in 2018. weekend place but I always had 8-10 adults using it. never had it pumped until it sold. it was fine but I had it done anyhoo
Old 03-06-2020, 3:46pm   #17
69camfrk
Barn Stall Owner #6969
Points: 53,803, Level: 100
Activity: 14.9%
69camfrk's Avatar
Gameroom Barn Bucks: $1071057
If a septic system is operating properly, it doesn't need to be pumped.
69camfrk is offline   Reply With Quote
Old 03-06-2020, 4:07pm   #18
lspencer534
Dorkapottamus
Barn Stall Owner #52
Points: 198,355, Level: 100
Activity: 2.6%
lspencer534's Avatar
Gameroom Barn Bucks: $9339376
I've lived in my house since 1990. It has two septic tanks. I've never had either one of them pumped out.
The Following 2 Users Say Thank You to lspencer534 For This Useful Post:
Old 03-06-2020, 7:02pm   #19
JRD77VET
NCM Supporter '16,'17,'19,'20
GTMS 18
Points: 87,793, Level: 100
Activity: 17.6%
JRD77VET's Avatar
Gameroom Barn Bucks: $5975553
The village idiot we used before was charging $250 and wanted to raise the price to $280.
We ended up seeing an ad in a local paper for another company for $180.
When the new company came, we found out the village idiot was only taking the liquid and leaving all the solids The new company did the correct job cleaning it and luckily no damage was done to our septic system.
EDIT
Village idiot is based out of Quakertown PA and has "Polish sounding name" that begins with a K
The upstanding and honest company is Robbins out of Green Lane PA and is highly recommended.
Old 03-07-2020, 6:32am   #20
6spdC6
Activity: 7.0%
6spdC6's Avatar
Here where the older systems were put in about 3' deep will cost you plenty if your overdue on getting them pumped. If it acts up in a cold part of the winter and they have to bring in a backhoe to get to the tank cover(and possibly the whole leach field) that normal charge of $250 or so will seem like a bargain.
As for me its cheap insurance to get it done every 3 years!
Thread Tools
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright 2009 - 2020 The Vette Barn
