04-21-2021, 7:37am | #21 | ||||||
That's some world class monitoring you got there. Never used more than 4 or 5 at once myself. You do know a monitor can host more than one application at a time?
04-21-2021, 11:31am | #22 | |||||||
VB Dad of the Year
Let's assume you had two 60" 4k monitors, your screen resolution would have a screen resolution of 9680 x 2160. In contrast, my array of 18 monitors will give me a working desktop size of 23,040 x 6480. Just because the huge monitors are bigger, they have the same resolution as each of my 32" monitors. That's a HUGE difference in total desktop size. |
04-21-2021, 11:33am | #23 | ||||||
how do even keep track of what is on each screen?
04-21-2021, 11:36am | #24 | ||||||
VB Dad of the Year
04-21-2021, 11:46am | #25 | |||||||
Were 8K monitors considered? If so, why did you decide against them? |
04-21-2021, 11:48am | #26 | ||||||
How many computers are connected to those monitors?
04-21-2021, 11:52am | #27 | ||||||
VB Dad of the Year
1
Monitor #7 illustrates why I'm buying 20 (2 spares). You can no longer buy the 1920x1200 monitors and when that bottom left died, I had to put a 1920x1080. |
04-21-2021, 12:10pm | #28 | |||||||
VB Dad of the Year
I also personally like this solution, because even though it's one desktop, each monitor can work as it's own, meaning when I double click on an app, it maximizes only on that screen. I definitely like that level of compartmentalization. One thing I'm very much looking forward to is the slimline bezel. On the current setup, the gap between 2 monitors due to the old wider bezels is 2+ inches. The new setup will look very much like a monitor wall that you'd see in an airport. |
The Following 2 Users Say Thank You to Datawiz For This Useful Post: |
04-21-2021, 12:11pm | #29 | ||||||
I understand buying a couple of spare monitors. I buy lots of spares. It's great when you can grab a replacement off the shelf for whatever without having to order it. I keep spare laptops. Usually I buy a spec I like new (and they're usually expensive), then when used ones become available for cheap I buy a few spares to keep things going for a bit longer. Just swap the SSD and RAM and I'm up and running again in a few minutes.
Since you only have one computer running all those monitors, I feel obliged to ask what kind of computer you're running? Is it off the shelf? Did you build it? What specs? What OS? |
04-21-2021, 12:13pm | #30 | ||||||
04-21-2021, 12:31pm | #31 | |||||||
The Following 3 Users Say Thank You to DAB For This Useful Post: |
04-21-2021, 12:37pm | #32 | ||||||
VB Dad of the Year
This thing is a monster (yes, I built it. Been building computers since 1986). It has 9 total internal drives with over 100 TB of internal storage. It has 3 nvidia GTX 1070 video cards with 4 ports each. The remaining 6 monitors run off of J5 Create USB to HDMI adapters. My new cards have 6 ports each, so I'll need no adapters, just the cards.
04-21-2021, 12:42pm | #33 | ||||||
VB Dad of the Year
Those cards only have 4 ports each. I need a total of 18 ports, and 4 cards "does" fit, but it prevents me from using a lot of cables that are necessary to the tower's overall functionality, like having working USB ports and lights (and 4 would only be 16 monitors). I MUST have 3 cards with 6 ports each.
04-21-2021, 12:49pm | #34 | ||||||
Gameroom Barn Bucks: $216475
I like cake.
(providing site content) |
The Following 2 Users Say Thank You to Thunder22 For This Useful Post: |
04-21-2021, 12:55pm | #35 | ||||||
VB Dad of the Year
04-21-2021, 2:11pm | #36 | |||||||
VB Dad of the Year
04-21-2021, 2:46pm | #37 | ||||||
Gameroom Barn Bucks: $1001365
J5 Create
The Following User Says Thank You to NotSlo For This Useful Post: |
04-21-2021, 2:51pm | #38 | ||||||
04-21-2021, 2:54pm | #39 | |||||||
But the ability to double-click and expand to only a single monitor is a big plus. |
04-21-2021, 3:05pm | #40 | |||||||
VB Dad of the Year
I routinely swap out the storage drives on a regular basis. Every time, I get bigger and bigger drives, and the fully functioning drives to be replaced go on a shelf. Capacity keeps getting larger and larger, and I don't really store much on the OS drive. I only need my programs on it, and it's imaged nightly via Acronis True Image. I also use a shit ton of VM's, in particular the one I do all of my programming with. It's portable and frequently moves back and forth between the tower and the mobile workstation. If the computer fails for any reason, I'm perfectly capable of working from the laptop. This is just a backup directory from 1 of the 9 drives. Clearly one drive is the OS drive, but I have a VMWare backups folder on the other 8 drives. I routinely back up my primary vm machines. In this screenshot, each copy of the highlighted backup is 500GB. And yes, that 500 GB easily fits on my mobile workstation, because it has 3 hard drives all by itself. |
