Old 11-17-2009, 10:24pm   #1
PortDawg
Charter Member - C3 Mod
Barn Stall Owner #34
NCM Supporter '15
Points: 30,980, Level: 100
PortDawg's Avatar
Gameroom Barn Bucks: $173
Default Put in a Halltech Air Filter and bridge...
..now I keep getting the Lean code. I thought this 04 was supposed to be smart enough to figure it out on it's own....
Anything I can do?
Old 11-18-2009, 7:22am   #2
How long has it been installed? I believe it takes a while for the tables to be re-learned. But you may need a tune to correct the lean situation.
Old 11-18-2009, 7:53am   #3
Did you move the MAF up to the TB end of the bridge?
Old 11-18-2009, 8:03am   #4
Culookin
Points: 5,156, Level: 49
Culookin's Avatar
Gameroom Barn Bucks: $802
As Munch stated, it may take a while for the computer to learn the new air intake. Have you tried disconnecting the battery for a little, then starting her up?
Culookin is offline   Reply With Quote
Old 11-18-2009, 8:06am   #5
MYSCZ06
Points: 11,473, Level: 74
Activity: 0.6%
MYSCZ06's Avatar
Gameroom Barn Bucks: $2154
^^ this was going to be my suggestion
~~Shawn~~
2018 Z06 A8
Old 11-19-2009, 6:11pm   #6
PortDawg
NCM Supporter '15
PortDawg's Avatar
No but I'll try it this weekend...
Old 11-19-2009, 6:12pm   #7
PortDawg
NCM Supporter '15
PortDawg's Avatar
Nope
Old 11-19-2009, 6:41pm   #8
Points: 35,055, Level: 100
First, double check for any possible leaks between the MAF and TB. (always check the simple stuff first).
Second, if you didn't do an idle relearn (or battery disconnect), try it. It will reset the fuel trims, and may stop the lean codes (or maybe just for a while).
Lastly, Aftermarket filter setups and Z06s have a long running reputation for this issue. The screenless MAF used on the 02-04 Z06's is a lot more sensitive to airflow patterns/turbulence, and will provide the PCM with inaccurate airmass readings as a result (reporting more airflow than actual).
Halltech makes a laminar honeycomb screen for the 85mm MAF, which is reported to cure the issue. That, or tuning might be your only options in fully curing it.
Sick of Lean Codes? End them forever - Corvette Forum
Halltech Systems- Corvette Induction Systems
Old 11-19-2009, 7:49pm   #9
Lowcash
Points: 4,921, Level: 47
Lowcash's Avatar
Gameroom Barn Bucks: $2827
I had this issue last month after an oil change and fuel filter change. I thought maybe there was an issue with the fuel filter but I tightened the clamps between the MAF and bridge and code went away.
2008 C6 Z06
