Old 02-03-2019, 9:06pm   #21
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,158, Level: 100
Activity: 9.4%
JRD77VET's Avatar
Originally Posted by Brett K View Post
I highly recommend a Larue trigger. I have one in every build. The best $87 you will spend on an AR. The bolt catch roll pin is the only tricky one. I use the starter and punch built specifically for this with one side flattened. I also tape the area on the receiver. I use some 220 grit sandpaper on one end of the pin and some Oil. I can usually get it in pretty far and then I use a set of straight jaw tongue and groove pliers wrapped in electrical tape to pull it the rest of the way through.
Thanks Brett
That just got moved very high on the list. I have a very nice trigger in my Bushmaster DCM , I can compare it to that when I get one.
Old 02-16-2019, 6:55pm   #22
JRD77VET
Activity: 9.4%
JRD77VET's Avatar
Cool
Finished this up this afternoon. It was actually pretty easy but instructions were needed.
I found this which has the lower assembly in what I feel is the proper order ( mag catch first so a mag vise block can be used )
https://www.pewpewtactical.com/build...ower-receiver/
My question to Palmetto State Armory about lower assembly was answered with this link
http://www.thenewrifleman.com/how-to...ower-receiver/
Tomorrow is off to the range to make sure it works as designed
Old 02-17-2019, 10:25am   #23
Brett K
Points: 13,229, Level: 79
Brett K's Avatar
Gameroom Barn Bucks: $2004620
Very nice! Any thoughts on optics?
Brett K is offline   Reply With Quote
Old 02-17-2019, 7:15pm   #24
JRD77VET
Activity: 9.4%
JRD77VET's Avatar
I have an illuminated reticle 3-10X scope (KONUS) I might put on for a bit before getting a red dot or similar system. I have a set of UTG quick detach mounts but need taller ones ( on order ).
Had it at the range today, it worked well but I forgot the sight tool and it was hitting 6" low ( but centered ) at 25 yards.
Old 02-18-2019, 2:50am   #25
Nox
Points: 13,176, Level: 79
Activity: 1.1%
Nox's Avatar
Gameroom Barn Bucks: $7601
25 yards is not a great zero for an AR, but at that range, it should shoot about 1.5 inches low to account for bullet rise at 100 yards and beyond.
Nox is offline   Reply With Quote
The Following User Says Thank You to Nox For This Useful Post:
Old 02-18-2019, 8:35pm   #26
JRD77VET
Activity: 9.4%
JRD77VET's Avatar
I usually start at 50 yards but I'm fighting a cold that is kicking my ass for the past week.
Thanks
Old 02-18-2019, 8:38pm   #27
markids77
Points: 22,591, Level: 100
Activity: 10.8%
markids77's Avatar
Pro tip... a bullet tip is all that is required to adjust most AR front sights.
The Following User Says Thank You to markids77 For This Useful Post:
Old 02-18-2019, 8:46pm   #28
JRD77VET
Activity: 9.4%
JRD77VET's Avatar
I have flip up sights
Optics: Magpul MBUS Front and Rear Flip-Up Sights, Black
They came with a little "socket" that fit over the sight
Old 03-16-2019, 8:00pm   #29
JRD77VET
Activity: 9.4%
JRD77VET's Avatar
About $95 shipped w/ tax.
Not installed yet but have it in hand ( in the cool tin they ship it in )
Old 03-18-2019, 3:21pm   #30
Brett K
Brett K's Avatar
They usually send lots of cool stuff with the tigger. No Dillo Dust or bottle opener?
Old 03-18-2019, 6:57pm   #31
JRD77VET
Activity: 9.4%
JRD77VET's Avatar
I got the trigger, a catalog and some packing paper.
Boy, I feel like I got ripped off now
