Share Thread Tools
Old 02-22-2021, 1:31pm   #1
DJ_Critterus
Stall Owner #1120.2520
Points: 65,013, Level: 100
Activity: 60.4%
DJ_Critterus's Avatar
Default [Geek] Need help with DICOM on Echo Cardio (ultrasound) Machine
Does anyone here know Triltech Software (Showcase Priemium and Image Center) and how it interacts with a GE Echo (ultrasound) machine?
I have all of my settings on the machine set correct, but I cannot transfer images to a computer with a direct ethernet connection (not on the LAN or domain).
Triltech's tech support is only done via email and they keep referring back to their troubleshooting guide which has done nothing to help.
Any of you know this software? I have screenshots and log files to look through if you do.
DJ_Critterus is offline   Reply With Quote
Old 02-22-2021, 1:56pm   #2
JetMechZ16
Points: 34,771, Level: 100
Activity: 99.4%
JetMechZ16's Avatar
Gameroom Barn Bucks: $856744
Quit trying to ultrasound your nuts.
Old 02-22-2021, 2:42pm   #3
ratflinger
Barn Stall Owner #THX1138
Points: 7,767, Level: 61
Activity: 25.5%
ratflinger's Avatar
Gameroom Barn Bucks: $1322
Look at the other site, not writing that shit twice!
ratflinger is offline   Reply With Quote
Old 02-22-2021, 2:48pm   #4
DJ_Critterus
Activity: 60.4%
IK like the warm jelly that has to be used for it to work
Old 02-22-2021, 3:04pm   #5
Torqaholic
Points: 16,373, Level: 88
Activity: 27.5%
Torqaholic's Avatar
Is it showing on the Device Manager in Control Panel?
Might be able to get some info through that if there's a conflict for resources? That used to be a common thing to see way back when, not so much anymore after plug and play finally got its act together.
Torqaholic is offline   Reply With Quote
Old 02-22-2021, 3:22pm   #6
BayouCountry
Barn Stall Owner #105
Points: 389, Level: 7
Activity: 31.9%
BayouCountry's Avatar
Maybe a crossover cable? Most systems I worked with needed domain authentication.
BayouCountry is offline   Reply With Quote
Old 02-22-2021, 3:55pm   #7
Points: 25,153, Level: 100
Why would you even try?
Just plug it into a LAN and be done with it.
Old 02-22-2021, 8:00pm   #8
snide
NCM Supporter '13
Points: 111,069, Level: 100
Activity: 99.6%
Do you really that that DJ is master of his domain?
snide is online now   Reply With Quote
Old 02-22-2021, 11:18pm   #9
ratflinger
Activity: 25.5%
ratflinger's Avatar
Domain authentication is not necessary unless the computer is set up to specifically need it. You must be a Windows guy.
Old 02-22-2021, 11:30pm   #10
Clearly not, but I know for sure that @Knooger is.
Old 02-23-2021, 8:29am   #11
DJ_Critterus
Activity: 60.4%
These sonograms are training devices and can't be put on our network due to licensing and security issues, so i have to do direct connections to the computers. Plus, for three machines, it wouldn't be worth the effort to set up a dicom server.
See, students go do their labs or tests then send the results to the computer so they can get out of the way for the next group while they/instructor goes over the results on the computer. It'll be more of an issue when the KungFlu is finally recognized for not being as serious as it is and they permit full classes again.
Old 02-23-2021, 8:40am   #12
BayouCountry
Activity: 31.9%
But what authentication does the GE equipment require? I worked with Unix and other systems. Started out programming cobal with IBM punch cards. Ended my career as a database administrator.
Old 02-23-2021, 8:55am   #13
DJ_Critterus
Activity: 60.4%
the GE equipment has its own login and doesn't care where it sends the data. Only the software on the computer cares about the computer's local login/PW.
Old 02-23-2021, 9:03am   #14
BayouCountry
Activity: 31.9%
Then the only other thing is to make sure it’s on the same subnet. If it pings then I’m guessing it’s a software issue if license is valid. Let us know what you find out.
Old 02-23-2021, 9:07am   #15
DJ_Critterus
Activity: 60.4%
subnet is a /24 255.255.255.0 and it matches on both machines.
GE sonogram IP is 192.168.1.1 and the computer's last octet is .2
Old 02-23-2021, 9:49am   #16
ratflinger
Activity: 25.5%
ratflinger's Avatar
No insult meant. Medical devices are generally not setup to require domain authentication because too many of them are sold to small clinics where the whole network may only be a switch. Granted more and more have some 3rd party IT admin now, but that usually just means a couple of extra switches, a DHCP server, & a firewall. Also, there are so many in a larger facility that no one whats to take the time to do all the network setup. Usually just get it to talk to the PACS & to the remote support VPN. In many larger facilities the imaging systems are on a separate vlan that talks to a PACS system. The PACS is the only device out on the hospital network, so it's authenticated.
Old 02-23-2021, 10:02am   #17
Your OP said "direct Ethernet connection" - in other words a crossover cable between two machines. If you take those same two machines, remove the crossover cable, and plug them (and only them) into a switch, now those machines are on a LAN. Does it work then?
Old 02-23-2021, 10:27am   #18
BayouCountry
Activity: 31.9%
No insult taken. I worked in a hospital for 20 years networking medical devices. I installed the first Windows NT Server and setup the initial domain. They didn't even have email when I started. We wanted devices on the domain because of the Interfaces between systems.
I don't claim to be an expert. I handed over the network Admin to the young guys and concentrated on interfaces and databases when the hospital grew into a healthcare enterprise.
I found most problems to be the routing and security settings when we had issues. Yes, I worked with the PACS system, OB monitoring system, etc.
Old 02-23-2021, 10:37am   #19
DJ_Critterus
Activity: 60.4%
Nope.
I sent screen shots to Tiltech tech support and they said all my configurations were correct except something was blocking port 8080 and port 104. I'm looking to see what's running using those now from the CMD window.
So far I see nothing and all of my firewall settings for domain, public, and private networks are disabled.
Old 02-23-2021, 11:44am   #20
DJ_Critterus
Activity: 60.4%
Success!!!!!! Disabling the firewall via gpedit was the trick. @ratflinger and others, thanks for the assistance
The Following User Says Thank You to DJ_Critterus For This Useful Post:
Thread Tools
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright © 2009 - 2021 The Vette Barn
