09-07-2014, 2:25pm | #1 | ||||||
Gameroom Barn Bucks: $2601174
battery tender
please post a pic of how you have connected your battery
09-14-2014, 3:08pm | #2 | ||||||
Barn Stall Owner #1776
I'm sorry, what the hell are you talking about and what exactly are you looking for? You've been given pictures (Google Image) what is it that you don't get and why the pity party.
09-14-2014, 3:15pm | #3 | ||||||
no pity at all, WTF are you talking about i purchased a car over payed a little but i am not crying
09-14-2014, 3:17pm | #4 | ||||||
Barn Stall Owner #16A
Gameroom Barn Bucks: $602908
Huh?
Plus to plus, minus-gative to minus-gative. Don't forget to plug the charger into the wall outlet. This isn't difficult. |
09-14-2014, 3:18pm | #5 | ||||||
You're talking about hooking up a battery tender, aren't you? Not buying a used car on this thread, correct?
09-14-2014, 3:19pm | #6 | ||||||
09-14-2014, 3:23pm | #7 | |||||||
09-17-2014, 10:37pm | #8 | ||||||
ok i just got the tender and the bolts but it just doesnt seem to fit through the holes can i cut the oring and spread it and then push it into the screw , what do you guys think |
09-17-2014, 10:38pm | #9 | ||||||
it just won fir through the hole what should i do |
09-17-2014, 11:00pm | #10 | ||||||
ok was told from another forum member just clip it and put it through just wondering why it was bigger
09-18-2014, 3:08pm | #11 | ||||||
job was done , ended it snipping the o ring connector and putting it into the bolt, i took some pics if anyone needs to see what it looked like, because hey sometimes all it takes is a pic to understand
09-22-2014, 7:51am | #12 | ||||||
ok i figured it out, this should be a sticky,
problem , kept noticing charger always showing battery half charged solution and conclusion took charger out of battery area and left out above hood, all of a sudden battery showing fully charged , it seems the interior lights and hood interior light was draining enough so the tender was showing half, so just a update in case anyone cares |
09-25-2014, 3:45pm | #13 | ||||||
I use the quick disconnect wire
09-25-2014, 4:17pm | #14 | ||||||
09-25-2014, 4:41pm | #15 | ||||||
09-28-2014, 2:44pm | #16 | ||||||
i know its weird but dayum if i have the hood open the tender goes into middle position the hood light uses a lot of power, but if i close the hood the light in the charger goes into maintenance mode
very weird indeed, who would have thought a light like that would use so much power |
09-28-2014, 2:58pm | #17 | |||||||
You can leave the hood up, the light will go out after 15 mins, if no doors are opened. If you open a door, the hood light will come back on for another 15 mins. Or just take the bulb out if it bothers you that much. |
09-28-2014, 3:05pm | #18 | |||||||
