01-09-2012, 7:09pm | #1 | ||||||
Gameroom Barn Bucks: $5201
Installing new radio in 2003 Sierra - double din
Has anyone installed an aftermarket radio in a ~2003 Sierra? I have noticed that double din radios fit. Crutchfield states that the removal of the rear bracket is needed on single and double din radios. I looked on YouTube and I have noted that some say it is not necessary.
So if anyone has some insight let me know. Thanks |
01-09-2012, 7:34pm | #2 | |||||||
Barn Stall Owner #17
That was a single din Alpine HU. When they say bracket removal, are they referring to the "cage" that holds the factory head unit in place? I would never alter that unless you had to, as it involves cutting over the top of and around a lot of important wiring. What I have seen issues with is the depth of the mounting hardware (holds the source unit) depending on mfr. (Scosche etc) Some of the late model GMs have less clearance due to HVAC ducting that is placed in the slot that would be directly behind where the head unit goes. Most of the time, you can remedy that by removing the stud at the rear of the unit to be installed. Feel free to shoot me a pm if it would be helpful. I'm not the best, but I've installed a lot of aftermarket systems over the last 25 years. Scott
01-09-2012, 7:37pm | #3 | ||||||
Barn Stall Owner #1991
478-477-4321. Ask for Billy. Tell him we are friends.
01-09-2012, 7:40pm | #4 | |||||||
01-09-2012, 7:41pm | #5 | ||||||
01-09-2012, 7:47pm | #6 | ||||||
The Following User Says Thank You to carlton_fritz For This Useful Post: |
01-09-2012, 9:22pm | #7 | ||||||
Gameroom Barn Bucks: $2173478
I just installed a 2 din in my 2500hd. I did have to cut the bracket, and use the two required modules.
01-09-2012, 9:28pm | #8 | |||||||
Also did you cut the metal bracket or the plastic part that holds the pin on the factory radio, what year is yours? I looked and that metal bracket is far back in there. One last question, did you try to fit it prior to cutting and if so how much was it off to making it fit. One module is for the chime was the other for steering controls or did you have OnStar? I do not have OnStar. Thanks many. Bob |
01-09-2012, 9:36pm | #9 | |||||||
Barn Stall Owner #38
Gameroom Barn Bucks: $2497584
01-09-2012, 9:38pm | #10 | ||||||
The Following User Says Thank You to Rotorhead For This Useful Post: |
01-09-2012, 9:58pm | #11 | |||||||
Yes the two modules were the door chime & steering wheel controls. I used the AXXESS adapter, it works ok, it was a real pain trying to get it working, then all the sudden it started working...very frustrating actually. I also used a relay to try and bypass the parking brake wire...it doesn't work very well on the app radio, I still wound up using a manual switch on the parking brake ground. I intend to add the back up camera sometime soon, and I still want to go back and re-wire/solder everything in place and shorten some of the wiring harnesses. I did a test fit it was close but I still had to cut out the bracket. I don't have a dremel so I used a hacksaw blade by hand and cut out the plastic in the rear for that pin, it wasn't bad. Anyways I hope this helps I'll be more than happy to help in any way I can, I just did this install about 2 weeks ago for Christmas. |
01-10-2012, 12:17pm | #12 | ||||||
I put in a single din radio in an '04 Silverado work truck because I wanted a cassette and cd player (put the 6 disc changer behind the seat). One great thing about doing that was it eliminated the damned door chime. Why anyone would want that is beyond me.
Want to listen to your stereo with the driver door open? Ding-ding-ding.....crap! I didn't have to worry about redundant steering wheel controls because it was a work truck, but my advice would be to forget about trying to keep the chime. Not having it is a plus. You don't get the nanny chime when you don't have a seat belt on, either. The only time I missed the chime was when I realized I had left a turn signal on, 5 miles down the road. OP, are you looking for a double din because you want an in-dash nav system? Otherwise, I don't see the benefit. |
01-10-2012, 12:35pm | #13 | |||||||
01-10-2012, 12:51pm | #14 | |||||||
Did you cut the plastic radio bucket or metal bracket? |
01-10-2012, 12:52pm | #15 | ||||||
01-10-2012, 1:08pm | #16 | ||||||
01-10-2012, 2:11pm | #17 | ||||||
Post up pix when you are done.
The Following User Says Thank You to Bucwheat For This Useful Post: |
01-10-2012, 5:12pm | #18 | ||||||||
