02-29-2024, 8:36am | #1 | ||||||
Gameroom Barn Bucks: $530
Need a new gas pressure washer
Have a 20 year old Excell 2600 and it's done. Has a Honda engine that is a bitch to start.
Any recommendations? Looking at this one. Not interested in the new start/stop technology. Westinghouse 3400 PSI 2.6 GPM Gas Powered Axial Cam Pump Cold Water Pressure Washer https://www.homedepot.com/p/Westingh...3400/317232456 |
02-29-2024, 8:37am | #2 | ||||||
Try this place too,I bought this there,went electric and works great for my needs....they have a large selection and was free shipping.
https://www.countryhomeproducts.com/ |
02-29-2024, 8:42am | #3 | ||||||
I like my Honda engine PW, think it's a craftsman (display model so was cheap).
Starts fine albeit a tad underpowered to me. They're all about the same crappy quality past the engine, you could slap a new engine in it... |
02-29-2024, 9:18am | #4 | ||||||
My last gas was a Troy Built with a Kohler engine @ 3,300 PSI. Was 10 yrs ago. Great machine
02-29-2024, 9:29am | #5 | ||||||
Gameroom Barn Bucks: $2001216
Hmmmm, if you're buying by price, HD can be ok....Mostly, HD sells an inferior (somehow modified) product at a lower price.
Fuk the box stores. IMO |
02-29-2024, 9:51am | #6 | ||||||
Paging @JoeCoool
02-29-2024, 10:18am | #7 | ||||||
You haven't said what you use it for.
I have an old Ryobi/Honda that works fine. Starting is always a bit challenging at the start of the year, but if you want to skip the hassle, just have some starter fluid on hand and it's second pull max. All my Honda pulls have been harder to start than my other small engines. Having said that, if If I can spend 15 seconds to yank an air filter and get another 10+ years out of it, I'm keeping it. Hit your existing, very capable, unit with a shot of starter and see if you don't change your mind. We had an electric for a while for small jobs. Emphasis on small. |
02-29-2024, 10:33am | #8 | |||||||
Have 2 large deck to clean yearly. front is 65 x 14 and the back is 60 x 11. Top and bottom. |
02-29-2024, 10:49am | #9 | |||||||
After that, you can start it while everything is hooked up, but you need to keep the trigger on to release the water pressure from the pump. |
02-29-2024, 10:58am | #10 | |
I bought a Craftsman model with 3200PSI (IIRC) 6-7 years ago and have never had an issue with it. Like said above, if the hose/wand are hooked up, the lever has to be pulled in order to start it, but I've never once had it try to yank my arm off. When not in use, I turn off the fuel and let the carb run dry and then fog it with either Deep Creep or load it up with Marvel Mystery Oil. |
02-29-2024, 11:06am | #11 | ||||||
Gameroom Barn Bucks: $311064
I bought a Husqvarna 3200 psi from Costco two years ago and have been happy with it.
02-29-2024, 11:20am | #12 | ||||||||
02-29-2024, 11:32am | #13 | |||||||
I have had to "tune" the choke position for it to run consistently, especially when it's hydrolocked. |
02-29-2024, 11:51am | #14 | |||||||
It ran a little better with the choke on but eventually just wouldn't run right or build pressure. |
02-29-2024, 12:01pm | #15 | |||||||
BTW, get rid of that wand for car washing unless you really need to reach somewhere. I got a new 50' hose for mine and fitted a new gun that I can plug in nozzles and foam guns straight up. I kept the M22 connection at the pump because it's actually a better mate and very solid. Everywhere else is quick connects so I can swap in and out. Will keep the wand for ground work, but it's now an accessory. |
02-29-2024, 12:08pm | #16 | |||||||
02-29-2024, 12:16pm | #17 | |||||||
Leave the hose connection at the pump OUTLET unconnected. Turn on the faucet (these power washers use the water for cooling), and then start her up. It will spit water at what looks like a dismal level because these work on pressure and volume. Volume is small, but as soon as you stop the flow, the pressure builds pretty much instantly. Let it run for a few minutes. If you can't start it, go back to square one with the carb fluid. But get it running without the hose first. It should present little pull resistance if you have nothing connected but supply water. If you get by that, then just keep the trigger depressed while you pull start and you should be fine. |
02-29-2024, 12:36pm | #18 |
Dirty carb, float had varnish in it, and needle valve also had varnish. Jet was probably clogged, too. A good cleaning with Deep Creep (SeaFoam) and some steel wool fixes that up easily.
02-29-2024, 1:32pm | #19 | |||||||
I tried every combination to start this. The pull cord is resistant. It's not the carb as once you get it going it runs fine. |
02-29-2024, 1:41pm | #20 | ||||||
Gameroom Barn Bucks: $476
You pay for GPM, not PSI.
PSI is advertising or bragging...gpm is for cleaning. |
The Following User Says Thank You to SurfnSun For This Useful Post: |
