Old 07-28-2020, 12:51am   #41
Points: 35,065, Level: 100
Originally Posted by Strats-N-Vettes View Post
No trolling...was a serious Q that I still don't have a legit answer for.
I'm not kicked out of anywhere, and it's not about CF or VB...I just used VB as the example as what I was asking.
Hoping @Y2Kvert4me ; or someone with moderate intelligence will answer or at least PM.
Shit works like this:
When you join. post, visit this site, yeah I do see an IP address. If you're on a typical landline ISP, I can usually approximate your (city) location from it.
If you're on a cellphone, I can see that and will know your mobile provider, however I won't be able to determine your location, and that IP# will probably match everyone else here that uses that same mobile carrier.
If you use a VPN, I can tell that too, but again, any location data is irrelevant, as I understand you could be anywhere in the world.
Point being, an IP address can sometimes be very useful information to me...But just as often, it is meaningless. Takes me but a second or two to determine which applies.
So if using a VPN, no I won't be privy to your actual (ISP) IP address. and for the purpose of hiding, you might actually achieve incognito success IF you manage to only visit here while connected to that VPN 100% of the time.
But understand 99.9% is the failing mark in this particular test. If you pop in here just once after forgetting to connect to that VPN, well then I will have your "real" IP logged, and all your efforts to obfuscate it accomplished exactly nothing.
Old 07-28-2020, 4:33am   #42
Strats-N-Vettes
SOME Real Barner
Points: 172,094, Level: 100
Activity: 8.1%
Strats-N-Vettes's Avatar
Gameroom Barn Bucks: $2034428
Exactly what I was asking about and wanted to know.
Thank you very much.
Strats-N-Vettes is offline   Reply With Quote
The Following User Says Thank You to Strats-N-Vettes For This Useful Post:
Old 07-28-2020, 10:03am   #43
Points: 57,259, Level: 100
Activity: 55.4%
It should be noted that most residential ISPs do not give you a fixed IP address - they charge you extra to have one. While it often stays stable for many weeks or months, it can and does change without notice. One quick and easy way to convince your ISP to assign you a new IP address is to program a new MAC address into your gateway's Ethernet interface and then reset your cable modem.
The Following User Says Thank You to dvarapala For This Useful Post:
Old 07-28-2020, 12:26pm   #44
JetMechZ16
Points: 46,956, Level: 100
Activity: 5.4%
JetMechZ16's Avatar
Gameroom Barn Bucks: $856744
Originally Posted by markids77 View Post
Why not try it? But call yourself "Cars and Guitars" or something so we'll know it is you.
Yugos-N-Ukuleles is more his speed.
The Following User Says Thank You to JetMechZ16 For This Useful Post:
