05-25-2019, 7:10pm | #1 | ||||||
Cub Cadet part save
George on the cub cadet forum had a major bearing failure for the chain drive tensioner on his snow thrower. Both needle bearings in the ears completely gave up, the sprocket shifted over into the casting and then the chained jumped off the sprocket. Sometime during the event, the spirol pin sheared.
We both looked for a replacement casting but they are next to impossible to find. I got the piece and used my three ton press to get it apart. ( just barely, I thought I would have to do it at work ). I made a bronze contoured washer to fit in the spot where the sprocket abraded the aluminum away and was able to save the transfer shaft. New needle bearings and a new sprocket and now it's ready for next winter |
The Following 10 Users Say Thank You to JRD77VET For This Useful Post: |
05-25-2019, 7:20pm | #2 | ||||||
Gameroom Barn Bucks: $930358
neato
The Following User Says Thank You to SubZero For This Useful Post: |
05-25-2019, 9:17pm | #3 | ||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
Nice craftsmanship
The Following User Says Thank You to Black94lt1 For This Useful Post: |
05-25-2019, 9:20pm | #4 | ||||||
05-25-2019, 9:23pm | #5 | ||||||
Found a box for the book!
Mailing next week. |
05-26-2019, 9:53am | #6 | ||||||
That skived out section of the casting, what do?? weld it up and machine it out, or just use some kind of filler/glue/etc???
05-26-2019, 6:37pm | #7 | |||||||
The picture shows the original sprocket that got against the outer bearing cage and as the steel sprocket wore, it "ate" the casting away. As seen in the replacement sprocket ( it's a plus 1 tooth) , it should be flat. Since I could get measurements off the sprocket, I made a "mirror image" of a bronze washer to replace the aluminum that was worn away. |
05-28-2019, 3:01am | #8 | ||||||
Barn Stall Owner #49
Gameroom Barn Bucks: $1025197
I love a good save like that!!!!
