01-20-2023, 9:47am | #21 | ||||||
01-20-2023, 3:11pm | #22 | ||||||
Gameroom Barn Bucks: $403994
Back on topic and trying to be helpful ...
Two things - maybe have them turn down the hardness level on the softener it may be set too high - usually when the water feels super slippery it is over softened. Then - the drinking water should really bypass the water softener. In the upper midwest where we are it is std practice to not have the kitchen faucet on the softener circuit. Check with your in-laws on this... if it is that way they can get their drinking water just from that one faucet. |
01-20-2023, 3:31pm | #23 | |||||||
Have a friend in Nevada City who has a softener. Soap won't lather and the water feels slimy. Don't care for it. I'd rather load up on calcium and wipe my cars down. Hell, hardly wash them anyhow these days. It's all about detail spray and keeping them clean all the time. Much easier. |
01-20-2023, 4:19pm | #24 | |||||||
But I have seen places (in my youth) that had a separate drinking line and faucet on the kitchen sink. Although one in particular (as I recall) was that they had a lame dug well, and not enough water for a household with 5 people. So the main water supply was a cistern, drinking water came from the well. Not that dug well water was necessarily more sanitary than cistern water, but living in the country has its unique problems that city people aren't even aware of. "Why doesn't water come out when I turn the faucet on?" |
01-20-2023, 5:58pm | #25 | ||||||
01-20-2023, 6:29pm | #26 | |||||||
I think you could take Big Bob. He's a big boy, but you're faster and in better shape. You would wear him out just dancing around him and then could go in for the TKO. Just stay out of his reach when you're tiring him out. And whatever you do, don't let him fall on you. |
01-20-2023, 6:36pm | #27 | |||||||
A family I knew, about 6-8 miles from here, had one. The guy bitched about it cuz he had a steady stream of water flowing across his driveway/lawn. |
01-20-2023, 8:15pm | #28 | |||||||
Odd fellow. When I knew him, he and I were probably making the same money. I had a house on two acres with a wife and kids on the way. He lived in his AMC Pacer. He just saw no need for luxuries like a bed, hot showers and a cherry dining room set. |
01-21-2023, 8:11pm | #29 | ||||||||
I have it softened down to 0 grain hardness. The water does not feel super slippery or slimy. Soap lathers well. Small amounts of soap will do a great job. I use a pea-sized dab of shaving soap with a brush to make tons of lather. A couple of ounces of laundry soap will wash a medium-sized load with just enough soap. ??? Sure wish I could figure out why these experiences are so different. |
01-21-2023, 8:18pm | #30 | ||||||
FWIW: I didn't notice any difference in the volume of lather/suds after my water softener was hooked up.
Also, I've read that there isn't necessarily any correlation between the volume of suds and the actual cleaning power of any soap. |
01-21-2023, 11:12pm | #31 | |||||||
Iron removal is done via a greensand fllter that is recharged with Potassium Permanganate. The KMnO4 oxidizes the dissolved iron into small particles that are caught in the greensand. The system then backflushes periodically to blow out the iron, typically in a dry sump. If you had more than the single tall canister and the smaller KMnO4 canister, then they may have also added a softener. Wells in northern VA are notorious for Iron. The first time that all the white laundry came out a pale orange, the wife went berserk. I installed the system the next week. Contrast that with the well I'm on in CO and it's really night and day. The only thing I need to do is remove sand, and that's easily done with a whole house filter. I test the water frequently due to having a spa and the total hardness and alkalinity of the tap water are under 100ppm. |
01-21-2023, 11:45pm | #32 | |||||||
"The Guy" said I could go that route or go with a chlorinator system (I think) but the price would be roughly the same for either system. The softener worked great from 2006 up until maybe 5 years ago. Then I would have to take the injector apart and clean it every year or so. But it continued to get worse, and the past year or so a day or two before regeneration I could taste the iron in the water. So I had a different "Guy" come a few months ago and replace the beads which were nearly all pulverized. I should have done it sooner, but no harm done. Water is all good now every day. |
01-22-2023, 3:38pm | #33 | |||||||
