Old 08-16-2018, 7:18pm   #1
carlton_fritz
Barn Stall Owner #1991
Points: 74,431, Level: 100
Activity: 2.9%
carlton_fritz's Avatar
Default window a/c experts/ electrical experts
My window a/c just quit. I pulled the plug out and felt something sticky wet on the side of the plug. Is there liquid inside the reset part? It will not reset. a/c not working. As you know from the other thread, I do not have money for this. Do I get to tough it out until next spring?
carlton_fritz is offline   Reply With Quote
Old 08-16-2018, 7:20pm   #2
StaticCling
Points: 39,993, Level: 100
StaticCling's Avatar
Not sure why there would be anything liquid on the plug, unless something fried/melted etc.
Window AC units aren't that expensive. Go donate plasma if you are broke and save up.
StaticCling is offline   Reply With Quote
Old 08-16-2018, 7:23pm   #3
carlton_fritz
Activity: 2.9%
If I donated plasma, the money would go to curing Riley.
The plug is behind a table that has my printer on it. I don't see how anything wet got to it.
Old 08-16-2018, 7:30pm   #4
carlton_fritz
Activity: 2.9%
Just handled the plug, it appears the liquid came out of the plug. Some was running down the cord. It's sticky and somewhat thick. Not molasses, but not water thin.
Old 08-16-2018, 7:35pm   #5
StaticCling
I'm sorry buddy, didn't know about your other troubles.
AC's 'leak' water/condensation, but with a window unit that should be outside...not sure how it would get inside. Odd.
Old 08-16-2018, 7:38pm   #6
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 115,957, Level: 100
Activity: 13.3%
JRD77VET's Avatar
Is it tilted so the back (outside ) is lower ? Is the drain clear?
Old 08-16-2018, 8:08pm   #7
mrvette
Barn Stall Owner #101
Points: 133,167, Level: 100
Activity: 8.3%
mrvette's Avatar
The other stuff plugged into that same spot still works?? if so, try plugging into the other outlet on that recepticle....if it still works, the electric is fine.....
so to change the plug on the a/c unit....sounds like it's fried from heating up due to bad connection, if the section of the outlet the a/c was in is bad....try the a/c in the good socket.....maybe one leg of the power got hot due to bad connection and that spade on the plug would change color...darker....
new outlet is about 10-15 bux at most that's IF it is a GFI.....new plug for a/c unit about 5 bux at most....
The Following User Says Thank You to mrvette For This Useful Post:
Old 08-17-2018, 3:35am   #8
carlton_fritz
Activity: 2.9%
There is no drainage coming in. The only part that had that wet sticky fluid was right at the plug. The plug looks normal. The battery backup it was plugged into is working fine.
Old 08-17-2018, 5:49am   #9
VatorMan
Barn Stall Owner #122
NCM Supporter '11,'13
Bantayan Kids '13,'14,'17
Points: 68,292, Level: 100
Activity: 9.4%
VatorMan's Avatar
Gameroom Barn Bucks: $1158963
Can you wiggle one of the plug blades ? If so, there is a possibility the compound that makes up the plug has melted.
It would be really helpful if you'd post a pic.
VatorMan is offline   Reply With Quote
Old 08-17-2018, 12:45pm   #10
bill_daniels
Points: 222,045, Level: 100
bill_daniels's Avatar
If the power outlet still works, cut the plug off and wire a new, heavy duty plug to the a.c. wire you just cut. Maybe cut off
bill_daniels is offline   Reply With Quote
The Following User Says Thank You to bill_daniels For This Useful Post:
Old 08-17-2018, 1:04pm   #11
Rob
Barn Stall Owner #14
Barn Raising II,III Chef
NCM Supporter '11,'12,'13,'14,'15,'16,'17,'20
Ukranian Famers are the modern day Chuck Norris
Points: 83,084, Level: 100
Activity: 4.0%
Rob's Avatar
@aerovette is the electrical expert around here
Rob is offline   Reply With Quote
The Following 2 Users Say Thank You to Rob For This Useful Post:
Old 08-17-2018, 3:46pm   #12
carlton_fritz
Activity: 2.9%
Blades firm. Will post pic of plug later. On phone with vet.
Old 08-17-2018, 4:22pm   #13
carlton_fritz
Activity: 2.9%
pics of plug.
Old 08-17-2018, 5:19pm   #14
StaticCling
Looks like a 10 AMP GFCI plug, quick search on Amazon shows them to be about 20 bucks. Worth a shot.
The Following User Says Thank You to StaticCling For This Useful Post:
Old 08-17-2018, 7:01pm   #15
carlton_fritz
Activity: 2.9%
This one look good? https://www.amazon.com/OAONAN-Replac...FCI+plug&psc=1
Old 08-17-2018, 8:17pm   #16
SubZero
Points: 13,168, Level: 79
Activity: 1.4%
SubZero's Avatar
Gameroom Barn Bucks: $930358
probably a capacitor on the GFCI electronics or melted varnish on a winding. I would just replace the plug
SubZero is offline   Reply With Quote
The Following 3 Users Say Thank You to SubZero For This Useful Post:
Old 08-17-2018, 9:10pm   #17
StaticCling
Yup, sure does.
Old 08-18-2018, 6:39am   #18
VatorMan
Activity: 9.4%
VatorMan's Avatar
2 questions : Was the plug upside down while plugged in ? In other words, the ground (round pin) was on the top ?
Was the plug hot when you took it out of the receptacle ?
Old 08-18-2018, 6:40am   #19
carlton_fritz
Activity: 2.9%
It was sideways and not hot.
Old 08-28-2018, 4:51pm   #20
carlton_fritz
Activity: 2.9%
I got the new plug, but when I took the old one apart, extra wire that the directions say nothing about. My new plug doesn't come apart the same. I cannot get into the circuit board without breaking the plug. What do I do now?
