Old 12-03-2019, 12:00pm   #1
Points: 159,154, Level: 100
Activity: 19.4%
Default creative plumbing
The Following 3 Users Say Thank You to Mike Mercury For This Useful Post:
Old 12-03-2019, 12:11pm   #2
Activity: 19.4%
The Following 6 Users Say Thank You to Mike Mercury For This Useful Post:
Old 12-03-2019, 12:34pm   #3
DAB
Barn Stall Owner #4
Points: 172,146, Level: 100
Activity: 9.4%
DAB's Avatar
inside diameter must be less than outside diameter
shit only goes downhill
payday is friday.
DAB is offline   Reply With Quote
Old 12-03-2019, 12:37pm   #4
Rodnok1
Points: 42,646, Level: 100
Activity: 53.6%
Rodnok1's Avatar
Looks like the quality of work my neighbor does... And he's a maintenance guy at a factory.
Rodnok1 is offline   Reply With Quote
Old 12-03-2019, 12:39pm   #5
z06psi
Barn Stall Owner #∞
Points: 25,038, Level: 100
z06psi's Avatar
Gameroom Barn Bucks: $34677
Originally Posted by Mike Mercury View Post
z06psi is offline   Reply With Quote
Old 12-03-2019, 2:53pm   #6
mrvette
Barn Stall Owner #101
Points: 133,632, Level: 100
Activity: 10.4%
mrvette's Avatar
These daze I am amazed anyone messes with metal pipes at all, other than a sawzall and trash can.....the 'water' will eat copper as well as 'galvanized'.....
I not sure about cast iron DWV......I suspect it's all toast by now too.....
AND too boot, just WTF?? those pix are not REAL, some jokester set it up.....
Old 12-03-2019, 3:41pm   #7
z06psi
Barn Stall Owner #∞
z06psi's Avatar
PEX
Old 12-03-2019, 4:01pm   #8
Rodnok1
Activity: 53.6%
Rodnok1's Avatar
Nothing wrong with copper besides the price for supply lines, hard to beat cast iron drain lines for quiet in a house.
And yes all those pics are real, I've seen as bad many times. One guy used play doh to make a drain pipe fit inside another pipe under kitchen sink instead of an adapter.
Old 12-03-2019, 4:18pm   #9
Cybercowboy
2016 Election Expert
Barn Stall Owner #64
Points: 50,697, Level: 100
Activity: 34.6%
Cybercowboy's Avatar
I actually saw something worse than this in a rental house we had for a week in Costa Rica. It was in our shower and I made sure the fuse to that circuit was definitely not in the fuse box. It meant we had no light or fan in there though so I had to put the fuse in a few times at night.
Cybercowboy is offline   Reply With Quote
Old 12-03-2019, 4:48pm   #10
86RAG
Points: 23,062, Level: 100
86RAG's Avatar
86RAG is offline   Reply With Quote
The Following User Says Thank You to 86RAG For This Useful Post:
Old 12-03-2019, 5:26pm   #11
Aerovette
Barn Stall Owner #7734
Points: 106,365, Level: 100
Aerovette's Avatar
Pfft, hold my beer. I'm twice the plumber as I am an electrician.
The Following 4 Users Say Thank You to Aerovette For This Useful Post:
Old 12-03-2019, 7:14pm   #12
MikeB
Barn Stall Owner #115
Points: 22,485, Level: 100
Activity: 9.0%
MikeB's Avatar
Gameroom Barn Bucks: $610854
I wonder if the water tingles when it hits you.
But, then again, I wouldn't try it.
MikeB is offline   Reply With Quote
Old 12-03-2019, 9:27pm   #13
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,248, Level: 100
Activity: 9.0%
JRD77VET's Avatar
payday is friday.
forgot one
Don't chew your fingernails
Old 12-04-2019, 3:42pm   #14
Aerovette
Aerovette's Avatar
At my parent's house years ago, I had some friends over and when we would get near the deep end, the water would buzz you. You could feel the tingle.
That's the end that had the pool light in it.
No, I did not wire it up.
Old 12-04-2019, 7:09pm   #15
mrvette
Activity: 10.4%
mrvette's Avatar
That's not wiring, that's PLUMBING!!! as in gaskets/seals/glass/etc.....
Old 12-04-2019, 10:54pm   #16
BADRACR1
Barn Stall Owner #5150
Points: 41,169, Level: 100
Activity: 4.7%
BADRACR1's Avatar
Damn.
BADRACR1 is offline   Reply With Quote
Old 12-05-2019, 11:57am   #17
Aerovette
Aerovette's Avatar
Except that a GFCI would have tripped...if whoever did it put one in. Electrical.
The Following User Says Thank You to Aerovette For This Useful Post:
Old 12-12-2019, 8:49am   #18
Activity: 19.4%
The Following User Says Thank You to Mike Mercury For This Useful Post:
