Old 11-10-2019, 7:23pm   #41
SnikPlosskin
Barn Stall Owner #93
Points: 63,649, Level: 100
Activity: 2.5%
SnikPlosskin's Avatar
Originally Posted by DAB View Post
ooooh........pretty.
you going to fill the star cut out with black later?
Yep.
The Following 3 Users Say Thank You to SnikPlosskin For This Useful Post:
Old 11-10-2019, 7:33pm   #42
SnikPlosskin
Activity: 2.5%
Tomorrow clear coats. About ten.
Old 11-24-2019, 2:09pm   #43
SnikPlosskin
Activity: 2.5%
Quick update! I’ve been buried under the weight of my own imagination so progress is slow but steady.
Had to sand off first finish attempt due to my sloppy sanding. That gold color shows every flaw! I still have a little filling work but it should be seamless.
First was several coats of vinyl sealer. Then color coat. Then a couple coats of clear. Next I filled the star detail thing with black epoxy to bring it flush like an inlay. I believe it will sand and polish nicely.
Once the epoxy has cured, I’ll be laying on about ten more coats of clear, sanding between each. Then, wet sand and polish.
Old 11-24-2019, 2:29pm   #44
SnikPlosskin
Activity: 2.5%
Did a little damage.
Old 11-24-2019, 2:31pm   #45
SnikPlosskin
Activity: 2.5%
Plus control box
Old 11-24-2019, 6:41pm   #46
SnikPlosskin
Activity: 2.5%
The more I work the worse it gets...
Old 11-25-2019, 9:39am   #47
snide
NCM Supporter '13
Points: 216,817, Level: 100
Activity: 53.6%
If you keep on digging, eventually you'll get to China.
Old 11-25-2019, 9:31pm   #48
SnikPlosskin
Activity: 2.5%
Oh boy....
Old 11-25-2019, 9:42pm   #49
snide
NCM Supporter '13
Activity: 53.6%
Oh boy....
Reported inappropriate image.
Old 11-25-2019, 9:49pm   #50
markids77
Points: 22,591, Level: 100
Activity: 10.8%
markids77's Avatar
You're almost golden now (pun intended). Flat sand until the inlay is clearly delineated with no white outline. Blend the curve on the body in and I recommend a tiny fineline tape line on the edge of the epoxy... either natural wood or a contrasting (silver?) stripe around so there is a definite break between the inlay and the body. Seal, color and clear; Bob's your uncle.
Old 11-25-2019, 9:51pm   #51
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,248, Level: 100
Activity: 9.0%
JRD77VET's Avatar
biggrin
How 'bout "inappropriate language"
Old 11-26-2019, 9:37am   #52
SnikPlosskin
Activity: 2.5%
That is a great idea!
Old 12-01-2019, 10:57pm   #53
SnikPlosskin
Activity: 2.5%
Getting back on track. Blended color coat - 2 coats of clear.
Love this color!
The Following 4 Users Say Thank You to SnikPlosskin For This Useful Post:
Old 12-01-2019, 11:05pm   #54
DAB
Barn Stall Owner #4
Points: 172,146, Level: 100
Activity: 9.4%
DAB's Avatar
Looking gewd!
DAB is offline   Reply With Quote
Old 12-05-2019, 9:40pm   #55
SnikPlosskin
Activity: 2.5%
Another set back. Got some cracking where I put color over clear. Just on one isolated area. Should be able to fix but weird as hell. Will post pic tomorrow. At first I thought they were scratches showing up. But soon it was clear it is fracturing. Real organic lacquer is some weird shit. With poly that would have been zero issue. I’m going for fifties Les Paul Good Top finish.
