Old 10-07-2022, 7:32pm   #181
Big bob
Points: 10,743, Level: 71
Activity: 99.6%
Big bob's Avatar
Originally Posted by LATB View Post
I may burn some. I do have a local guy with a pit nearby who will haul debris for me. Will go that route unless it gets too costly.
That is what you bought the grapple for pile it up for a bonfire party.
With the box blade drop the teeth low and crank up it on the back and rake your yard at the same time.
Big bob is offline   Reply With Quote
Old 10-07-2022, 7:44pm   #182
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 107,113, Level: 100
Activity: 25.6%
JRD77VET's Avatar
Originally Posted by Big bob View Post
Also the PTO will remove arms and legs instantly mind any lose clothing.
Looking thru one of my FIL farming magazines and they were doing a product test on a post hole digger.
Guy in the photos had an old T shirt on and the photographer had a motor driven camera. The shielded PTO shaft grabbed his T shirt and almost instantly wrapped it around tearing a perfect square off the front ( waist to neck and shoulder width) . It was wrapped around and did quite a few revolutions before he had any reaction to what was happening. Only then did he move back but if it was a newer/stronger T shirt, it would have been over
THINK on EVERYTHING before doing.
JRD77VET is online now   Reply With Quote
The Following 2 Users Say Thank You to JRD77VET For This Useful Post:
Old 10-07-2022, 8:43pm   #183
CurtP
Points: 1,340, Level: 21
Activity: 5.8%
CurtP's Avatar
Originally Posted by JRD77VET View Post
Neighbor flipped his over backwards attempting to put out a root ball (stump) from a tree.
I had an uncle that wasn't so lucky. The tractor crushed him. Closed casket funeral.
Had an aunt get her foot caught in an auger. Lost most of it, got gangrene and lost what was left.
Grandfather was working on a running combine. It engaged and he got his hand caught up in the belts. Lost his thumb and ring finger.
Growing up, neighbor kid down the road was riding on the disc, jumping off to grab rocks in the field. Fell off and was killed when the disc went over him.
I've had a few close calls. Learned pretty quick not to **** around with heavy machinery.
CurtP is offline   Reply With Quote
The Following 2 Users Say Thank You to CurtP For This Useful Post:
Old 10-07-2022, 9:26pm   #184
MadInNc
Points: 155,634, Level: 100
Activity: 48.3%
MadInNc's Avatar
The work on a farm is not for the weak. Reason why many moved to the city generations ago.
MadInNc is online now   Reply With Quote
The Following 4 Users Say Thank You to MadInNc For This Useful Post:
Old 10-08-2022, 7:36am   #185
TheHammer
Points: 11,056, Level: 72
Activity: 46.5%
TheHammer's Avatar
Gameroom Barn Bucks: $2149
I had a boss when I was kid who had a few horses. He was fecking around with his tractor, got his shirt caught in the PTO and drug his arm into it. Ripped his arm right off. Arrrrr..
TheHammer is offline   Reply With Quote
Old 10-08-2022, 7:39am   #186
Points: 110,955, Level: 100
I’ll take that as a compliment. It applies to construction also. I’m 63 and can outwork most kids half my age.
LATB is online now   Reply With Quote
Old 10-08-2022, 9:14am   #187
Big bob
Activity: 99.6%
Big bob's Avatar
Go slow when shoving branches they can shoot through the grapple at amazing speed.
Old 10-08-2022, 10:15am   #188
ricks327
Points: 1,927, Level: 27
Activity: 17.4%
ricks327's Avatar
Not a tractor or a farm guy but why is the canopy so high?
ricks327 is online now   Reply With Quote
Old 10-08-2022, 11:16am   #189
Big bob
Activity: 99.6%
Big bob's Avatar
So you don't hit your head.
The Following User Says Thank You to Big bob For This Useful Post:
Old 10-08-2022, 3:34pm   #190
Indeed. I made a point of grabbing from the side for that reason, and don't want to poke one in the grill.
Old 10-08-2022, 3:37pm   #191
It's mounted on the top of the ROPS. I have seen some aftermarket types that mount below the ROPS. This one is OEM.
Correct. I was concerned I would hit my head when entering the seat.
Old 10-09-2022, 7:13am   #192
Tikiman
Barn Stall Owner #117
Points: 17,779, Level: 92
Activity: 80.8%
Tikiman's Avatar
Rule 101 drop your hydrolic implements when not in use.
Okay. So I have a question regarding that. Whenever I see trucks with booms parked for any length of time, they all seem to park them with their boom buckets way high in the air.
Why do they do this?
I am referring to the type of buckets that linemen might use to trim trees or service power lines.
Tikiman is offline   Reply With Quote
Old 10-09-2022, 7:18am   #193
I think it’s so no one will get into the bucket. Similar to a crane lifting a job box or welder/compressor etc. in the air. Keeps the lowlife assholes from stealing or vandalizing.
The Following 2 Users Say Thank You to LATB For This Useful Post:
Old 10-09-2022, 7:42am   #194
Rodnok1
Points: 31,486, Level: 100
Rodnok1's Avatar
Yep its to keep idiots out of them. Their hydraulic controls are a better quality I'm sure than tractor units.
Also they leave tools in buckets sometimes.
Rodnok1 is online now   Reply With Quote
The Following User Says Thank You to Rodnok1 For This Useful Post:
