Share Thread Tools
Old 09-27-2020, 9:01pm   #1
aerovette
Barn Stall Owner #7734
Points: 52,234, Level: 100
Activity: 48.7%
aerovette's Avatar
Gameroom Barn Bucks: $102859
Default IAC on 2002 Rodeo $#%^#@ !!!
I'll start with cliffs...
Testing the IAC for movement and it came apart. Can't find the pintle.
Does a new one need adjustment or will it plug and play?
My parent's just got ripped off for about $1600.00 from a mechanic that ultimately said "I did all I can, I can't fix it".
So I started poking around at the things they didn't check. I pulled the IAC and turned the key to check for movement. On the last try, it spin the spring loaded pintle out and it flew somewhere. I ordered a new IAC and can't tell whether it self adjusts or if I need to do something with it. I can't compare the pintle extended and retracted distance, because the pintle is gone.
I "think" it will adjust itself, via the computer but I have no idea.
This Rodeo is low mileage, driven by a family friend's mother. Well maintained, but in the last three weeks it has been shitting all over itself. They took it to Christian brothers who had it for two weeks and threw parts at it and ultimately gave up.
Here are the symptoms
1. Erratic idle rises and falls between 900 and 1100 RPMs
2. P0351 code (bad coil)
3. THREE coils were tried out and the same code still appears
4. Horrible shudder and tire barking slam in to gear at take off. (may be unrelated)
aerovette is offline   Reply With Quote
Old 09-28-2020, 2:30am   #2
mrvette
Barn Stall Owner #101
Points: 87,899, Level: 100
Activity: 36.2%
mrvette's Avatar
Gameroom Barn Bucks: $1137246
I was having operational issues with my injected '72 vette, and I found the fuel pressure was too low....running 30 psi instead of the needed 43.5 jacked it up and it runs fine.....
The Following 2 Users Say Thank You to mrvette For This Useful Post:
Old 09-28-2020, 6:42am   #3
Rodnok1
Points: 6,264, Level: 54
Activity: 96.0%
Rodnok1's Avatar
Gameroom Barn Bucks: $311422
Alot of newer car issues are grounding problems, I'd start with main battery connections and clean the main ground to start with then find the ground for IAC and clean/check it. Since showing bad coil I'd check the wiring to them and the ground for ICM.
At least on my car one bad ground will back feed and cause issues elsewhere that are unrelated.
I will assume the TB has been cleaned throughly.
Rodnok1 is offline   Reply With Quote
The Following User Says Thank You to Rodnok1 For This Useful Post:
Old 09-28-2020, 7:36am   #4
JetMechZ16
Points: 28,642, Level: 100
Activity: 48.6%
JetMechZ16's Avatar
Gameroom Barn Bucks: $855071
My Z06 died on me on a twisty mountain road. No start but a fire and die once in a while. After getting it home and checking fuel pressure I had 12 psi, should be 58. Everyone said change the fuel pump, which is a huge pain in a later model C5. I finally found the fuel pump ground and it was loose tightened it up and everything worked great. Saved me maybe $900.00 which is what they wanted to change it. Bad grounds can cause all sorts of strange issues.
The Following 2 Users Say Thank You to JetMechZ16 For This Useful Post:
Thread Tools
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright 2009 - 2020 The Vette Barn
