Old 01-09-2011, 7:59pm   #1
lutzdog
Points: 11,003, Level: 72
lutzdog's Avatar
Gameroom Barn Bucks: $595211
Default Drain Gas Tank
Unfortunately I ran out of warm time to paint the car so I am on hold and I want to get rid of the nasty ethanol gas that is in the tank and put in some non ethanol with some stabil so I don't have any surprises when I start painting again. I have read a couple of methods so as not to duplicate work.
1 is
Pump Operative
Remove LF fuel rail cover
DIS fuel return hose from fuel rail
Attach & clamp a length of flexible fuel hose (clear) to the fuel rail return pipe
Insert open end of fuel hose into an approved container
RUN ENG until it stalls
Reconnect fuel return hose to fuel rail
Continue procedure if the RT fuel tank still contins fuel
Position an approved container under the RT tank fuel sender
Attach a length of flexible fuel hose (clear) to an air operated pump device
Wrap shop towel around the fuel sender fuel feed pipe (jet pump to LF tank) at the RT fuel sender
DIS fuel sender fuel feed pipe (jet pump to LF tank) at the RT tank fuel sender
Remove plastic CON retainer from the fuel sender nipple
Attach & clamp the flexible fuel hose from pump device to the fuel sensor nipple
Drain RT tank until no fuel comes out
DIS pump device from the RT tank fuel sender nipple
Install plastic CON retainer to the fuel sender nipple
Plug or cap the fuel sender nipple and the fuel sender fuel feed pipe.
the second is http://www.aacorvette.com/pdf/aa_fue...structions.pdf
I am cautious about either of these and would like to hear from the seasoned members as to which method they recommend or another method preferably with pics lol that they recommend.
I have a 97 vette so i already know that it is its own beast such as the double fuel lines to the drivers side fuel rails.
Old 01-31-2011, 7:37pm   #2
lutzdog
lutzdog's Avatar
well since i got no reply's I went to the other site which i don't like to do and I used the idea of a fuel pressure gauge with a pressure relief button. A full tank was drained in twenty minutes. Thanks phil for the help.
Old 01-31-2011, 9:06pm   #3
Tulsa Vette Guy
Points: 4,253, Level: 44
Tulsa Vette Guy's Avatar
Gameroom Barn Bucks: $13
Good information, Thanks
Old 01-31-2011, 9:09pm   #4
PortDawg
Charter Member - C3 Mod
Barn Stall Owner #34
NCM Supporter '15
Points: 30,980, Level: 100
PortDawg's Avatar
Gameroom Barn Bucks: $173
So it's empty? Cool...
Old 02-01-2011, 10:09am   #5
Bucwheat
Points: 49,877, Level: 100
Bucwheat's Avatar
A buddy of mine messed up two outboard motors on his boat using the dam E-85 crap, had to take it into a Marine mechanic.
Old 02-03-2011, 12:38pm   #6
lutzdog
lutzdog's Avatar
yeah got it drained and filled with non ethanol gas with stabil. It was too close for my comfort level to let it sit in there anymore.
