Old 06-08-2010, 6:09am   #1
zz4vetteguy
Points: 19,739, Level: 97
zz4vetteguy's Avatar
Gameroom Barn Bucks: $9916
Default Does size matter?
When it comes to spark plug wires?
I have been looking around for plugs and wires for when I do the headers and noticed different size wires....8.5mm, 9mm, 10.2mm, etc....what do I need to look for?
Street Dreams Corvette Club
Old 06-08-2010, 6:54am   #2
allthrottleandsomebottle
Points: 23,599, Level: 100
Gameroom Barn Bucks: $1005893
Once more..............OEM, period!
Old 06-08-2010, 11:10am   #3
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
The Corvette wires are so short the OEM wires are good for high power applications, more power than most sane people will ever see.
Old 06-08-2010, 3:42pm   #4
Points: 35,065, Level: 100
A new set of stock GM wires are all you need.
I'm using the 10.4mm Taylor Thundervolt wires, which have worked fine for me, but at $75/set, aren't exactly the cheapest game in town.
While there may be no real performance benefit with the expensive wires, the boots on the Taylors are noticeably better than stock (and MSD wires too), they make for a very positive and secure connection at both the coil and plug.
Don't know if I'd ever spend that much on wires again, but with 20k miles or so on them (with no metal insulators or kool sox), I have no regrets in choosing them.
Old 06-08-2010, 5:55pm   #5
zz4vetteguy
I am asking cause my father (who lives) was on ebay and found some NGK plugs and wires for $100.00
NKG & 10mm
Old 06-08-2010, 6:25pm   #6
For what you get, that doesn't look like a terrible buy, because the iridium plugs alone run around $50/set...but it does not say which heat range/gap plugs are included (TR5IX, TR55IX, TR6IX).
I would at least ask the seller for that clarification before buying.
The equivalent copper electrode NGK's are a bunch cheaper, more like $2 ea, not $7ea, but downside is they are not as long-lasting as the iridium.
I'm running TR6IX iridiums in mine (with close to 12:1 CR), but for a stock engine, the stock heat range/wide gap TR55 (copper) or TR55IX (iridium) are the better choice.
Old 06-08-2010, 6:41pm   #7
1TZSLO
Points: 5,654, Level: 51
1TZSLO's Avatar
Gameroom Barn Bucks: $377
Hmm I am guessing the OEM wires are like what 60bucks? Since Bosch is like 70 at Autozone. Well RK chevy parts dept is closed or I would have called haha.
I usually bought my TR6's from Autozone pretty cheap.
TR55s are like 3 bucks a pop there when I jsut called. The Copper type. Iridium is like 7 bucks a pop.
Arctic White 97 C5 Coupe
NOT STOCK
Old 06-08-2010, 7:33pm   #8
71corv
Points: 7,200, Level: 59
71corv's Avatar
Gameroom Barn Bucks: $1383
As mentioned above, stock wires and a set of "koolsox".
Gene
Old 06-08-2010, 8:10pm   #9
$25-30 if you know where to look.
Add another $30-40 for the pre-cut insulating sox, and suddenly the 'expensive" wires don't seem all that unreasonable.
Old 06-08-2010, 10:25pm   #10
thegreenman
I might have to give Taylors a try. I can't feel the stock or MSD wire lock onto the plugs and it bugs me. Thanks for the tip.
Old 06-22-2010, 8:09am   #11
zz4vetteguy
they are the T55IX
Old 06-26-2010, 12:14pm   #12
zz4vetteguy
ok, so I went ahead and picked them up from Ebay...should be here in a week.
Brian, after next weekend's C&C if you are not busy right after, would you mind stopping by my folk's house with me, taking a look at what is in the box and letting me know what else I need?
