12-15-2019, 6:59pm | #1 | ||||||
Guest
Gameroom Barn Bucks: $1082
Advance Auto Hosed Me...
Pickup has had the battery cable come loose from the solenoid twice now. Few weeks ago I went to Advance and got a new solenoid, figuring the copper bolt was stretching, soft , broke, whatever. Finally got around to swapping it tonight. Get the starter off, here it's the wrong solenoid. Wtf? Advance is still open, jump in the Vette and head there starter in hand. They look, they don't even list a solenoid for it. Uhhh, 03 Chevy pickup, no solenoid? Not even listed to order? Nope. Reman starter for $175. Mine is an AC Delco and not that old, wasn't interested in handing them that with $175 for a generic reman unit. They don't stock the AC Delco. Got credit for the wrong part and left... Came home and threw it back together. |
12-15-2019, 7:00pm | #2 | ||||||
Guest
They also told me it's common for the website to list a part and it either doesn't fit or they don't have it.
The Following User Says Thank You to K-Spaz For This Useful Post: |
12-15-2019, 7:14pm | #3 | ||||||
I'm to the point i write down the part number I want and go in and say fetch it. When they ask what it fits just say it doesn't fit anything I want that part.
12-15-2019, 7:19pm | #4 | |||||||
But to your point, typically the stores don't have the part and i end up driving tho the warehouse.... |
12-15-2019, 7:19pm | #5 | ||||||
The Following 5 Users Say Thank You to Mike Mercury For This Useful Post: |
12-15-2019, 8:27pm | #6 | ||||||
NAPA...Never Any Parts Available.
12-15-2019, 8:32pm | #7 | ||||||
2020 Election Expert
Gameroom Barn Bucks: $1134156
cliffs?
12-15-2019, 8:33pm | #8 | ||||||
Gameroom Barn Bucks: $18284
get a nylock for about 60 cents and try that.
12-15-2019, 9:10pm | #9 | ||||||
Guest
Might have to do that if it does it again. Or a lock-nut with the sides dimpled. Not sure it'll take the heat down there. The wiring has burns on it so even with the heatshield blocking the manifold it still gets pretty warm.
12-15-2019, 9:13pm | #10 | ||||||
12-15-2019, 9:21pm | #11 | |||||||
Location: Falling down is an accident, staying down is a choice
Gameroom Barn Bucks: $3524
Get a spark plug heat sock for the wire, the kind they use for headers |
12-15-2019, 9:35pm | #12 | ||||||
12-15-2019, 9:44pm | #13 | |||||||
Guest
The whole thing started when I worked on the exhaust manifold bolts. I had a bar in there to pry the manifold away from the head so I could EZ out, TIG weld, or just vice grips the broken bolts out. It fell down on the starter hot wire and sorta heated that up (like glowing red). Ruined the battery, or so I thought. Might have annealed that bolt and it either keeps stretching or it is in the process of breaking. Looked fine when I had it out today though so I took a chance. |
12-15-2019, 9:55pm | #14 | ||||||
The Hooptie Whisperer
Gameroom Barn Bucks: $1975165
People still buy parts at local parts stores beyond fuses and Gojo?
12-15-2019, 9:58pm | #15 | |||||||
Guest
But yes, most times when I need a part I don't have a week to mess around. |
12-15-2019, 10:00pm | #16 | |||||||
The Following User Says Thank You to 96 Vette CE For This Useful Post: |
12-15-2019, 10:17pm | #17 | ||||||
Gameroom Barn Bucks: $3016342
Can't make this sheit up...
Yeah, I started doing the same thing since the last time I was there, the mouth-breather behind the counter asked if Corvette was a Ford product.
12-15-2019, 10:23pm | #18 | ||||||
12-15-2019, 10:47pm | #19 | ||||||
Gameroom Barn Bucks: $12721
I once bought some battery terminals from the local NAPA. Then, this happened:
The Following 3 Users Say Thank You to Mick For This Useful Post: |
12-15-2019, 10:57pm | #20 | |||||||
Guest
