05-17-2021, 4:49pm | #1 | ||||||
Ever wire a car?
Been working on doing the wiring in my 47 Olds with a Painless Wiring kit. I did all the dash wiring, as well as redoing the gauges for 12 volt use, on my bench in the cellar over the winter. Got that done and mounted the dash back into the car. I left pigtails for all the dash wiring so I could hook it all up to the fuse panel once it was back in the car. I figured it would be easier to do it that way as laying on my back trying to do it in the car would kill me!. It's taking me days just to get that done. Most of it on my back, good thing I did the dash on the bench! Then running and taping the rest of the interior harnesses and getting them in to place. It's not too bad running the harnesses, but taping them up isn't a lot of fun. I've gotten the interior done, and the run to the trunk for tail lights and such, and ran the engine section through the firewall, but that's about as much as I can do for now. At least til I get the front sheet metal on. All the exterior lights won't go in til I paint the whole car.
Just a couple pics to show the progress: Last one is what the dash looked like when I started with it. |
The Following 19 Users Say Thank You to 86RAG For This Useful Post: |
05-17-2021, 4:57pm | #2 | ||||||
SOME Real Barner
Gameroom Barn Bucks: $2034428
Universal kit, or specific year/make/model kit?
05-17-2021, 5:00pm | #3 | ||||||
I'm probably going to need to do this for my Charger. I'm going to make a nail-board layout of the existing harness and make a new harness so I can put it in like the factory.
The Following 4 Users Say Thank You to Aerovette For This Useful Post: |
05-17-2021, 5:22pm | #4 | ||||||
SOME Real Barner
The Following 7 Users Say Thank You to Strats-N-Vettes For This Useful Post: |
05-17-2021, 5:27pm | #5 | |||||||
Only when somebody really pisses me off. Oh. Oh. You meant actually wir....um, just nevermind. |
The Following 6 Users Say Thank You to Bill For This Useful Post: |
05-17-2021, 5:28pm | #6 | ||||||
Looks good and yes I've done a few. Under the dash the bad one especially on the back. I make long run to goto back of the car then cut and put ends on after routing the wires so the clips and connectors don't make it harder. Also i add grounds by the lights that mfg use the housings for grounds. Requires new sockets or a jumper wire from housing but it's worth it.
Good luck. |
The Following 5 Users Say Thank You to Rodnok1 For This Useful Post: |
05-17-2021, 5:32pm | #7 | ||||||
Barn Stall Owner #74
The Following 9 Users Say Thank You to 99 pewtercoupe For This Useful Post: |
05-17-2021, 5:35pm | #8 | ||||||
The Following 4 Users Say Thank You to Bill For This Useful Post: |
05-17-2021, 5:41pm | #9 | ||||||
The Following 2 Users Say Thank You to 86RAG For This Useful Post: |
05-17-2021, 5:42pm | #10 | ||||||
05-17-2021, 5:48pm | #11 | |||||||
All the terminals I'm using are non insulated and then I go over them with adhesive lined heat shrink. I hate using insulated terminals, ugly as sin |
05-17-2021, 5:49pm | #12 | ||||||
05-17-2021, 5:58pm | #13 | ||||||
VB Dad of the Year
The extent of GWiz and my wiring expertise is to swap the entire wire harness from her 96 to her 94 to support the ODBII vs. ODB1 incompatibility.
Doing what you do is not in my wheelhouse. |
The Following 4 Users Say Thank You to Datawiz For This Useful Post: |
05-17-2021, 6:10pm | #14 |
Gameroom Barn Bucks: $555
Back in the 70's when I was building hot rods, I had to make my own wire harness. So much easier now with the painless and knock off wire harness that are all color coded and labeled. Im running a Speed way universal harness for my '32 Ford Cabriolet. Let's see some pics of your '47 Olds....
The Following 8 Users Say Thank You to zeek For This Useful Post: |
05-17-2021, 6:17pm | #15 | |||||||
I switched to weatherpak style connections for any new installs even on older cars. Wish we had those way back as wiring sucks when everything is exposed and corrodes. I have scotch lock nightmares regularly from trailer fixing. |
05-17-2021, 6:21pm | #16 | ||||||
Yep, 1965 Corvette.
The original somehow grounded out and about burned the car to the ground. It filled the interior with smoke in a matter on minutes. If I had been going fast, nowhere to turn off to from the road I was on, etc...it would have been bad. Old wiring wasn't meant to last very long. Good job! |
The Following 3 Users Say Thank You to Grey Ghost For This Useful Post: |
05-17-2021, 6:27pm | #17 | |||||||
Edit: using packard 56 terminals where needed, like on ignition switch, light switch, and wiper switch. |
05-17-2021, 6:28pm | #18 | ||||||
Barn Stall Owner #747-400
05-17-2021, 6:29pm | #19 | ||||||
It wouldn't have been in mine, if not for a kit like Painless with all the wires color coded and marked about every foot!
05-17-2021, 6:34pm | #20 | ||||||
Barn Stall Owner #113
Gameroom Barn Bucks: $306898
Did you ask @aerovette to help?
The Following 7 Users Say Thank You to The_Dude For This Useful Post: |
