Old 10-07-2015, 3:47pm   #1
son93sl2
Points: 9,834, Level: 68
son93sl2's Avatar
Gameroom Barn Bucks: $352394
Default Putting Pipe under driveway
So i'm building a home and thinking about building in items to help with future expandability for electrical items like exterior lighting or an electric dog fence. Our driveway is not poured yet so I can put a pipe that runs under the concrete. What size pipe should I get and is there a special kind of PVC pipe? What thickness pipe I should get?
son93sl2 is offline   Reply With Quote
Old 10-07-2015, 3:59pm   #2
SilverBullitt
Points: 5,263, Level: 49
SilverBullitt's Avatar
Gameroom Barn Bucks: $880
I just built a home and had that done under my driveway and all my sidewalks. They used a piece of plastic electrical conduit that was designed to run underground. It looked about 3.5"-4" in diameter.
One tip if you do this, be sure they put it pretty deep and add extra rebar & wire mesh over it. I already have a hairline crack on the driveway right above that pipe. The builder told me this was likely when they were installing it, and his forecast came true.
SilverBullitt is offline   Reply With Quote
The Following User Says Thank You to SilverBullitt For This Useful Post:
Old 10-07-2015, 5:29pm   #3
mrvette
Barn Stall Owner #101
Points: 133,205, Level: 100
Activity: 8.6%
mrvette's Avatar
Sounds about right, not that a crack says much....really, hell, here in Florida, a one inch offset in sidewalks/drives is not much....should see some spots....
I been lucky so far....just a filler over a hump in the front sidewalk, drive has been fine.....knocking on my solid mahogany desk.....
mrvette is online now   Reply With Quote
Old 10-07-2015, 5:34pm   #4
VITE1
Barn Stall Owner #69
Bantayan Kids '14,'15,'17
Points: 62,271, Level: 100
Activity: 5.0%
VITE1's Avatar
Gameroom Barn Bucks: $1084134
As others have said bury it deep and make sure it's reinforced. Also make sure you get it marked off really well. I had it done in three places and could only find two after a few years.
VITE1 is offline   Reply With Quote
Old 10-07-2015, 5:35pm   #5
HellCat
Points: 4,806, Level: 47
HellCat's Avatar
Gameroom Barn Bucks: $103430
How do you put a conduit under an existing driveway or sidewalk? Ground is sand.
HellCat is offline   Reply With Quote
Old 10-07-2015, 5:43pm   #6
mrvette
Activity: 8.6%
mrvette's Avatar
Simple in the case of a sidewalk, ASSuming it's a typical yard wide across the lawn in front, making a tree lawn as a separate chunk of grass from your front lawn .......it's only about 4-6" deep, an so to pick out a slab to tunnel under, they are segmented, and to dig out from each side and then to connect into the middle, and run the pipe through.....that's about all I did, under an expanse of drive, I have not the gear or the DRIVE!!!!!
Old 10-07-2015, 5:44pm   #7
VITE1
Activity: 5.0%
VITE1's Avatar
Pound it.
The Following User Says Thank You to VITE1 For This Useful Post:
Old 10-07-2015, 5:46pm   #8
Jeff '79
Barn Stall Owner #2112
Fantasy Football Champ '14,'16,'20
Points: 162,095, Level: 100
Jeff '79's Avatar
Gameroom Barn Bucks: $3043611
Jeff '79 is offline   Reply With Quote
Old 10-07-2015, 5:57pm   #9
99 pewtercoupe
Barn Stall Owner #74
Bantayan Kids '13,'17
Points: 94,793, Level: 100
Activity: 5.8%
99 pewtercoupe's Avatar
I couldn't believe this thread got this far without a laying pipe reference
You guys are slipping.
99 pewtercoupe is online now   Reply With Quote
The Following User Says Thank You to 99 pewtercoupe For This Useful Post:
Old 10-08-2015, 8:48am   #10
son93sl2
son93sl2's Avatar
I asked the builder, he said 1" pipe no problem, they do it all the time. 4" sounds like it's too big. Any other thoughts?
Old 10-08-2015, 9:14am   #11
DAB
Barn Stall Owner #4
Points: 171,953, Level: 100
Activity: 10.1%
DAB's Avatar
if you think you need 2, put in 4. not that expensive now to add some spares.
run them well past the edge of the planned driveway, say 10 feet, then have a sweep elbow up to a capped end. you can always dig back down and join to them later. buy a pair of fake boulders to cover the stubs.
DAB is online now   Reply With Quote
Old 10-08-2015, 9:50am   #12
Points: 158,557, Level: 100
Activity: 30.6%
if 1" won't cut it, then go with two 1"... seperated a little.
Like SilverBullitt already mentioned, too large a diameter and you setup a place for the concrete/asphalt to develop a crack.
Mike Mercury is online now   Reply With Quote
Old 10-08-2015, 10:09am   #13
son93sl2
son93sl2's Avatar
I think 1" would be fine. So I should get long pieces of PVC and join them together for the builder yeah? I can't just get a 20' piece and have it fit in my car.
Old 10-08-2015, 10:16am   #14
DAB
Barn Stall Owner #4
Activity: 10.1%
DAB's Avatar
Grey PVC conduit typically comes in 10' sections. Joined with PVC glue.
Old 10-08-2015, 10:19am   #15
Rob
Barn Stall Owner #14
Barn Raising II,III Chef
NCM Supporter '11,'12,'13,'14,'15,'16,'17,'20
Ukranian Famers are the modern day Chuck Norris
Points: 83,084, Level: 100
Activity: 4.0%
Rob's Avatar
Just get 250 1" long pieces of 1" pipe and you can make it exactly the length you want
Rob is offline   Reply With Quote
Old 10-08-2015, 10:24am   #16
DAB
Barn Stall Owner #4
Activity: 10.1%
DAB's Avatar
I'm gonna say your strengths are not related to construction.
The Following User Says Thank You to DAB For This Useful Post:
Old 10-08-2015, 10:32am   #17
RedLS1GTO
C4 Mod
Points: 59,024, Level: 100
Activity: 51.4%
RedLS1GTO's Avatar
If a truck would help you out, give me a shout.
RedLS1GTO is offline   Reply With Quote
Old 10-08-2015, 11:01am   #18
onedef92
Vette Barn Deacon
Points: 129,023, Level: 100
onedef92's Avatar
Gameroom Barn Bucks: $21169452
Would this be a good time to consider a heated driveway, too to melt ice and snow?
onedef92 is offline   Reply With Quote
Old 10-08-2015, 12:41pm   #19
Activity: 30.6%
Old 10-08-2015, 2:44pm   #20
bill_daniels
Points: 222,160, Level: 100
bill_daniels's Avatar
I disagree. That way, he can return any excess pipe to the store for a refund. He won't pay for an extra inch of pipe he doesn't need.
This is why accountants should always be the ones making decisions about construction related things.
bill_daniels is online now   Reply With Quote
The Following User Says Thank You to bill_daniels For This Useful Post:
