Old 06-23-2014, 9:04pm   #1
Black95
Barn Stall Owner #204
Points: 13,600, Level: 80
Activity: 2.5%
Black95's Avatar
Gameroom Barn Bucks: $403724
Default Duh! Read the owner's manual!
Went to a small town car show this past weekend. Showed the car with the hood open for several hours, so thought I should remove the hood light bulbs because I didn't want them on for several hours at the show. When I got home, I got to thinking, that it would be easier to splice in a switch to the line or pull which ever fuse controled the hood lights, so looked in the owner's manual to find out which one it was. Came across page 6-73 in the owner's manual for my 1995 and there is plain sight "Underhood Lamps Fuse: Your Corvette has one single fuse underhood for the underhood lamps. The fuse is under the hood on the driver's sidemarker lamp assembly. Leaving your hood open and your underhood lams n can drain your battery. If you need to keep the hood oen for an extended period of time, remove the underhood lamps fuse."
Corvette thought of us again at car shows. Maybe I will have to spend more time reading the owner's manual!
Black95 is offline   Reply With Quote
Old 06-24-2014, 1:26am   #2
DukeAllen
Points: 42,433, Level: 100
Activity: 99.5%
DukeAllen's Avatar
How many asked what kind of Nissan it was
DukeAllen is offline   Reply With Quote
The Following User Says Thank You to DukeAllen For This Useful Post:
Old 06-24-2014, 6:38am   #3
Black95
Activity: 2.5%
Black95's Avatar
Only one!!! But I was surrounded by Mustang Cobras and boy do those guys like to talk about their cars! The one to my right was a 2001 32 valve aluminum engine, so I had to hear all about it. It was a garage-trailer queen. At least the two 'stangs on my left were drivers. They drove theirs to the show and even drove them off in the middle of the show for a beer break, but didn't bring me back one.
The Following User Says Thank You to Black95 For This Useful Post:
Old 06-26-2014, 5:47am   #4
WW7
Points: 11,123, Level: 72
WW7's Avatar
The rotten bastards,they could have brought you one back......
When I go to car shows or cruise-ins, I just unplug the under hood lights at the front of the car..There's one plug near the overflow tank that you unplug and both lights go out...When your done just plug it back in........WW
WW7 is offline   Reply With Quote
The Following User Says Thank You to WW7 For This Useful Post:
Old 06-26-2014, 7:15am   #5
Black95
Activity: 2.5%
Black95's Avatar
Thanks! Just looked under the hood and found that connector. Will use it in the future.
Old 07-03-2014, 12:27pm   #6
hcbph
Points: 7,854, Level: 62
hcbph's Avatar
Gameroom Barn Bucks: $575
Default Underhood lights
It's either Eckler's or Corvette Center that has a little wiring kit that's plug and play. Unhook the 2 underhood lights, plug this little setup into the wiring and it had a pushbutton on-off switch. Very easy to use and easy to restore the lights with a push of the button.
hcbph is offline   Reply With Quote
The Following User Says Thank You to hcbph For This Useful Post:
