02-04-2023, 10:24am | #1 | ||||||
Need some plumber hot water heater advice
Replacing thermostats, heating elemts and sacrificial anode in 80 gallon State Select electric water heater (I've done the T-stats and heating elements before but not the anode). Anybody know where its located ? Apparently there are three kinds, a top mounted rod with a 1-1/16" hex head bolt separate from the hot water pipe, a top mounted inline version in series with the hot water outlet (big problem) and a side mounted one. I can't find a separate rod on top after lifting the plastic covers and looking around and I'm hoping its not an inline version. Could this fixture on the side above the Energy Guide sticker be the anode rod ?
02-04-2023, 10:26am | #2 | ||||||
In before someone asks why you are heating hot water
The Following 8 Users Say Thank You to 04 commemorative For This Useful Post: |
02-04-2023, 10:27am | #3 | ||||||
First of all it is not a hot water heater. Just a water heater. See that rubber plug on top? Take a peek under that might have to pull some insulation out to get to it.
02-04-2023, 10:31am | #4 | ||||||
Barn Stall Owner #118
Gameroom Barn Bucks: $1002672
is that PVC all over the top of that thing? |
The Following 2 Users Say Thank You to slewfoot For This Useful Post: |
02-04-2023, 10:43am | #5 | ||||||
Gameroom Barn Bucks: $2001216
The rod should be on the hot water outlet side. It threads into the top of the tank, about a 3' rod. Need head room above the tank to pull it completely out...
Did you just follow my thread? |
02-04-2023, 10:48am | #6 | ||||||
If its an inline rod under that blue recirculating timer pump then its all over that lower nut is corroded badly - this one is 18 years old and I looked at new tanks this size and wife nearly had to call for the crash cart...More inflation to thank for it I guess.
02-04-2023, 11:04am | #7 | ||||||
Even brand new you will need an impact to get it out. Put some wd 40 or something on it. Then just barely turn it with the impact then hand remove and install. I there is anything left of it you don't want it whipping around inside tearing shit up.
02-04-2023, 11:08am | #8 | |||||||
Hmmm, my two old water heaters are still down in the crawl space, can't lift them out, without help....I'll try to remove the rods to see how badly they have disintegrated.... https://www.thevettebarn.com/forums/...d.php?t=131128 |
02-04-2023, 11:09am | #9 | ||||||
You are looking for a 1-1/16 hex yours will not be in a pipe just a solid hex.
https://www.google.com/search?q=stat...&ie=UTF-8#ip=1 https://www.amazon.com/Aluminum-Eau-...%2C2466&sr=8-3 |
02-04-2023, 1:19pm | #10 | |||||||
Gameroom Barn Bucks: $12721
Good luck! |
02-04-2023, 1:28pm | #11 | ||||||
I am sure the cheater pipe would work but I was on my own on this. And many space is a problem. Who did you get to bear hug your tank?
02-04-2023, 2:20pm | #12 | ||||||
02-04-2023, 3:22pm | #13 | ||||||
I admire you trying to fix it and I'd probably do the same but after seeing your pictures I Personally wouldn't be messing with that thing. What scares me the most is your PVC piping. Not sure I'd have the outlet of my water heater made from PVC. By the looks of it it's pretty old too by the color. I thank our builder for using copper throughout my house and my water heater is gas!!
02-04-2023, 3:27pm | #14 | ||||||
When it is empty, that is true. Once it is in use, it is a hot water heater. If the thermostat is set to 150 degrees, but the water is 145 degrees, is that 145 degree water not hot?
02-04-2023, 3:29pm | #15 | ||||||
02-04-2023, 3:52pm | #16 | ||||||
02-04-2023, 3:54pm | #17 | ||||||
02-04-2023, 3:56pm | #18 | |||||||
02-04-2023, 6:03pm | #19 | ||||||
02-04-2023, 6:11pm | #20 | ||||||
