03-26-2022, 3:11pm | #1 | ||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
Repairing a cracked wheel?
Anyone ever had a cracked wheel repaired, if so did it hold? When I uncovered my vette last weekend, one of my tires was 15 lbs low, never lost an ounce in 7 years. Pulled the wheel and tire off today, sure enough cracked wheel - thank you crappy Michigan roads. The crack is on the inner lip (bead), perpendicular to the edge. All indications are that this type of crack can be welded. Anyone have experience with this?
The wheels are ZR1 replicas that where powder coated by the previous owner, so I don’t know the powder color. If I did, I’d attempt to buy a replacement wheel. Otherwise it looks like a new set of wheels |
03-26-2022, 3:30pm | #2 | |||||||
Gameroom Barn Bucks: $2115673
I have done much grinding &sanding, some at Atomic plants and I worked the welded bead over. It came out real good. You could not see where we worked! Only need a very small weight to bring wheel and tire up to balance spec. When he got rid of the car (Camaro) years later was still fine! Never leaked! A serious pro shop should have no problem doing that work! |
The Following User Says Thank You to 6spdC6 For This Useful Post: |
03-26-2022, 3:53pm | #3 | ||||||
Gameroom Barn Bucks: $1005893
https://weldcraftwheels.com/
These guys widened a pair into 18 x 12 wide for me.....great work and NDT testing. Have them do it and know its done right if you don't do it yourself |
The Following User Says Thank You to allthrottleandsomebottle For This Useful Post: |
03-26-2022, 5:28pm | #4 | |||||||
Good to know others have successfully repaired/modified wheels |
The Following 2 Users Say Thank You to Black94lt1 For This Useful Post: |
03-26-2022, 5:36pm | #5 | ||||||
Most larger cities have a rim repair shop and yes it works. I had a serious gouge fixed years ago.
