12-09-2019, 9:04pm | #1 | ||||||
Gameroom Barn Bucks: $3632152
Computer ?
I have an older Antec case that has a 120mm rear fan. The fan is almost done. It plugs directly into the PS. I put a new fan in that plugs into the MB. It wouldn't boot up. Put the old one back in and it put up a repair message and wouldn't boot up. I finally hit the restart button since it wasn't doing anything and it booted up. Any idea why it wouldn't take the new fan?
12-09-2019, 9:34pm | #2 | ||||||
2016 Election Expert
Barn Stall Owner #64
Does the new fan ohm out at a reasonable reading? A dead short could do this. Should be a few ohms (not sure exact but not zero) but if it looks ok in that regard then no idea. Shouldn’t even matter polarity wise.
12-09-2019, 9:37pm | #3 | ||||||
Say a fan uses 5 watts. The voltage is 5 volts. P=V*v/R. R=V*V/P=5 ohms. Should be in that range.
12-09-2019, 11:33pm | #4 | ||||||
Don't know but the fan worked when I turned it on.
12-10-2019, 7:57am | #5 | ||||||
Gameroom Barn Bucks: $406058
It's been a while since I messed with PC components, but some fans that plug into MBs have connections for sensing, speed control, or whatever. Maybe the new fan isn't compatible, so the MB thinks there's no fan running & won't boot? You might want to run down the connector pin connections on the fan cable & MB & make sure they look correct.
12-10-2019, 10:27am | #6 | |||||||
More data is called for. Does the new fan work if you leave the old one plugged into the PS? Does the new fan work in a different PC?Does the PC boot if you unplug all the fans? |
12-10-2019, 1:08pm | #7 | ||||||
Gameroom Barn Bucks: $1524159
I never heard of a fan being plugged directly into the PS. I've used several Antec cases, and the rear fan will usually either plug into the motherboard connector, or plug into one of the PS power leads. Maybe a pic may help. The only thing that comes to mind if the positive and negative leads of the fan are reversed.
12-10-2019, 1:26pm | #8 | |||||||
12-10-2019, 3:19pm | #9 | ||||||
12-11-2019, 1:03pm | #10 | |||||||
New fan worked when plugged into the MB but the computer wouldn't load. It would get to the loading screen and just have the little thing spinning that shows up when it's loading but not doing anything. put the old fan back in and it did the same thing after putting up a message about launching repair something or other. The message would disappear but the thing stayed spinning. I eventually hit the restart button and hit to restore to a previous point. It chose what point and ended up working. Old fan has been in since then and the computer loads fine again. Fan is still going out though. It struggles to get started spinning but after it does, it seems to keep spinning fine. |
12-11-2019, 1:04pm | #11 | ||||||
I have this case on the way now. https://www.newegg.com/black-antec-p...82E16811129209
12-11-2019, 2:04pm | #12 | ||||||
You realize that new fans are like $4 dollars on Amazon, right?
12-11-2019, 2:33pm | #13 | ||||||
12-11-2019, 3:02pm | #14 | |||||||
12-11-2019, 7:06pm | #15 | ||||||
12-11-2019, 8:21pm | #16 | ||||||
12-11-2019, 8:24pm | #17 | ||||||
