10-08-2009, 10:50pm | #1 | ||||||
Adjusting A4 shifts
So I am curious about tuning the shifts on the A4. When you use tuning software what is it that you can actually change? I know you can change the RPM for WOT shifts and you can also change the MPH at which it shifts under normal driving but what is it that you change as far as shift firmness goes? Is there a % of pressure adjustment or what?
Please edumacate me. |
10-09-2009, 6:52am | #2 | |||||||
Gameroom Barn Bucks: $2827
I'm sure Ed will chime in with an explanation.
2008 C6 Z06 |
10-09-2009, 7:25am | #3 | ||||||
I had mine changed by ECS at Carlisle a couple years ago. But I didn't ask about the finer points. Doug was so busy, I didn't want to take up anymore of his time, than I already had.
10-09-2009, 5:47pm | #4 | ||||||
Barn Stall Owner #78
Gameroom Barn Bucks: $1004569
Excuse my ignorance on the subject...is this the same as adjusting the shift points on an automatic tranny? I've been told that really peps up a C5 with automatic and I'm considering it too?
10-09-2009, 6:07pm | #5 | ||||||
Yes. If you see A4, that's a C5 auto. M6&M12 are manuals, normal and Z06.
10-09-2009, 6:09pm | #6 | ||||||
From what I understand you can change the shift points in regards to at what MPH it shifts during normal driving. You can change the RPM at which it shifts under full throttle and you can change the firmness of the shifts (or somehting of that nature) but I am not an expert so there could be more. I just wanna know more about the firmness of shifts and how that is actually controlled and changed.
10-09-2009, 9:44pm | #7 | ||||||
Charter Member - Vendor
Gameroom Barn Bucks: $155
all i can say is after ECS sent me back my mail order tune and they adjusted the shift points the car is night and day different to drive.
Well worth the money for the tune with the firm shifts i now have |
10-10-2009, 6:57am | #8 | ||||||
10-10-2009, 8:39am | #9 | ||||||
for what its worth
I bought a second computer on the famous auction site for my 99 for 85.00. Sent it direct to ECS with my vin and all the info for mods. They did thier magic and sent it back to me. I pulled old one out and put new one in. Took awhile to reprogram the computer tot he car but was simple. This was of doing it for me was great. Only took the car apart once and I still have original tune in the original computer. 250.00 total spent. |
10-10-2009, 11:27pm | #10 | |||||||
10-12-2009, 1:47pm | #11 | ||||||
You can change part throttle shift points for all gears, as far as MPH vs TPS %. You can change WOT shift points by RPM and speed. You can change shift time in milliseconds. You can also change the line pressure. Using the shift time and line pressure, you can change the shift firmness. Also reducing the amount of timing pulled in the torque reduction tables really wakes them up.
The Following User Says Thank You to edcmat-l1 For This Useful Post: |
10-12-2009, 6:01pm | #12 | ||||||
Gameroom Barn Bucks: $27
I really need to get my car tuned.
10-12-2009, 6:06pm | #13 | |||||||
10-12-2009, 6:46pm | #14 | ||||||
Ed tuned mine and it was a HUGE difference.
10-13-2009, 10:58pm | #15 | ||||||
on a stock C5 you can disable Torque Manmagement... and do nothing else... and make a noticeable improvement on the A4.
Everything else adds icing to the cake. |
10-14-2009, 12:12am | #16 | ||||||
12-28-2009, 5:44pm | #17 | ||||||
Barn Stall Owner #44
Gameroom Barn Bucks: $30044
Is there a way to tell what has been or what kind of a tune has been put on a car? I think my car was tuned before it was mine I have found some things that have been changed the 2.73 gears was changed to 3.42 out of a Z and when it shifts its hit very firm. I haven't been in stock A4 so I don't have any thing to compare it to, thanks for any input. I don't want to change anything but I would like to know what if anything has been done.
C5 97 Arctic White A4 |
12-28-2009, 6:17pm | #18 | ||||||
You could find someone with tuning software and hook your car up to see where things are set at. Of course you would need to know what the settings are from the factory to have something to compare it to.
12-30-2009, 11:08am | #19 | ||||||
I going to show my lack of knowledge here but anyway, the tuning software that is used to do this I ques it could upload my info save it as a file and you could have a default file with factory settings and you could switch them back and forth if you wanted too for some reason? are any of the changes permanent? I think I seen a post somewhere that stated that something with the shift points were permanent which I didn't understand why you would not be able to default it.
12-30-2009, 3:31pm | #20 | ||||||
I have heard of people making a couple of tune files and then swapping them to suit their needs. As far as changes being permanent I can't imagine why, if you can change something once there should be no reason why you can't change it again. I am about as far away from an expert on this as one can get so you might want to post this in Ed's tuning sticky in this section, he probably checks that more often.
