Old 09-18-2011, 11:12am   #1
Olustee bus
Points: 41,978, Level: 100
Activity: 1.4%
Olustee bus's Avatar
Gameroom Barn Bucks: $1232517
Default The next time you have smoked boston butt, put this on them
Either with sandwiches or plates.
3 pounds pickling cucumbers, sliced into 1/4-inch thick slices
2 cups sliced onions
1/2 cup pickling salt
6 cups water
3 cups white vinegar
1 1/2 cups apple cider vinegar
3 1/2 cups sugar
2 tablespoons yellow mustard seeds
1/2 teaspoon turmeric
4 whole cloves
10 tablespoons roughly chopped garlic
24 dried cayenne peppers
2 teaspoons 100 percent Natural Pickle Crisp, optional
Place cucumbers, onions, pickling salt, and water in a large, non-reactive bowl. Cover and allow cucumbers to soak for 2 hours. Drain the water from the onions and cucumbers through a colander and rinse well for 5 minutes. Drain well and set aside.
Combine the vinegars, sugar, mustard seeds, turmeric, cloves, garlic, and peppers in a medium saucepan over high heat. Bring to a boil, reduce heat to medium and add the cucumbers and onions. Bring to a simmer and remove the saucepan from the heat.
Fill each of the hot sterilized pint-size preserving jars with the pickle mixture, dividing them evenly, and enough of the liquid to come within 1/2-inch of the top. Add 1/2 teaspoon of Natural Pickle Crisp to each jar, if desired. With a clean damp towel, wipe the rim and fit with a hot lid. Screw on the metal ring just until the point of resistance is met. Process the jars in a hot-water bath for 15 minutes.
Using tongs, remove the jars, place on a towel, and let cool. Test the seals by allowing the jars to stand at room temperature overnight or until the lids pop. Tighten the rings and store in a cool dry place. Let the pickles age for at least 2 weeks before using.
Read more: I am looking for a copycat recipe for "wickles" pi Community Forums - p1 - Food.com
Now, if you don't want to do this, buy the same thing if you can find it.
It is really good.
Olustee bus is offline   Reply With Quote
Old 02-24-2012, 3:31pm   #2
Bucwheat
Points: 49,877, Level: 100
Bucwheat's Avatar
Sounds awesome.
