05-27-2019, 11:28am | #1 | ||||||
Remove Great Stuff spray insulation foam.
I used this stuff yesterday and I got it on my hands. I cannot find ANYTHING that even begins to remove it.
Any ideas? I've tried: 100% acetone 91% alcohol PB blaster WD 40 Purple Power Dawn Green Scotchbrite pad |
05-27-2019, 11:38am | #2 | ||||||
Gameroom Barn Bucks: $930358
Acetone has worked for me before it dries. Once it dries you'll have to scrub yourself raw to get it off.
05-27-2019, 11:51am | #3 | ||||||
Pro tip: Don't get Great Stuff foam on your hands.
05-27-2019, 11:52am | #4 | ||||||
Barn Stall Owner #3
Gameroom Barn Bucks: $2324642
The Following 3 Users Say Thank You to C5SilverBullet For This Useful Post: |
05-27-2019, 11:55am | #5 | ||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
Wear gloves
The Following User Says Thank You to Black94lt1 For This Useful Post: |
05-27-2019, 11:58am | #6 | ||||||
Moderatrix
Barn Stall Owner #109 BR Organizer II,III,IV NCM Supporter '17 Bantayan Kids '13,'15,'17
Location: Your not a good moderator either, V-A-G. Honestly I find it kind of funny.
Gameroom Barn Bucks: $9966256
Get an old school emery board (nail file) and file off as much as you can. Get as close to the skin as you can get and make the layer as thin as possible. You may have to use more than one emery board but don’t file your skin off. From there you should be able to use nail polish remover/acetone. Or if the layer is thin enough you can just peel it off.
This also works if you ever get superglue on your fingers. |
05-27-2019, 12:05pm | #7 | ||||||
VB Dad of the Year
Yeah, but the real problem is the OP didn't disclose that said hand is also connected to his Johnson.
The Following 6 Users Say Thank You to Datawiz For This Useful Post: |
05-27-2019, 12:25pm | #8 | ||||||
Gameroom Barn Bucks: $1232517
you may want to try MEK available at hardware store. DO NOT GET IT ON YOU JONSON.
05-27-2019, 12:36pm | #9 | ||||||
Barn Stall Owner #6969
Gameroom Barn Bucks: $1071547
05-27-2019, 12:45pm | #10 | ||||||
Happened to me years ago......time will get it off.....nothing else
The Following User Says Thank You to 04 commemorative For This Useful Post: |
05-27-2019, 12:45pm | #11 | ||||||
I just spent about 20 minutes sanding my fingers with a sanding pad. I'm pretty sure I could be a burglar and leave no prints behind. A lot is gone, a lot is left. Even what's left is not at all affected by the acetone.
Note to self, wear gloves next time. |
The Following 3 Users Say Thank You to Aerovette For This Useful Post: |
05-27-2019, 2:10pm | #12 | ||||||
Like others have said, it will come off with time. Just be thankful you didn't get it on your clothes. I did, and it won't come off...EVER!
05-27-2019, 2:58pm | #13 | ||||||
Moderatrix
05-27-2019, 4:27pm | #14 | |||||||
Oh but I did. They came up with this ingenious nozzle that loops back on itself and attaches to a pin plug so you can use it again without the straw clogging. I went to "use it again" and pulled the wrong end loose. I proceeded to coat my door, clothes and patio with it. I was wiping it away quickly with my hand and...here I am asking how to get it off me. |
05-27-2019, 4:52pm | #15 | |||||||
05-27-2019, 7:42pm | #16 | ||||||||
Here's a classic from the 4wd forums How Do I Get Herculiner Off of My Hootus?! https://www.explorerforum.com/forums...-hootus.18595/ Quote:
05-27-2019, 7:58pm | #17 | ||||||
Awesome pics!
Oh, wait... |
05-27-2019, 8:59pm | #18 | ||||||
I'm gonna use Great Stuff insulating foam to make a cast of my junk. Can I just spray it down with Pam or WD-40 before I apply the foam in order to make removing the foam easier?
05-27-2019, 9:01pm | #19 | |||||||
What was it you were trying to seal in the first place? |
05-27-2019, 10:00pm | #20 | ||||||
