General Tips & Tricks - How To's Post any Tips & Tricks or How To's here that could apply to all Corvette generations. |
10-13-2009, 3:27pm | #1 | ||||||
Barn Stall Owner #777
Gameroom Barn Bucks: $6589249
Help! Key Fob fix please!
Can someone post the information for taking apart and resoldering the older key fobs? Mine is of the 1998 variety, and it is constantly losing it's link with the car.
Thanks in advance! |
10-24-2009, 4:53am | #2 | ||||||
Disassembly is pretty straight forward, here's the components to help;
You want to clean the carbon buttons and contacts; Make sure the battery contacts are clean and make good contact (two pads on the right side); OK Here's the common joints that come loose, they are on the chip but pry on every joint to see what else is loose; Solder all the loose contacts and you should be good to go! Tim |
The Following 4 Users Say Thank You to tstar For This Useful Post: |
10-24-2009, 9:21am | #3 | ||||||
Gameroom Barn Bucks: $2154
good info!
~~Shawn~~ 2018 Z06 A8 |
10-24-2009, 12:34pm | #4 | ||||||
FYI I should point out that the "silver can" on the upper left corner of the board is the rattle can that activates the Passive feature on the earlier C5s. Just in case some one opens theirs up and says... "Well, there's the problem, I'm missing sumptin!"
Tim |
12-08-2009, 12:52pm | #5 | ||||||
Is that like a tiny mercury switch, I wonder?
12-08-2009, 7:46pm | #6 | ||||||
Gameroom Barn Bucks: $7813
12-20-2009, 8:04pm | #7 | ||||||
Barn Raising I
Gameroom Barn Bucks: $1247236
And I was just going to suggest to change the battery.
04-05-2011, 12:55pm | #8 | ||||||
Good job,thanks.
