02-01-2011, 8:44pm | #1 | ||||||
Barn Stall Owner #21
Gameroom Barn Bucks: $850
Anyone know how to use a OBD1 Scanner?
Bought an Autoxray 6000 (used off ebay)- was able to get a scan, but when I ran the car and hit 'monitor' for live feed, first time it went for about 10 seconds (could see the water temp rise equaling what was on the dash) then it froze back to the original scan.
Rebooted, did it again, this time went 140 seconds, but before i could finish writing down all the numbers-stopped and reverted back to the original 2nd scan. Am I an idiot? or is this thing screwed up? |
02-01-2011, 9:32pm | #2 | ||||||
Gameroom Barn Bucks: $3895593
Sounds like a bad unit, I have never had that issue with my old MAC Tool OBD1 reader.
02-01-2011, 9:55pm | #3 | ||||||
My 92 was OBDI.
You turn the switch on but, do not start the engine. I think code 12 was a default code, means nothing. |
02-01-2011, 9:59pm | #4 | ||||||
Gameroom Barn Bucks: $825
Never had that happen with my Snap on mt2500, but check out this post--kinda sounds like what you're describing? Auto XRAY 6000
The Following User Says Thank You to Bronze85 For This Useful Post: |
02-01-2011, 10:37pm | #5 | ||||||
Auto x ray 6000 is I believe OBD 1 and 2. I have the x ray 5000. OBD1 does not capture any info like OBD2 does. The live moniter thing should work fine. If its not working correctly, shut down, restart and re insert start up info.
Mike |
The Following User Says Thank You to Corvette_Mike For This Useful Post: |
02-02-2011, 1:56am | #6 | ||||||
Barn Stall Owner #49
Gameroom Barn Bucks: $1025197
OBD1 works with the engine OFF/ ignition ON. Reads codes only-no live stuff or monitoring. 12 is an "alive" code(normal function-system ready). If the engine is running, test results are all skewed. I just short the pins and pump for codes..
OBD2 uses engine ON and monitors live. |
02-02-2011, 7:33am | #7 | |||||||
The Following User Says Thank You to WW7 For This Useful Post: |
02-02-2011, 8:36am | #8 | ||||||
Barn Stall Owner #25
02-02-2011, 8:43am | #9 | ||||||||||||
I noticed that the numbers to the right (01, 02, 03 etc.) were blinking when on Live Monitor as you scrolled through, but then they quit blinking and froze back to the original start up scan. This is a fecked up unit then, right? |
02-02-2011, 8:45am | #10 | ||||||
02-02-2011, 8:58am | #11 | ||||||
Here's something else I just remembered...I don't know what year car you have, but the mid to late 80s cars had some issues when working with scanners. I read somewhere on the Moate's site that they would drop the connection with the scanners after a short time because of the ecm that was used in the mid to late 80s cars. I also use Datamaster with my computer and I will loose the connection once in awhile with that also..You will also notice with the Auto Xray scanners that once in awhile you will see your engine start idleing funny, the rpms will pick up for no reason, this is another glitch they had with the computers and the ecms with the 80s cars.So what im saying is its not neccesarily your scanner thats screwing up....WW
02-02-2011, 9:03am | #12 | |||||||
I had to pull the battery and reboot the unit to get another scan. What's the protocol when doing this? Plug in unit Turn on unit (config to 92 GM) Turn on key Scan Then, what's the protocol for starting the car? do I leave the unit on? then hit MON for live monitoring? |
02-02-2011, 9:14am | #13 | ||||||
I plug my unit in, turn on key , turn unit on and set for the car Im scanning, then push button to connect , then push button to read the data, then start the car, then push button to read live data. Sometimes on mine it takes 2 or 3 trys to get it to connect, it will read "Scan unsuccessful"....WW
02-02-2011, 10:41am | #14 | ||||||
This would be the way to go, It will read live data,codes,bi-directional controls (meaning you can activate fuel pump, idle air control etc.) probably more than you need. It's the same one I have and this particular one has plenty of cartridges etc. for a good price. They're older so the bid should'nt go up much more. HTH Snap-on MT2500 Diagnostic Scanner Many Extras NoReserve - eBay (item 300519444562 end time Feb-02-11 12:08:17 PST)
02-02-2011, 1:49pm | #15 | |||||||
Is there a cartridge there that would work for my 92? |
02-02-2011, 1:51pm | #16 | |||||||
02-02-2011, 2:09pm | #17 | ||||||
Barn Stall Owner #37
Barn Raising I,II,III NCM Supporter '11,'12,'13,'15,'17 Bantayan Kids '13,'15
Gameroom Barn Bucks: $514865
02-02-2011, 3:07pm | #18 | ||||||
Gameroom Barn Bucks: $100015
The girl in the background in the purple top is a bit jealous. Probably because her boyfriend's shirt is wet with drool.
02-02-2011, 3:35pm | #19 | ||||||
Gameroom Barn Bucks: $2013824
^^^ haha, good catch...I never made it past the booty to notice much else on that pic.
02-02-2011, 3:43pm | #20 | ||||||
The primary GM etc. through 99 etc. would be the ones you need, that auctions over but they're always on there. The one I have has the programmable cartridges but I still have the old ones. If you wind up getting that type of scanner and need them lemme know.
