#1 | ||||||
Barn Stall Owner #4 Barn Raising I,II NCM Supporter '13,'14,'15,'16,'17,'21 Bantayan Kids '13,'14,'15,'17 ![]()
Started this today for one of you broken toys here.
spent about 30-45 min sketching things out, figuring out a cool pattern i could make with the materials available. 2 glue ups, both about 24" long. will get planed flat on each face, then cross cut into about 2-1/8" thick strips, those then get glued up again with end grain exposed. should get 10 strips out of each glue up, than join those together in an alternating fashion for a cool result. more tomorrow, let this dry all night. don't be afraid to use glue, it's cheap (sort of). used about 1/3 of the bottle, will use about that much again tomorrow. Titebond 3 - it's food safe and waterproof (so the board won't fall apart when you clean it, but don't soak it in water ![]() ![]() |
The Following 30 Users Say Thank You to DAB For This Useful Post: | 16again, 73sbVert, 86RAG, Black94lt1, Blademaker, carlton_fritz, Dan47, Don Rickles, dwjz06, gs568, higgyburners, JRD77VET, LATB, LisaJohn, Louie Detroit, MadInNc, Millenium Vette, Mr Hole, NEED-A-VETTE, Norm, snide, sublime1996525, Tikiman, ToolMaker, Tpatt, TripleBlack, Vandelay Industries, VatorMan, Vegas, Vette40th |
#2 | ||||||
Gameroom Barn Bucks: $18284
Those things are beautiful once complete. Wish I had the time/skills/ and equipment to do it.
The Following User Says Thank You to Egnalf For This Useful Post: |
#3 | ||||||
Barn Stall Owner #117
Going to be beautiful, Douglas.
![]() Titebond 3 is good stuff. I go through about three bottles of it a year. Do you run the board through a drum sander after the final glue up? |
The Following 17 Users Say Thank You to Tikiman For This Useful Post: |
#4 | ||||||
Don’t have a drum sander. So it gets placed on a flat piece of granite, and high spots are sanded down with a handheld belt sander.
#5 | ||||||
Barn Stall Owner #1776
NCM Supporter '11,'12,'13,'14,'15,'16,'17,'19,'20,'21 Bantayan Kids '13,'17 ![]()
Location: BRANDON FALLS, DE had owned a '65, '75, '97, '01, '10, '14, '16Z, now '81, '86.
Back in the groove, will be excellent.
#6 | ||||||
Gameroom Barn Bucks: $2001216
I recognize those trees!
![]() Two mints are better than one! |
#7 | ||||||
Nothing better than a fine piece of ash.
The Following User Says Thank You to Tikiman For This Useful Post: |
#8 | ||||||
#9 | ||||||
some scraping and planing gets us to this point.
will let finish drying overnight, then cross cut and glue again. |
The Following 7 Users Say Thank You to DAB For This Useful Post: |
#10 | ||||||
The Following 9 Users Say Thank You to Tikiman For This Useful Post: |
#11 | |||||||
![]() Quote:
this board was limited by how much lumber I was sent. stay tuned. ![]() |
#12 | ||||||
Barn Stall Owner #90125 NCM Supporter '19,'20 ![]()
I mean, unhappy people need to cut stuff, too. Seems discriminatory to me.
#13 | ||||||
Barn Stall Owner #97
Looking forward to watching this project. You have amazing talent!
The Following User Says Thank You to ToolMaker For This Useful Post: |
#14 | ||||||
Barn Stall Owner #16A
Barn Stall Owner #16B NCM Supporter '11,'13 Bantayan Kids '13 ![]()
Gameroom Barn Bucks: $602908
It isn’t fancy enough
#15 | ||||||
#16 | ||||||
Barn Stall Owner #101 Bantayan Kids '13 ![]()
Some years ago, I got a cutting board you made for my daughter, a year ago or so, I spotted it drying in her kitchen, been used......
#17 | ||||||
#18 | ||||||
Moderator
Barn Stall Owner #20 Barn Stall Owner #33 Barn Raising I,II NCM Supporter '11,'13,'14,'20,'21 Bantayan Kids '13 ![]()
Gameroom Barn Bucks: $988270
Mine's been used as well, not as fancy as the multiple wood boards, but just as much appreciated!
The Following User Says Thank You to 73sbVert For This Useful Post: |
#19 | ||||||
cross cut to 2" thick, yields 11 pieces per glue up. keep the pieces straight, and then choose one from column A, and one from column B - wash, rinse, repeat, then add some glue. lots of glue....
almost ran out of glue from the first bottle (which was full yesterday before i started), thankfully, had a second bottle in reserve. final piece will be about 12-1/2 x 19-1/4 or so. will round the corners later. i did the glue up on the scrap piece of granite, which is perfectly flat (not sure the work bench is), so the cutting board should require minimal sanding to make it lay flat later. |
#20 | |||||||
![]() Quote:
WOW!!! |
