Old 05-10-2022, 11:57am   #1
aerovette
Barn Stall Owner #7734
Points: 71,454, Level: 100
aerovette's Avatar
Location: It's insulting when liberals think we're as stupid as they are.
Default A meaningless story to pass the time.
I had a motor mount go bad on my truck. I watched a few videos and figured I'd tackle it myself. Well, I slid under the truck and changed my mind real fast. Being 4WD, there was way too much big bulky shit in the way and I decided this would get farmed out. I don't have a second car so anything I do, or get done, has to be all in one day. A coworker knows the owner of an aftermarket accessories shop. The guy quoted a decent price and my first question was "Have you done this before?". He assured me he has. Said it's a big job, but not outside their wheelhouse.
Fast forward, they call and tell me the truck is done. I go pick it up and immediately I have a check engine light. No panic since I knew the battery was disconnected etc. I cleared the fault but it came back. Turns out they broke the knock sensor off the block. I took it back and learned that the guy that worked on my truck was so pissed off about what a huge job it was, that he quit. They rep[laced the sensor no charge of course. In hindsight, I think he quit before he was done with my truck...
I would back out of my driveway and hear a "clunk" in the front end as I steered from left to right. The truck is pushing 130k so I know things will start happening. Probably needs some suspension work.
I FINALLY decided to take it to my regular shop. He tells me that the rack was left loose when parts of the suspension were removed to get to the motor mount. The pissed off mechanic never tightened the rack. They also left off or lost a sway bar bushing. He got it all listed out and I had two tie rod ends put on, sway bar bushings, and an alignment. He called to tell me the truck was on the alignment rack and getting finished up. It should be done by the time I get there to pick it up.
I pulled in and it was still on the rack. I went in to the office and was informed that they found more loose bolts and were still checking it all out.
Now I have it back and it steers tight and right. Moral of the story, if you find a decent mechanic, treat them right and know it isn't always about price or convenience. Going to the Off Road shop because it was close to my office, could have caused a catastrophic accident. I just got lucky that I took it to my guy before it all came apart.
aerovette is offline   Reply With Quote
The Following 4 Users Say Thank You to aerovette For This Useful Post:
Old 05-10-2022, 12:16pm   #2
Anjdog2003
Points: 27,421, Level: 100
Activity: 99.6%
Anjdog2003's Avatar
Gameroom Barn Bucks: $324490
cliffs
Anjdog2003 is offline   Reply With Quote
Old 05-10-2022, 12:36pm   #3
RMVette
Points: 42,748, Level: 100
Activity: 99.5%
RMVette's Avatar
Gameroom Barn Bucks: $311064
You're lucky something didn't come apart!
RMVette is online now   Reply With Quote
Old 05-10-2022, 12:39pm   #4
GTOguy
Points: 1,018, Level: 18
Activity: 12.7%
GTOguy's Avatar
I was a pro mechanic for 17 years in private industry before I went into consumer protection involving auto repair for another 25 years, and sadly, your story is very common. You 'get what you pay for'. Always check the reputation of the tech or the shop and be leery of great deals. Mechanics/Techs that are getting treated right and paid fairly for their work generally do an excellent job. Like everything else, 5% of the bad techs give the 95% of the rest of the techs a black eye. I remember a couple of occasions where I had to pick up on a repair job that another tech had quit or walked off on and went home 'sick'.....in each case, virtually everything surrounding the repair area was buggered up, loose, stripped, or broken. Sorry for your experience.
GTOguy is offline   Reply With Quote
The Following User Says Thank You to GTOguy For This Useful Post:
Old 05-10-2022, 12:39pm   #5
Points: 127,576, Level: 100
Activity: 71.1%
Mike Mercury is online now   Reply With Quote
The Following 5 Users Say Thank You to Mike Mercury For This Useful Post:
Old 05-10-2022, 12:40pm   #6
RMVette
Activity: 99.5%
RMVette's Avatar
Originally Posted by Mike Mercury View Post
Well alrighty then.....
Old 05-10-2022, 1:19pm   #7
DJ_Critterus
Stall Owner #1120.2520
Points: 82,344, Level: 100
DJ_Critterus's Avatar
That's the equivalent of using @aerovette as your electrician.
DJ_Critterus is offline   Reply With Quote
The Following 3 Users Say Thank You to DJ_Critterus For This Useful Post:
Old 05-10-2022, 2:13pm   #8
aerovette
aerovette's Avatar
Originally Posted by Anjdog2003 View Post
cliffs
Truck broke then
Truck fixed bad then
Truck fixed good
The Following 7 Users Say Thank You to aerovette For This Useful Post:
Old 05-10-2022, 2:49pm   #9
Points: 34,226, Level: 100
"When your monthly nut is $3000..."
dvarapala is online now   Reply With Quote
The Following 2 Users Say Thank You to dvarapala For This Useful Post:
Old 05-10-2022, 3:57pm   #10
Vandelay Industries
Points: 12,766, Level: 78
Activity: 55.6%
Vandelay Industries's Avatar
Gameroom Barn Bucks: $4810
This story lived up to its title.
Vandelay Industries is offline   Reply With Quote
The Following 2 Users Say Thank You to Vandelay Industries For This Useful Post:
Old 05-10-2022, 4:09pm   #11
ratflinger
Barn Stall Owner #THX1138
Points: 11,275, Level: 73
Activity: 26.9%
ratflinger's Avatar
Gameroom Barn Bucks: $1322
I approve of the ingenuity shown here. Base steel would have been cheaper though.
ratflinger is offline   Reply With Quote
The Following User Says Thank You to ratflinger For This Useful Post:
Old 05-10-2022, 4:33pm   #12
Don Rickles
Points: 10,188, Level: 69
Activity: 73.6%
Don Rickles's Avatar
Gameroom Barn Bucks: $2001216
Your tailgate vehicle?
Don Rickles is online now   Reply With Quote
Old 05-10-2022, 4:39pm   #13
Points: 81,723, Level: 100
Activity: 51.2%
Maybe big zip ties would have worked
04 commemorative is online now   Reply With Quote
Old 05-10-2022, 4:52pm   #14
aerovette
aerovette's Avatar
No. Ask me how I know.
Old 05-10-2022, 4:53pm   #15
The_Dude
Points: 33,907, Level: 100
Activity: 37.2%
The_Dude's Avatar
Gameroom Barn Bucks: $306898
No, they did that for fun I think.
The_Dude is offline   Reply With Quote
Old 05-12-2022, 6:16am   #16
ToolMaker
Barn Stall Owner #97
Points: 9,131, Level: 66
Activity: 11.6%
ToolMaker's Avatar
I see lots of things like this on rat rods. It's fun looking for it!
ToolMaker is offline   Reply With Quote
Old 05-12-2022, 8:33pm   #17
m and t's77
Points: 13,586, Level: 80
Activity: 7.4%
m and t's77's Avatar
Gameroom Barn Bucks: $3122345
The welds are near perfect,it was for showing off for sure.
The Following User Says Thank You to m and t's77 For This Useful Post:
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
