05-26-2024, 11:08pm | #1 | ||||||
Hey Flexo! This video's for you!
05-27-2024, 12:07am | #2 | ||||||
Well, if there is an actual documented case of a C6-C8 being stolen this way, then I'll worry.
I'm more worried about somebody with a tow truck hauling it off. That's much quicker, simpler, and MUCH quieter than somebody starting the car. This may be of some concern on other types of fobs, but again, I am not aware of a single case of fob "cloning" on Vettes. |
05-27-2024, 8:20am | #3 | |||||||
05-27-2024, 8:33am | #4 | |||||||
Gameroom Barn Bucks: $2115673
Being a good contributor in the car help section of that other website for many years I noticed that most HELP I locked myself out had to do with that system! |
05-27-2024, 8:45am | #5 | ||||||
Gameroom Barn Bucks: $12967
05-27-2024, 8:49am | #6 | ||||||
05-27-2024, 9:11am | #7 | |||||||
If a button on the car is pressed, it has a very short range (within a couple of feet). If a button on the fob is pressed, it has a much longer range. There is no way to "turn off" the passive entry on a recent MY GM. I take it back, you don't have passive entry if the battery is dead or missing, and you have to use the key to get inside. Then you must put the fob in the slot to start. Or use a Faraday cage. If your fob battery is dead in a year, either a button on the fob is stuck, or it was a sub-par battery out of the gate (not uncommon). I once had a battery go bad quickly, and when I changed it there was a fingerprint etched on it. Be careful to touch only the edges when changing it. The battery should last about 3 years on average. |
The Following User Says Thank You to owc6 For This Useful Post: |
05-27-2024, 10:00am | #8 | ||||||
Barn Stall Owner #123
Gameroom Barn Bucks: $525
05-27-2024, 10:27am | #9 | ||||||
I agree. They can hook to it even in gear with the brake on, drag it around the corner, and winch it up onto the rollback in a minute making minimal noise.
05-27-2024, 10:39am | #10 | ||||||
Gameroom Barn Bucks: $1524159
I have a new 2024 Honda Pilot SE. If my FOB is dead because of the battery, I can still start the car by moving the dead FOB next to the start button which will then start the car.
I miss the gold old days of simply having a key. Not really into all this convenience. What about getting something like this: https://www.amazon.com/Stoplock-HG-1...A1GJZM3EQ&th=1 |
The Following User Says Thank You to Wathen1955 For This Useful Post: |
05-27-2024, 10:49am | #11 | |||||||
That is incorrect. I walk up to my vehicle, I press the button on the handle of the door, the doors unlock. I press NO buttons on the fob. If a thief can imitate/simulate the signal from my fob, the doors will unlock and my ignition will allow the vehicle to start. Simple. |
05-27-2024, 10:51am | #12 | ||||||
05-27-2024, 10:52am | #13 | |||||||
05-27-2024, 10:59am | #14 | |||||||
Myself and a couple others ( mostly eboggs) have done extensive research into how the fob system operates, with hundreds if not thousands of posts on the subject at the other place if you are interested in some long reading. |
05-27-2024, 11:41am | #15 | |||||||
The Following User Says Thank You to KenHorse For This Useful Post: |
05-27-2024, 12:05pm | #16 | ||||||
05-27-2024, 12:07pm | #17 | ||||||
05-27-2024, 12:10pm | #18 | ||||||
05-27-2024, 1:14pm | #19 | ||||||
FYI the Z06 was reversed into the driveway with my Charger directly behind it and my stepsons F150 beside it, and there were no skids marks. It wasn't dragged.
05-27-2024, 1:19pm | #20 | ||||||
