Old 03-18-2010, 1:03pm   #1
Default Is there a fuse I can pull to disable the power antenna?
I've got an aftermarket Pioneer Premier HU installed w/ XM so I never listen to the radio. The antenna recieves power any time the HU is on. Cutting the wire that supplies the power cut the power to my OEM speaker door amps so I had to reconnect it. When I was putting in my flush tails I couldn't see an easy way to get to a plug to unplug it.
So... is there a fuse I can pull or can anyone tell me where I might be able to unplug it?
-Brian
Old 03-18-2010, 1:19pm   #2
CF search tells me the #24 fuse in the passenger side footwell will do the trick. Will try that and report back.
Old 03-18-2010, 6:23pm   #3
Well that didn't work... pulling that fuse kile the power to the bose door amps. Kiled the antenna too... had to plug it back in. Gotta find the power plug to unplug the thing.
Old 03-18-2010, 6:53pm   #4
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Not sure if you can get to the motor on the antenna in the trunk or not? If you can you could clip the power wire would be easier than pulling the Head unit and finding the antenna power wire and clipping it, bad thing is once clip then you can not raise it when you need it unless you wire in a switch. As far as I know there is not one fuse that will do it as that fuse runs other electrical components. No easy fix as far as I know?
Old 03-18-2010, 9:19pm   #5
I allready clipped the supply off of my HU and that disabled my OEM speaker amps so I had solder it back together. There has to be a plug somewhere b/c you have to be able to replace the antenna unit. When I had the tails out last weekend I couldn't find any plugs... didn't start taking the interior apart but I'm guessing there's a plug somewhree along the way.
Old 03-19-2010, 9:50am   #6
Figured it out.... plug is on the backside of the passenger wheel well. From the manual:
4. Remove the RH decklid support trim panel. Pull to release the retaining clips.
5. Pull back the edge of the rear compartment floor carpet from behind the RH decklid support, then reposition the RH side of the carpet.
6. Release the antenna coaxial cable and wiring harness from the retaining clip on the rear of the wheelhouse.
7. Disconnect the power antenna coaxial cable from the power antenna coaxial extension cable.
8. Disconnect the antenna electrical connector from the front body wiring harness connector.
Old 03-19-2010, 10:12am   #7
Vet4jdc
Barn Stall Owner #78
Points: 19,383, Level: 96
Vet4jdc's Avatar
Gameroom Barn Bucks: $1004569
Gump....you're a friggin geniuos!
Old 03-19-2010, 7:42pm   #8
Garb55
Garb55's Avatar
I thought there was something back there. Glad you found it and thanks for sharing the detailed info.
